Vista - Need help on treeview
Old 06-10-2008   #1 (permalink)
Boein
I want to use a treeview object in my application but don't know how to
start. Can somebody show me how to use it or give some examples I can work
on.
Thanks
Boein
Old 07-18-2008   #2 (permalink)
Bishop
RE: Need help on treeview
here is a sample VB-Script that shows a custom Dialog (including a Listbox)
with a Excel macro.
http://www.scriptbox.at.tt/index.php...el%20Makro.vbs
I think you can also use a treeview!
"Boein" wrote:
Quote:
> Hi,
> on.
> Thanks
> Boein
Explorer treeview +/- Vista General
