Vista - help with formatting
Old 06-04-2008   #1 (permalink)
simalt
Could someone help me with this please. This puts out a list of
mailboxes from each server to a text file with tabs. Is it possible
to change this to comma delimited. Thanks.
'To list the largest mailbox on each server
Option Explicit
'* Purpose: Display each Exchange_Mailbox found for Exchange server,
'* and show selected, formated properties on the
'* Exchange_Mailbox objects
'* Change: cComputerName [string] the computer to access (netbios
name)
'* Output: Displays the name of each Exchange_Mailbox and
properties
'* based on http://msdn.microsoft.com/library/de...ary/en-us/e2k3...
wmiref_cl_Exchange_Mailbox.asp
'* works only with Exchange 2003 servers
Const cServerNames = "c:\Scripts\serverNames.txt"
Const cWinMgmts = "winmgmts:{impersonationLevel=impersonate}!\
Const cWMINameSpace = "root/MicrosoftExchangeV2"
Const cWMIInstance = "Exchange_Mailbox"
Const cBOX = "OctelVMD,SMTP,System
Attendant,SystemMailbox"
Const cDBG = False '= Debug flag (Ture/False)
Dim i, j, k
Dim arrBOX
arrBOX = Split(cBOX,",")
Dim booBOX
Dim intBOX
Dim strBOX
Dim intLEN
intLEN = 0
Dim arrOUT()
Dim intOUT
intOUT = 0
Dim strOUT
Dim strTMP
Dim strTXT
Dim strWinMgmts ' Connection string for WMI
Dim objWMIExchange ' Exchange Namespace WMI object
Dim listExchange_Mailboxes ' Exchange_Mailbox collection
Dim objExchange_Mailbox ' A single Exchange_Mailbox WMI object
Dim cComputerName
Dim fileSys
Set fileSys = CreateObject("Scripting.FileSystemObject")
Dim fileToRead
Set fileToRead = fileSys.OpenTextFile(cServerNames,1)
'* Create the object string, indicating WMI (winmgmts), using the
'* current user credentials (impersonationLevel=impersonate),
'* on the computer specified in the constant cComputerName, and
'* using the CIM namespace for the Exchange provider.
'- Do While fileToRead.AtEndOfStream <> True
Do While Not fileToRead.AtEndOfStream
cComputerName = fileToRead.ReadLine
If cComputerName = "" Then Exit Do
WScript.Echo "Server name is: " & cComputerName
strWinMgmts = cWinMgmts & cComputerName & "\" & cWMINameSpace
On Error Resume Next
Set objWMIExchange = GetObject(strWinMgmts)
'* Verify connection to the WMI namespace on the server
If Err.Number <> 0 Then
WScript.Echo "ERROR: Unable to connect to the WMI
namespace."
WScript.Echo Err.Description & " (" & Hex(Err.Number) &
WScript.Quit 1
End If
On Error GoTo 0
'* The Resources that currently exist appear as a list of
'* Exchange_Mailbox instances in the Exchange namespace.
Set listExchange_Mailboxes =
objWMIExchange.InstancesOf(cWMIInstance)
'* Were any Exchange_Mailbox Instances returned?
If listExchange_Mailboxes.count <= 0 Then
WScript.Echo "WARNING: No Exchange_Mailbox instances were
returned."
WScript.Quit 1
End If
WScript.Echo "Running mailbox size report for all stores on
server " & cComputerName & vbCrLf
'* Iterate through the list of Exchange_Mailbox objects.
If cDBG Then WScript.Echo "Loop!"
For Each objExchange_Mailbox in listExchange_Mailboxes
If cDBG Then WScript.Echo ".LegacyDN = " _
& objExchange_Mailbox.LegacyDN _
& vbTab & ".MailboxDisplayName = "
_
objExchange_Mailbox.MailboxDisplayName _
& vbTab & ".Size = " _
& objExchange_Mailbox.Size _
& vbTab & ".TotalItems = " _
& objExchange_Mailbox.TotalItems
strTMP = objExchange_Mailbox.LegacyDN
strTMP = Mid(strTMP,InStrRev(strTMP,"CN=")+3)
strTMP = objExchange_Mailbox.MailboxDisplayName & " (" &
strTMP & ")"
If intLEN < Len(strTMP) Then intLEN = Len(strTMP)
ReDim Preserve arrOUT(intOUT)
arrOUT(intOUT) = (10^10-objExchange_Mailbox.Size) _
& vbtab & strTMP _
& vbtab & FormatNumber(objExchange_Mailbox.Size,0) _
& vbtab & FormatNumber(objExchange_Mailbox.TotalItems,
0)
If cDBG Then WScript.Echo intOUT & ". " & arrOUT(intOUT)
intOUT = intOUT + 1
Next
Set objWMIExchange = Nothing
'* Sort by objExchange_Mailbox.Size
If cDBG Then WScript.Echo "Sort!"
For i = UBound(arrOUT) - 1 To 0 Step -1
For j = 0 To i
If arrOUT(j) > arrOUT(j+1) Then
k = arrOUT(j+1)
arrOUT(j+1) = arrOUT(j)
arrOUT(j) = k
End If
Next
Next
'* List by objExchange_Mailbox.Size
If cDBG Then WScript.Echo "List!"
strTXT = "Mailbox" & Space(intLEN-7) _
& " Size" _
& " Items"
WScript.Echo strTXT & vbCrLf & String(intLEN+12+10,"-")
For intOUT = 0 To UBound(arrOUT)
strOUT = Split(arrOUT(intOUT),vbTab)
booBOX = True
For intBOX = 0 To UBound(arrBOX)
strBOX = arrBOX(intBOX)
If InStr(strOUT(1),strBOX) > 0 Then booBOX = False
Next
If booBOX Then
strTXT = strOUT(1) & Space(intLEN-Len(strOUT(1))) _
& Space(12-Len(strOUT(2))) & strOUT(2) _
& Space(12-Len(strOUT(2))) & strOUT(3)
WScript.Echo strTXT
End If
Next
'* Reinitialize
Erase arrOUT
intOUT = 0
Loop
'MsgBox "Done!",vbInformation,WScript.ScriptName
Old 06-04-2008   #2 (permalink)
Richard Mueller [MVP]
Re: help with formatting
In every statement you can replace each instance of
vbTab
with
For example change this:
& vbTab & ".MailboxDisplayName = " _
& objExchange_Mailbox.MailboxDisplayName _
To something like this:
& "," & ".MailboxDisplayName = " _
& "," & ".Size = " _
& "," & ".TotalItems = " _
But in addition, if the aim is a comma delimied file you can read into a
spreadsheet program, you probably don't want the values preceeded by strings
like ".Size = ". Instead you may want to format just the values. For example
the following makes more sense to me:
If cDBG Then WScript.Echo objExchange_Mailbox.LegacyDN _
& "," & objExchange_Mailbox.MailboxDisplayName _
& "," & objExchange_Mailbox.Size _
& "," & objExchange_Mailbox.TotalItems
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
"simalt" <simalt@xxxxxx> wrote in message
news:b9266239-f31f-4ca9-b0e3-821f654e8592@xxxxxx
> Option Explicit
> name)
> properties
> '* based on
> Dim i, j, k
> Dim arrBOX
> Dim booBOX
> Dim intBOX
> Dim strBOX
> Dim intLEN
> intLEN = 0
> Dim arrOUT()
> Dim intOUT
> intOUT = 0
> Dim strOUT
> Dim strTMP
> Dim strTXT
> Dim cComputerName
> Dim fileSys
> Dim fileToRead
> namespace."
> WScript.Quit 1
> End If
> On Error GoTo 0
> returned."
> WScript.Quit 1
> End If
> _
> strTMP & ")"
> & vbtab & strTMP _
> 0)
> intOUT = intOUT + 1
> Next
> For j = 0 To i
> k = arrOUT(j+1)
> arrOUT(j) = k
> End If
> Next
> Next
> & " Size" _
> & " Items"
> booBOX = True
> Next
> If booBOX Then
> WScript.Echo strTXT
> End If
> Next
> '* Reinitialize
> Erase arrOUT
> intOUT = 0
> Loop
Old 06-04-2008   #3 (permalink)
simalt
On Jun 4, 2:39*pm, "Richard Mueller [MVP]" <rlmueller-
nos...@xxxxxx> wrote:
> * * vbTab
> with
> * * If cDBG Then WScript.Echo ".LegacyDN = " _
> * * * * & objExchange_Mailbox.LegacyDN _
> * * * * & vbTab & ".MailboxDisplayName = " _
> * * * * & objExchange_Mailbox.MailboxDisplayName _
> * * * * & vbTab & ".Size = " _
> * * * * & objExchange_Mailbox.Size _
> * * * * & vbTab & ".TotalItems = " _
> * * * * & objExchange_Mailbox.TotalItems
> * * * * & "," & ".MailboxDisplayName = " _
> * * * * & "," & ".Size = " _
> * * * * & "," & ".TotalItems = " _
> * * If cDBG Then WScript.Echo objExchange_Mailbox.LegacyDN _
> * * * * & "," & objExchange_Mailbox.MailboxDisplayName _
> * * * * & "," & objExchange_Mailbox.Size _
> * * * * & "," & objExchange_Mailbox.TotalItems
> Richard Mueller
> Hilltop Lab -http://www.rlmueller.net
> "simalt" <sim...@xxxxxx> wrote in message
Quote:
> > Could someone help me with this please. *This puts out a list of
> > mailboxes from each server to a text file with tabs. *Is it possible
> > to change this to comma delimited. *Thanks.
Quote:
> > *Option Explicit
> > '* Purpose: *Display each Exchange_Mailbox found for Exchange server,
> > '* * * * * * and show selected, formated properties on the
> > '* * * * * * Exchange_Mailbox objects
> > '* Change: * cComputerName [string] the computer to access (netbios
> > name)
> > '* Output: * Displays the name of each Exchange_Mailbox and
> > properties
> > '* based on
> >http://msdn.microsoft.com/library/de...ary/en-us/e2k3....
> > * *Const cServerNames *= "c:\Scripts\serverNames.txt"
> > * *Const cWinMgmts * * = "winmgmts:{impersonationLevel=impersonate}!\
> > * *Const cWMINameSpace = "root/MicrosoftExchangeV2"
> > * *Const cWMIInstance *= "Exchange_Mailbox"
> > * *Const cBOX * * * * *= "OctelVMD,SMTP,System
> > * *Const cDBG * * * * *= False *'= Debug flag (Ture/False)
> > * *Dim i, j, k
> > * *Dim arrBOX
> > * * * *arrBOX = Split(cBOX,",")
> > * *Dim booBOX
> > * *Dim intBOX
> > * *Dim strBOX
> > * *Dim intLEN
> > * * * *intLEN = 0
> > * *Dim arrOUT()
> > * *Dim intOUT
> > * * * *intOUT = 0
> > * *Dim strOUT
> > * *Dim strTMP
> > * *Dim strTXT
> > * *Dim strWinMgmts * * * * * *' Connection string for WMI
> > * *Dim objWMIExchange * * * * ' Exchange Namespace WMI object
> > * *Dim listExchange_Mailboxes ' Exchange_Mailbox collection
> > * *Dim objExchange_Mailbox * *' A single Exchange_Mailbox WMI object
> > * *Dim cComputerName
> > * *Dim fileSys
> > * *Set fileSys = CreateObject("Scripting.FileSystemObject")
> > * *Dim fileToRead
> > * *Set fileToRead = fileSys.OpenTextFile(cServerNames,1)
> > * '* *Create the object string, indicating WMI (winmgmts), using the
> > * '* *current user credentials (impersonationLevel=impersonate),
> > * '* *on the computer specified in the constant cComputerName, and
> > * '* *using the CIM namespace for the Exchange provider.
> > '- *Do While fileToRead.AtEndOfStream <> True
> > * *Do While Not fileToRead.AtEndOfStream
> > * * * *cComputerName = fileToRead.ReadLine
> > * * * *If cComputerName = "" Then Exit Do
> > * * * *strWinMgmts = cWinMgmts & cComputerName & "\" & cWMINameSpace
> > * * * *On Error Resume Next
> > * * * *Set objWMIExchange = GetObject(strWinMgmts)
> > * * * '* Verify connection to the WMI namespace on the server
> > * * * *If Err.Number <> 0 Then
> > * * * * * *WScript.Echo "ERROR: Unable to connect to the WMI
> > namespace."
> > * * * * * *WScript.Echo Err.Description & " (" & Hex(Err.Number) &
> > * * * * * *WScript.Quit 1
> > * * * *End If
> > * * * *On Error GoTo 0
> > * * * '* *The Resources that currently exist appear as a list of
> > * * * '* *Exchange_Mailbox instances in the Exchange namespace.
> > * * * *Set listExchange_Mailboxes =
> > * * * '* *Were any Exchange_Mailbox Instances returned?
> > * * * *If listExchange_Mailboxes.count <= 0 Then
> > * * * * * *WScript.Echo "WARNING: No Exchange_Mailbox instances were
> > returned."
> > * * * *End If
> > * * * *WScript.Echo "Running mailbox size report for all stores on
Quote:
> > * * * '* Iterate through the list of Exchange_Mailbox objects.
Quote:
> > * * * *If cDBG Then WScript.Echo "Loop!"
> > * * * *For Each objExchange_Mailbox in listExchange_Mailboxes
> > * * * * * *If cDBG Then WScript.Echo ".LegacyDN = " _
> > * * * * * * * * * * * * * * * * * *&objExchange_Mailbox.LegacyDN _
> > * * * * * * * * * * * * * * * * * *&vbTab & ".MailboxDisplayName = "
> > _
> > * * * * * * * * * * * * * * * * * *&vbTab & ".Size = " _
> > * * * * * * * * * * * * * * * * * *&objExchange_Mailbox.Size _
> > * * * * * * * * * * * * * * * * * *&vbTab & ".TotalItems = " _
> > * * * * * * * * * * * * * * * * * *&objExchange_Mailbox.TotalItems
> > * * * * * *strTMP = objExchange_Mailbox.LegacyDN
> > * * * * * *strTMP = Mid(strTMP,InStrRev(strTMP,"CN=")+3)
> > * * * * * *strTMP = objExchange_Mailbox.MailboxDisplayName& " (" &
> > strTMP & ")"
> > * * * * * *If intLEN < Len(strTMP) Then intLEN = Len(strTMP)
> > * * * * * *ReDim Preserve arrOUT(intOUT)
> > * * * * * *arrOUT(intOUT) = (10^10-objExchange_Mailbox.Size) _
> > * * * * * * * *& vbtab & strTMP _
> > * * * * * * * *& vbtab & FormatNumber(objExchange_Mailbox.Size,0) _
> > * * * * * * * *& vbtab & FormatNumber(objExchange_Mailbox.TotalItems,
> > 0)
> > * * * * * *If cDBG Then WScript.Echo intOUT & ". " & arrOUT(intOUT)
> > * * * * * *intOUT = intOUT + 1
> > * * * *Next
> > * * * *Set objWMIExchange = Nothing
> > * * * '* *Sort by objExchange_Mailbox.Size
Quote:
> > * * * *If cDBG Then WScript.Echo "Sort!"
> > * * * *For i = UBound(arrOUT) - 1 To 0 Step -1
> > * * * * * *For j = 0 To i
> > * * * * * * * *If arrOUT(j) > arrOUT(j+1) Then
> > * * * * * * * * * *k = arrOUT(j+1)
> > * * * * * * * * * *arrOUT(j+1) = arrOUT(j)
> > * * * * * * * * * *arrOUT(j) = k
> > * * * * * * * *End If
> > * * * * * *Next
> > * * * *Next
> > * * * '* *List by objExchange_Mailbox.Size
> > * * * *If cDBG Then WScript.Echo "List!"
> > * * * *strTXT = "Mailbox" & Space(intLEN-7) _
> > * * * * * * * & " * * * *Size" _
> > * * * * * * * & " * * Items"
> > * * * *WScript.Echo strTXT & vbCrLf & String(intLEN+12+10,"-")
> > * * * *For intOUT = 0 To UBound(arrOUT)
> > * * * * * *strOUT = Split(arrOUT(intOUT),vbTab)
> > * * * * * *booBOX = True
> > * * * * * *For intBOX = 0 To UBound(arrBOX)
> > * * * * * * * *strBOX = arrBOX(intBOX)
> > * * * * * * * *If InStr(strOUT(1),strBOX) > 0 Then booBOX = False
> > * * * * * *Next
> > * * * * * *If booBOX Then
> > * * * * * * * strTXT = strOUT(1) & Space(intLEN-Len(strOUT(1))) _
> > * * * * * * * * * * *& Space(12-Len(strOUT(2))) & strOUT(2) _
> > * * * * * * * * * * *& Space(12-Len(strOUT(2))) & strOUT(3)
> > * * * * * * * *WScript.Echo strTXT
> > * * * * * *End If
> > * * * *Next
> > * * * '* *Reinitialize
> > * * * *Erase arrOUT
> > * * * *intOUT = 0
> > * *Loop
> > * *'MsgBox "Done!",vbInformation,WScript.ScriptName- Hide quoted text -
> - Show quoted text -
Thanks. I tried it but still does not quite produce a comma ordered
list.
Need Formatting Help!!!! General Discussion
Formatting HD General Discussion
formatting Vista General
Formatting Vista installation & setup
Re: Formatting Bug PowerShell
