Vista Tutorial - How to create a dialog box with radio buttons
Old 05-21-2008   #1 (permalink)
coolfiona
Guest
I am doing an HTA application, could you please tell how to create a
dialog box with a few radio buttons, and the dialog box can record
result from the radio button?
Thank you so much!!
Fay
Old 05-21-2008   #2 (permalink)
mayayana
Guest
Re: How to create a dialog box with radio buttons
See the post "Custom dialog boxes" from a couple of
days ago. Unless you use some kind of component, making
a custom message window means writing a webpage and
showing it in IE. You can write the function in an external
include file and link it in the HTA with something like:
<SCRIPT LANGUAGE="VBScript" SRC="ExtraOps.vbs"></SCRIPT>
The actual message would be a webpage that you write
dynamically and then open in IE as a separate HTML file.
> Thank you so much!!
> Fay
Grouping radio buttons w/o group box .NET General
Radio buttons do not save state after post back .NET General
Save as dialog box browser buttons are frozen? General Discussion
Using Radio Buttons within Powershell PowerShell
Missing buttons from print picture dialog box Vista music pictures video
