Vista Tutorial - Disk Management - Delete and Extend
Comment
Old 09-28-2007
Brink
Administrator
How to Delete and Extend a Partition with Disk Management in Vista
Old 02-10-2009
Emil Musayev
Vista Business x32
Post Re: Disk Management - Delete and Extend
Quote  Quote: Originally Posted by Brink View Post
Hello Emil,
Yes you can use DISKPART to delete the D: OEM partition if you would like to.
Afterwards, you can use Disk Management on the now unallocated partition if you like.
Why D:?
On my system this partition is hidden/system and without any assigned letters.
I just afraid that if I delete hidden partition some boot problems raised.
Old 02-10-2009
Brink
Administrator
Emil,
Usually the OEM recovery partition is located on the D: Partition, and the hidden EISA partition with no drive letter is just the location of the drivers and free or trial applications files that came with your OEM computer. It will be safe to remove both of these since you have created both of these to DVD already to use instead.
Old 02-10-2009
SIW2
Master
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Hi emil,
It will help you if you give the hidden partitions drive letters - D and E will do if your dvd drive is not already D , otherwise use E and F.
Are the hidden partitions on the left or the right as viewed in Disk Management ?
If you post a screenshot of Disk Manangement it will help.
You shouldn't have trouble booting as long as you don't move the Vista partition ( C ).
Hope it helps
SIW2
Old 02-10-2009
Emil Musayev
Vista Business x32
Quote  Quote: Originally Posted by SIW2 View Post
Hi emil,
Hope it helps
SIW2
I didn't assign any drive letter and I can't to do it.
It is system / hidden/ not active partition in the beginning of disk.
My Vista running on the same disk (drive letter C).
It is factory settings.
Old 02-10-2009
SIW2
Master
You should be ok to delete that if you really need to -it will then be unallocted space.
You could make another partition from that unallocated space to use as you wish.
You will not be able to use Disk Management to incorporate it into the same partition Vista is on.
SIW2
Old 02-10-2009
Brink
Administrator
Emil,
You can use METHOD TWO in the tutorial below picking up at step 2 to extend the C: partition into that bit of unallocated space so that you have just one disk again.
Partition or Volume - Extend - Windows 7 Forums
Old 03-31-2009
helodude
Newbie
vista home premium
Need help extending partition C. I have run out of space. I deleted Partition D and I still cannot extend partition. It now says free space. I have a lenovo y510.
Old 03-31-2009
Brink
Administrator
Hello Helodude, and welcome to Vista Forums.
Can you post a screenshot of your Disk Management to better see what may be going on?
Comment
Tutorial Tools
Tutorial Category
computer management-disk management problem General Discussion
Computer Management - Disk Management... Vista General
why extend option in disk management is gray? Vista General
Computer Management --> Storage --> Disk Management Vista account administration
Hard drive management - extend Vista General
