| Guest | vbscript and HTA help Hi all, Am trying my hand at my first HTA and would like to ask for some help with a process i am tying to implement... I would like to select one option of 3 options for a given object and then once all the objects have had a selection, output the object.name to a text file maching the choice... so if i picked disable for object 1 and automatic for object 2 and manual for object 3 and automatic for object 4 - i would have 3 text files with the object name on a line. So the output file for automatic (lets call it automatic.txt) would have object1 and on the next line object4. I think you get what i mean.... here is the test hta code i am working with at the moment... <html> <head> <title>test</title> <hta:application ID="objHTA" VERSION="1.0" icon="simple.ico" applicationName="test" border=dialog borderStyle=normal caption=yes contextMenu=yes innerBorder=yes maximizeButton=yes minimizeButton=yes navigable=yes scroll=no selection=yes showInTaskBar=yes sysMenu=yes singleInstance=yes windowState=normal /> <script language="vbscript"> Sub Window_Onload strComputer = "." Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") Set colItems = objWMIService.ExecQuery("Select * From Win32_DesktopMonitor") For Each objItem in colItems intHorizontal = objItem.ScreenWidth intVertical = objItem.ScreenHeight Next intLeft = (intHorizontal - 800) / 2 intTop = (intVertical - 600) / 2 window.resizeTo 800,600 window.moveTo intLeft, intTop window.focus() End Sub </script> </head> <body> <table width="200" border="1"> <tr> <td>object 1 <label></label></td> </tr> <tr> <td><input type='radio' name='disable' id='disable2' /> Disable </label> <label> <input type='radio' name='radio' id='Automatic2' value='Automatic' /> Automatic</label> <label> <input type='radio' name='radio' id='Manual2' value='Manual' / Quote: > </tr> <tr> <td>object 2</td> </tr> <tr> <td><input type='radio' name='disable' id='disable3' /> Disable </label> <label> <input type='radio' name='radio' id='Automatic3' value='Automatic' /> Automatic</label> <label> <input type='radio' name='radio' id='Manual3' value='Manual' / Quote: > </tr> </table> </body> </html> I would greatly appreciate your help ![]() Cheers, Daz |
| Guest | Re: vbscript and HTA help "Daz" <darren.blackley@xxxxxx> wrote in message news:83da94f4-28e4-46de-9eea-0fc83ac03dee@xxxxxx Quote: > Hi all, > > Am trying my hand at my first HTA and would like to ask for some help > with a process i am tying to implement... > > I would like to select one option of 3 options for a given object and > then once all the objects have had a selection, output the object.name > to a text file maching the choice... so if i picked disable for object > 1 and automatic for object 2 and manual for object 3 and automatic for > object 4 - i would have 3 text files with the object name on a line. > So the output file for automatic (lets call it automatic.txt) would > have object1 and on the next line object4. > > I think you get what i mean.... > > here is the test hta code i am working with at the moment... Will this help? Watch for word-wrap. <html> <head> <title>test</title> <hta:application ID="objHTA" VERSION="1.0" icon="simple.ico" applicationName="test" border=dialog borderStyle=normal caption=yes contextMenu=yes innerBorder=yes maximizeButton=yes minimizeButton=yes navigable=yes scroll=no selection=yes showInTaskBar=yes singleInstance=yes sysMenu=yes windowState=normal /> <script language="vbscript"> Sub Radios() Const cMAX = 4 Dim arrCTF(3) Dim intCTF Dim strCTF Dim arrDIC(3) arrDIC(1) = "Automatic" arrDIC(2) = "Disable" arrDIC(3) = "Manual" Dim intDIC Set objDIC = CreateObject("Scripting.Dictionary") For intDIC = 1 To UBound(arrDIC) objDIC.Add arrDIC(intDIC), intDIC Next Dim iMAX : iMAX = 0 DIm i, o, s For i = 1 To cMAX For Each o In Eval("document.form1.object" & i) If o.Checked = True Then iMAX = iMAX + 1 intCTF = objDIC.Item(o.Value) arrCTF(intCTF) = arrCTF(intCTF) & "object" & i & vbCrLf End If Next Next '* If iMAX = cMAX Then Set objFSO = CreateObject("Scripting.FileSystemObject") For intDIC = 1 To UBound(arrDIC) strCTF = arrDIC(intDIC) & ".txt" Set objCTF = objFSO.CreateTextFile(strCTF,True) objCTF.Write arrCTF(intDIC) Set objCTF = Nothing s = s & "<li>" & strCTF & " : " & Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf Next Else Alert("Only " & iMAx & " of " & cMAX & " radio buttons checked!") Exit Sub End If '* document.write s End Sub Sub Window_Onload() Const strComputer = "." Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") Set colItems = objWMIService.ExecQuery("Select * From Win32_DesktopMonitor") For Each objItem in colItems intHorizontal = objItem.ScreenWidth intVertical = objItem.ScreenHeight Next intLeft = (intHorizontal - 800) / 2 intTop = (intVertical - 600) / 2 window.resizeTo 800,600 window.moveTo intLeft, intTop window.focus() End Sub </script> </head> <body> <form name="form1"> <table border="1" width="300"> <tr> <td>object 1</td> </tr> <tr> <td> <input type="radio" name="object1" value="Disable">Disable <input type="radio" name="object1" value="Automatic">Automatic <input type="radio" name="object1" value="Manual">Manual </td> </tr> <tr> <td>object 2</td> </tr> <tr> <td> <input type="radio" name="object2" value="Disable">Disable <input type="radio" name="object2" value="Automatic">Automatic <input type="radio" name="object2" value="Manual">Manual </td> </tr> <tr> <td>object 3</td> </tr> <tr> <td> <input type="radio" name="object3" value="Disable">Disable <input type="radio" name="object3" value="Automatic">Automatic <input type="radio" name="object3" value="Manual">Manual </td> </tr> <tr> <td>object 4</td> </tr> <tr> <td> <input type="radio" name="object4" value="Disable">Disable <input type="radio" name="object4" value="Automatic">Automatic <input type="radio" name="object4" value="Manual">Manual </td> </tr> </table> <br> <input type="button" value="Submit" onclick="Radios()"> <input type="reset" value="Reset" > </form> </body> </html> |
| Guest | Re: vbscript and HTA help On May 25, 10:33*am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > > news:83da94f4-28e4-46de-9eea-0fc83ac03dee@xxxxxx > > > Quote: > > Hi all, Quote: > > Am trying my hand at my first HTA and would like to ask for some help > > with a process i am tying to implement... Quote: > > I would like to select one option of 3 options for a given object and > > then once all the objects have had a selection, output the object.name > > to a text file maching the choice... so if i picked disable for object > > 1 and automatic for object 2 and manual for object 3 and automatic for > > object 4 - i would have 3 text files with the object name on a line. > > So the output file for automatic (lets call it automatic.txt) would > > have object1 and on the next line object4. Quote: > > I think you get what i mean.... Quote: > > here is the test hta code i am working with at the moment... > [snip] > > Will this help? *Watch for word-wrap. > > <html> > <head> > <title>test</title> > <hta:application > *ID="objHTA" > *VERSION="1.0" > *icon="simple.ico" > *applicationName="test" > *border=dialog > *borderStyle=normal > *caption=yes > *contextMenu=yes > *innerBorder=yes > *maximizeButton=yes > *minimizeButton=yes > *navigable=yes > *scroll=no > *selection=yes > *showInTaskBar=yes > *singleInstance=yes > *sysMenu=yes > *windowState=normal > /> > <script language="vbscript"> > Sub Radios() > * * Const cMAX = 4 > * * Dim arrCTF(3) > * * Dim intCTF > * * Dim strCTF > * * Dim arrDIC(3) > * * * * arrDIC(1) = "Automatic" > * * * * arrDIC(2) = "Disable" > * * * * arrDIC(3) = "Manual" > * * Dim intDIC > * * Set objDIC = CreateObject("Scripting.Dictionary") > * * For intDIC = 1 To UBound(arrDIC) > * * * * objDIC.Add arrDIC(intDIC), intDIC > * * Next > * * Dim iMAX : iMAX = 0 > * * DIm i, o, s > * * For i = 1 To cMAX > * * * * For Each o In Eval("document.form1.object" & i) > * * * * * * If o.Checked = True Then > * * * * * * * * iMAX = iMAX + 1 > * * * * * * * * intCTF = objDIC.Item(o.Value) > * * * * * * * * arrCTF(intCTF) = arrCTF(intCTF) & "object" & i & vbCrLf > * * * * * * End If > * * * * Next > * * Next > * *'* > * * If iMAX = cMAX Then > * * * * Set objFSO = CreateObject("Scripting.FileSystemObject") > * * * * For intDIC = 1 To UBound(arrDIC) > * * * * * * strCTF = arrDIC(intDIC) & ".txt" > * * * * * * Set objCTF = objFSO.CreateTextFile(strCTF,True) > * * * * * * * * objCTF.Write arrCTF(intDIC) > * * * * * * Set objCTF = Nothing > * * * * * * s = s & "<li>" & strCTF & " : " & > Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf > * * * * Next > * * Else > * * * * Alert("Only " & iMAx & " of " & cMAX & " radio buttons checked!") > * * * * Exit Sub > * * End If > * *'* > * * document.write s > End Sub > > Sub Window_Onload() > * * Const strComputer = "." > * * Set objWMIService = GetObject("winmgmts:\\" & strComputer & > "\root\cimv2") > * * Set colItems = objWMIService.ExecQuery("Select * From > Win32_DesktopMonitor") > * * For Each objItem in colItems > * * * * intHorizontal = objItem.ScreenWidth > * * * * intVertical = objItem.ScreenHeight > * * Next > * * intLeft = (intHorizontal - 800) / 2 > * * intTop = (intVertical - 600) / 2 > * * window.resizeTo 800,600 > * * window.moveTo intLeft, intTop > * * window.focus() > End Sub > </script> > </head> > <body> > <form name="form1"> > <table border="1" width="300"> > <tr> > * <td>object 1</td> > </tr> > <tr> > * <td> > * * <input type="radio" name="object1" value="Disable">Disable > * * <input type="radio" name="object1" value="Automatic">Automatic > * * <input type="radio" name="object1" value="Manual">Manual > * </td> > </tr> > <tr> > * <td>object 2</td> > </tr> > <tr> > * <td> > * * <input type="radio" name="object2" value="Disable">Disable > * * <input type="radio" name="object2" value="Automatic">Automatic > * * <input type="radio" name="object2" value="Manual">Manual > * </td> > </tr> > <tr> > * <td>object 3</td> > </tr> > <tr> > * <td> > * * <input type="radio" name="object3" value="Disable">Disable > * * <input type="radio" name="object3" value="Automatic">Automatic > * * <input type="radio" name="object3" value="Manual">Manual > * </td> > </tr> > <tr> > * <td>object 4</td> > </tr> > <tr> > * <td> > * * <input type="radio" name="object4" value="Disable">Disable > * * <input type="radio" name="object4" value="Automatic">Automatic > * * <input type="radio" name="object4" value="Manual">Manual > * </td> > </tr> > </table> > <br> > <input type="button" value="Submit" onclick="Radios()"> > <input type="reset" value="Reset" > > </form> > </body> > </html> Thanks for you help and the code... it certainly is the sort of thing i am looking for. The only issue i have at the moment is that the output from the selected options isn't being captured in the txt files - am i missing something? Cheers, Daz |
| Guest | Re: vbscript and HTA help "Daz" <darren.blackley@xxxxxx> wrote in message news:85730564-e3cd-4036-a518-7a645861668f@xxxxxx On May 25, 10:33 am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > > news:83da94f4-28e4-46de-9eea-0fc83ac03dee@xxxxxx > > > Quote: > > Hi all, Quote: > > Am trying my hand at my first HTA and would like to ask for some help > > with a process i am tying to implement... Quote: > > I would like to select one option of 3 options for a given object and > > then once all the objects have had a selection, output the object.name > > to a text file maching the choice... so if i picked disable for object > > 1 and automatic for object 2 and manual for object 3 and automatic for > > object 4 - i would have 3 text files with the object name on a line. > > So the output file for automatic (lets call it automatic.txt) would > > have object1 and on the next line object4. Quote: > > I think you get what i mean.... Quote: > > here is the test hta code i am working with at the moment... > [snip] > > Will this help? Watch for word-wrap. Quote: > Set objFSO = CreateObject("Scripting.FileSystemObject") > For intDIC = 1 To UBound(arrDIC) > strCTF = arrDIC(intDIC) & ".txt" > Set objCTF = objFSO.CreateTextFile(strCTF,True) > objCTF.Write arrCTF(intDIC) > Set objCTF = Nothing > s = s & "<li>" & strCTF & " : " & > Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf > Next Hi, Thanks for you help and the code... it certainly is the sort of thing i am looking for. The only issue i have at the moment is that the output from the selected options isn't being captured in the txt files - am i missing something? It works for me... |
| Guest | Re: vbscript and HTA help On May 27, 5:41*am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > > news:85730564-e3cd-4036-a518-7a645861668f@xxxxxx > On May 25, 10:33 am, "McKirahan" <N...@xxxxxx> wrote: > > > Quote: > > "Daz" <darren.black...@xxxxxx> wrote in message Quote: > >news:83da94f4-28e4-46de-9eea-0fc83ac03dee@xxxxxx Quote: Quote: > > > Hi all, Quote: Quote: > > > Am trying my hand at my first HTA and would like to ask for some help > > > with a process i am tying to implement... Quote: Quote: > > > I would like to select one option of 3 options for a given object and > > > then once all the objects have had a selection, output the object.name > > > to a text file maching the choice... so if i picked disable for object > > > 1 and automatic for object 2 and manual for object 3 and automatic for > > > object 4 - i would have 3 text files with the object name on a line. > > > So the output file for automatic (lets call it automatic.txt) would > > > have object1 and on the next line object4. Quote: Quote: > > > I think you get what i mean.... Quote: Quote: > > > here is the test hta code i am working with at the moment... Quote: > > [snip] Quote: > > Will this help? Watch for word-wrap. > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > For intDIC = 1 To UBound(arrDIC) > > * *strCTF = arrDIC(intDIC) & ".txt" > > * * Set objCTF = objFSO.CreateTextFile(strCTF,True) > > * * * * objCTF.Write arrCTF(intDIC) > > * * Set objCTF = Nothing > > * * s = s & "<li>" & strCTF & " : " & > > * * Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf > > Next > [snip] > > Hi, > > Thanks for you help and the code... it certainly is the sort of thing > i am looking for. *The only issue i have at the moment is that the > output from the selected options isn't being captured in the txt files > - am i missing something? > > It works for me... Just 1 final question... how do i remove the need for all fields to have an option checked? i.e. if only 4 fields are checked - then i would still like it to write to the txt files obviously omitting the field not checked. Cheers, Darren |
| | #6 (permalink) |
| Guest | Re: vbscript and HTA help On May 27, 6:29*pm, Daz <darren.black...@xxxxxx> wrote: Quote: > On May 27, 5:41*am, "McKirahan" <N...@xxxxxx> wrote: > > > Quote: > > "Daz" <darren.black...@xxxxxx> wrote in message Quote: > >news:85730564-e3cd-4036-a518-7a645861668f@xxxxxx > > On May 25, 10:33 am, "McKirahan" <N...@xxxxxx> wrote: Quote: Quote: > > > "Daz" <darren.black...@xxxxxx> wrote in message Quote: Quote: > > >news:83da94f4-28e4-46de-9eea-0fc83ac03dee@xxxxxx Quote: Quote: > > > > Hi all, Quote: Quote: > > > > Am trying my hand at my first HTA and would like to ask for some help > > > > with a process i am tying to implement... Quote: Quote: > > > > I would like to select one option of 3 options for a given object and > > > > then once all the objects have had a selection, output the object.name > > > > to a text file maching the choice... so if i picked disable for object > > > > 1 and automatic for object 2 and manual for object 3 and automatic for > > > > object 4 - i would have 3 text files with the object name on a line. > > > > So the output file for automatic (lets call it automatic.txt) would > > > > have object1 and on the next line object4. Quote: Quote: > > > > I think you get what i mean.... Quote: Quote: > > > > here is the test hta code i am working with at the moment... Quote: Quote: > > > [snip] Quote: Quote: > > > Will this help? Watch for word-wrap. > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > > For intDIC = 1 To UBound(arrDIC) > > > * *strCTF = arrDIC(intDIC) & ".txt" > > > * * Set objCTF = objFSO.CreateTextFile(strCTF,True) > > > * * * * objCTF.Write arrCTF(intDIC) > > > * * Set objCTF = Nothing > > > * * s = s & "<li>" & strCTF & " : " & > > > * * Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf > > > Next Quote: > > [snip] Quote: > > Hi, Quote: > > Thanks for you help and the code... it certainly is the sort of thing > > i am looking for. *The only issue i have at the moment is that the > > output from the selected options isn't being captured in the txt files > > - am i missing something? Quote: > > It works for me... > Found the problem - it is working now... > > Just 1 final question... how do i remove the need for all fields to > have an option checked? i.e. if only 4 fields are checked - then i > would still like it to write to the txt files obviously omitting the > field not checked. > > Cheers, > Darren will be dynamically implemented and will be the value that is desired to be output to the text files... |
| | #7 (permalink) |
| Guest | Re: vbscript and HTA help "Daz" <darren.blackley@xxxxxx> wrote in message news:924ce5de-fac5-4157-8e20-eec9b1af3666@xxxxxx On May 27, 5:41 am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > Quote: > Just 1 final question... how do i remove the need for all fields to > have an option checked? i.e. if only 4 fields are checked - then i > would still like it to write to the txt files obviously omitting the > field not checked. If iMAX = cMAX Then Set objFSO = CreateObject("Scripting.FileSystemObject") For intDIC = 1 To UBound(arrDIC) strCTF = arrDIC(intDIC) & ".txt" Set objCTF = objFSO.CreateTextFile(strCTF,True) objCTF.Write arrCTF(intDIC) Set objCTF = Nothing s = s & "<li>" & strCTF & " : " & Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf Next Else Alert("Only " & iMAx & " of " & cMAX & " radio buttons checked!") Exit Sub End If with these lines: If iMAX <> cMAX Then strMSG = "Only " & iMAx & " of " & cMAX & " radio buttons checked!" If MsgBox(strMSG,vbQuestion+vbOKCancel,"Continue?") = vbCancel Then Exit Sub End If '* Set objFSO = CreateObject("Scripting.FileSystemObject") For intDIC = 1 To UBound(arrDIC) strCTF = arrDIC(intDIC) & ".txt" Set objCTF = objFSO.CreateTextFile("~" & strCTF,True) objCTF.Write arrCTF(intDIC) Set objCTF = Nothing s = s & "<li>" & strCTF & " : " & Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf Next Watch for word-wrap. |
| | #8 (permalink) |
| Guest | Re: vbscript and HTA help On May 29, 5:43*am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > > news:924ce5de-fac5-4157-8e20-eec9b1af3666@xxxxxx > On May 27, 5:41 am, "McKirahan" <N...@xxxxxx> wrote: > Quote: > > "Daz" <darren.black...@xxxxxx> wrote in message > [snip] > Quote: > > Just 1 final question... how do i remove the need for all fields to > > have an option checked? i.e. if only 4 fields are checked - then i > > would still like it to write to the txt files obviously omitting the > > field not checked. > Replace these lines: > > * * If iMAX = cMAX Then > * * * * Set objFSO = CreateObject("Scripting.FileSystemObject") > * * * * For intDIC = 1 To UBound(arrDIC) > * * * * * * strCTF = arrDIC(intDIC) & ".txt" > * * * * * * Set objCTF = objFSO.CreateTextFile(strCTF,True) > * * * * * * * * objCTF.Write arrCTF(intDIC) > * * * * * * Set objCTF = Nothing > * * * * * * s = s & "<li>" & strCTF & " : " & > Replace(arrCTF(intDIC),vbCrLf," ") & vbCrLf > * * * * Next > * * Else > * * * * Alert("Only " & iMAx & " of " & cMAX & " radio buttons checked!") > * * * * Exit Sub > * * End If > > with these lines: > > * * If iMAX <> cMAX Then > * * * * strMSG = "Only " & iMAx & " of " & cMAX & " radio buttons checked!" > * * * * If MsgBox(strMSG,vbQuestion+vbOKCancel,"Continue?") = vbCancel Then > Exit Sub > * * End If > * *'* > * * Set objFSO = CreateObject("Scripting.FileSystemObject") > * * For intDIC = 1 To UBound(arrDIC) > * * * * strCTF = arrDIC(intDIC) & ".txt" > * * * * Set objCTF = objFSO.CreateTextFile("~" & strCTF,True) > * * * * * * objCTF.Write arrCTF(intDIC) > * * * * Set objCTF = Nothing > * * * * s = s & "<li>" & strCTF & " : " & Replace(arrCTF(intDIC),vbCrLf," ") > & vbCrLf > * * Next > > Watch for word-wrap. final script i am working on the name field with be dynamically populated from WMI and therefore i cannot use object & i as a array building option... |
| | #9 (permalink) |
| Guest | Re: vbscript and HTA help So the body could be something like this as an example <body> <form name="form1"> <table border="1" width="300"> <tr> <td>a could be anything</td> </tr> <tr> <td> <input type="radio" name="a could be anything" value="Disable">Disable <input type="radio" name="a could be anything" value="Automatic">Automatic <input type="radio" name="a could be anything" value="Manual">Manual </td> </tr> <tr> <td>b could be anything</td> </tr> <tr> <td> <input type="radio" name="b could be anything" value="Disable">Disable <input type="radio" name="b could be anything" value="Automatic">Automatic <input type="radio" name="b could be anything" value="Manual">Manual </td> </tr> <tr> <td>c could be anything</td> </tr> <tr> <td> <input type="radio" name="c could be anything" value="Disable">Disable <input type="radio" name="c could be anything" value="Automatic">Automatic <input type="radio" name="c could be anything" value="Manual">Manual </td> </tr> <tr> <td>d could be anything</td> </tr> <tr> <td> <input type="radio" name="d could be anything" value="Disable">Disable <input type="radio" name="d could be anything" value="Automatic">Automatic <input type="radio" name="d could be anything" value="Manual">Manual </td> </tr> <tr> <td>e could be anything</td> </tr> <tr> <td> <input type="radio" name="e could be anything" value="Disable">Disable <input type="radio" name="e could be anything" value="Automatic">Automatic <input type="radio" name="e could be anything" value="Manual">Manual </td> </tr> <tr> <td>f could be anything</td> </tr> <tr> <td> <input type="radio" name="f could be anything" value="Disable">Disable <input type="radio" name="f could be anything" value="Automatic">Automatic <input type="radio" name="f could be anything" value="Manual">Manual </td> </tr> </table> <br> <input type="button" value="Submit" onclick="Radios()"> <input type="reset" value="Reset" > </form> |
| | #10 (permalink) |
| Guest | Re: vbscript and HTA help "Daz" <darren.blackley@xxxxxx> wrote in message news:8da8394b-7597-4b91-b64c-41d4a506d3d6@xxxxxx On May 29, 5:43 am, "McKirahan" <N...@xxxxxx> wrote: Quote: > "Daz" <darren.black...@xxxxxx> wrote in message > > news:924ce5de-fac5-4157-8e20-eec9b1af3666@xxxxxx > On May 27, 5:41 am, "McKirahan" <N...@xxxxxx> wrote: > Quote: > > "Daz" <darren.black...@xxxxxx> wrote in message > [snip] > Quote: > > Just 1 final question... how do i remove the need for all fields to > > have an option checked? Quote: > Replace these lines: Quote: > with these lines: Quote: > Ok the one thing this edit doesn't address is that fact that in the > final script i am working on the name field with be dynamically > populated from WMI and therefore i cannot use object & i as a array > building option... Perhaps if you posted your code I might be able to see what you want to "dynamically populate" the form with. I can't read your mind. |
| New to VBscript, Help please! | VB Script | |||
| CSS and VBscript | VB Script | |||
| Where is VBscript now? | VB Script | |||
| VBscript Help | VB Script | |||
| How to do No hang up VBScript (nohup for VBScript) | VB Script | |||
