Vista - vbscript and HTA help
Old 05-31-2008   #11 (permalink)
Daz
Re: vbscript and HTA help
On May 30, 10:31*pm, "McKirahan" <N...@xxxxxx> wrote:
Quote:
> "Daz" <darren.black...@xxxxxx> wrote in message
> news:8da8394b-7597-4b91-b64c-41d4a506d3d6@xxxxxx
> On May 29, 5:43 am, "McKirahan" <N...@xxxxxx> wrote:
Quote:
> >news:924ce5de-fac5-4157-8e20-eec9b1af3666@xxxxxx
> > On May 27, 5:41 am, "McKirahan" <N...@xxxxxx> wrote:
Quote:
Quote:
> > [snip]
Quote:
Quote:
> > > Just 1 final question... how do i remove the need for all fields to
> > > have an option checked?
> [snip]
Quote:
> > Replace these lines:
> [snip]
Quote:
> > with these lines:
> [snip]
Quote:
> > Ok the one thing this edit doesn't address is that fact that in the
> > final script i am working on the name field with be dynamically
> > populated from WMI and therefore i cannot use object & i as a array
> > building option...
> My response (as I stated) only addressed the one question.
> Perhaps if you posted your code I might be able to see what you want
> to "dynamically populate" the form with. *I can't read your mind.
Thanks for all your help... I have worked out another solution.
Thanks very much again.
Cheers,
Daz
New to VBscript, Help please! VB Script
CSS and VBscript VB Script
Where is VBscript now? VB Script
VBscript Help VB Script
How to do No hang up VBScript (nohup for VBScript) VB Script
