| | Re: Switches JoJo wrote: Quote: > By typing "Filename.EXE /?" or "Filename.EXE /Help" I can get a list of > all the available switches. > > This approach does NOT work with my VisualBasicFile.EXE file. > > * Is there another way to identify the switches associates with my EXE > file ? have a bit of luck to decipher what everything means. Process explorer will also list strings contained within running processes. ~JasonG -- |
| | Re: Switches Jason Gurtz wrote: Quote: > JoJo wrote: Quote: >> By typing "Filename.EXE /?" or "Filename.EXE /Help" I can get a >> list of all the available switches. >> >> This approach does NOT work with my VisualBasicFile.EXE file. >> recognizes when it parses a command line. Since it is your VisualBasicFile.EXE, you are the one to do something about that. |
| Alt-Tab switches between two windows only | Vista General | |||
| Using EXE Switches in Powershell | PowerShell | |||
| VGA switches | Vista hardware & devices | |||
| automatic program switches | Vista mail | |||
| Connection switches to Local Only? | Vista networking & sharing | |||
