| | VB scripting help Hello all, I am working on part of a VB logon script. This script will have to run when the user logs in and I think I got it to were it will read a text file of all computers (44) from a text then the part that I need help with is to check to see if the computer name is in the list, if so then start the file copy process. (I got this part done too). My code isn't close to complete. ![]() Dim strComp Const ForReading = 1 Set objFSO = CreateObject("Scripting.FileSystemObject") Set objTextFile = objFSO.OpenTextFile _ ("c:\scripts\servers.txt", ForReading) strText = objTextFile.ReadAll objTextFile.Close arrComputers = Split(strText, vbCrLf) For Each strComputer in arrComputers Set FSO =CreateObject("scripting.FileSystemObject") FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" Next -- |
| | Re: VB scripting help David Rodriguez wrote: Quote: > I am working on part of a VB logon script. This script will have to run > when the user logs in and I think I got it to were it will read a text > file > of all computers (44) from a text then the part that I need help with is > to > check to see if the computer name is in the list, if so then start the > file > copy process. (I got this part done too). > > My code isn't close to complete. ![]() > > Dim strComp > > Const ForReading = 1 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.OpenTextFile _ > ("c:\scripts\servers.txt", ForReading) > > strText = objTextFile.ReadAll > objTextFile.Close > > arrComputers = Split(strText, vbCrLf) > > For Each strComputer in arrComputers > > Set FSO =CreateObject("scripting.FileSystemObject") > FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > > Next > -- > object. Assuming your text file has the NetBIOS names of computers, one per line, you could use code similar to: ============ Const ForReading = 1 Set objFSO = CreateObject("Scripting.FileSystemObject") Set objTextFile = objFSO.OpenTextFile _ ("c:\scripts\servers.txt", ForReading) strText = objTextFile.ReadAll objTextFile.Close arrComputers = Split(strText, vbCrLf) Set objNetwork = CreateObject("Wscript.Network") strLocalComputer = objNetwork.ComputerName For Each strComputer in arrComputers If (LCase(strComputer) = LCase(strLocalComputer)) Then objFSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" Exit For End If Next ======= No need to bind to objFSO a second time in the "For Each" loop. I used the LCase function to make the comparison case insensitive. I exit the "For Each" loop after the copy since there is no point considering other names. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: VB scripting help Sorry for bugging so soon, I have one question about the script, would I be able to change the location of the text file? Like from... ("c:\scripts\servers.txt", ForReading) to .. ("\\svr1\netlogon\SEP_Install\servers.txt", ForReading) I do appreciate you helping me with this. -- "Richard Mueller [MVP]" wrote: Quote: > David Rodriguez wrote: > Quote: > > I am working on part of a VB logon script. This script will have to run > > when the user logs in and I think I got it to were it will read a text > > file > > of all computers (44) from a text then the part that I need help with is > > to > > check to see if the computer name is in the list, if so then start the > > file > > copy process. (I got this part done too). > > > > My code isn't close to complete. ![]() > > > > Dim strComp > > > > Const ForReading = 1 > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objTextFile = objFSO.OpenTextFile _ > > ("c:\scripts\servers.txt", ForReading) > > > > strText = objTextFile.ReadAll > > objTextFile.Close > > > > arrComputers = Split(strText, vbCrLf) > > > > For Each strComputer in arrComputers > > > > Set FSO =CreateObject("scripting.FileSystemObject") > > FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > > > > Next > > -- > > > You can retrieve the NetBIOS name of the local computer from the wshNetwork > object. Assuming your text file has the NetBIOS names of computers, one per > line, you could use code similar to: > ============ > Const ForReading = 1 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.OpenTextFile _ > ("c:\scripts\servers.txt", ForReading) > > strText = objTextFile.ReadAll > objTextFile.Close > arrComputers = Split(strText, vbCrLf) > > Set objNetwork = CreateObject("Wscript.Network") > strLocalComputer = objNetwork.ComputerName > > For Each strComputer in arrComputers > If (LCase(strComputer) = LCase(strLocalComputer)) Then > objFSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > Exit For > End If > Next > ======= > No need to bind to objFSO a second time in the "For Each" loop. I used the > LCase function to make the comparison case insensitive. I exit the "For > Each" loop after the copy since there is no point considering other names. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| | Re: VB scripting help I was able to test it with the UNC path and it worked just fine. Thank you, -- David Rodriguez C & D Computer Consulting www.networking-help.biz 602-578-4516 "David Rodriguez" wrote: Quote: > Sorry for bugging so soon, I have one question about the script, would I be > able to change the location of the text file? > > Like from... > ("c:\scripts\servers.txt", ForReading) > > to .. > ("\\svr1\netlogon\SEP_Install\servers.txt", ForReading) > > I do appreciate you helping me with this. > > -- > > "Richard Mueller [MVP]" wrote: > Quote: > > David Rodriguez wrote: > > Quote: > > > I am working on part of a VB logon script. This script will have to run > > > when the user logs in and I think I got it to were it will read a text > > > file > > > of all computers (44) from a text then the part that I need help with is > > > to > > > check to see if the computer name is in the list, if so then start the > > > file > > > copy process. (I got this part done too). > > > > > > My code isn't close to complete. ![]() > > > > > > Dim strComp > > > > > > Const ForReading = 1 > > > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > > Set objTextFile = objFSO.OpenTextFile _ > > > ("c:\scripts\servers.txt", ForReading) > > > > > > strText = objTextFile.ReadAll > > > objTextFile.Close > > > > > > arrComputers = Split(strText, vbCrLf) > > > > > > For Each strComputer in arrComputers > > > > > > Set FSO =CreateObject("scripting.FileSystemObject") > > > FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > > > > > > Next > > > -- > > > > > You can retrieve the NetBIOS name of the local computer from the wshNetwork > > object. Assuming your text file has the NetBIOS names of computers, one per > > line, you could use code similar to: > > ============ > > Const ForReading = 1 > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objTextFile = objFSO.OpenTextFile _ > > ("c:\scripts\servers.txt", ForReading) > > > > strText = objTextFile.ReadAll > > objTextFile.Close > > arrComputers = Split(strText, vbCrLf) > > > > Set objNetwork = CreateObject("Wscript.Network") > > strLocalComputer = objNetwork.ComputerName > > > > For Each strComputer in arrComputers > > If (LCase(strComputer) = LCase(strLocalComputer)) Then > > objFSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > > Exit For > > End If > > Next > > ======= > > No need to bind to objFSO a second time in the "For Each" loop. I used the > > LCase function to make the comparison case insensitive. I exit the "For > > Each" loop after the copy since there is no point considering other names. > > > > -- > > Richard Mueller > > MVP Directory Services > > Hilltop Lab - http://www.rlmueller.net > > -- > > > > > > |
| | Re: VB scripting help Hey Richard, How would I add this email portion to this script that you helped me with? Just so you know I am running the script 2 times, because there are 2 SEP servers that will handle different workstations. The email portion is just to confirm that the workstation is ready for phase 2. Const ForReading = 1 Set objFSO = CreateObject("Scripting.FileSystemObject") Set objTextFile = objFSO.OpenTextFile _ ("\\svr2\NETLOGON\RemoteComp.txt", ForReading) strText = objTextFile.ReadAll objTextFile.Close arrComputers = Split(strText, vbCrLf) Set objNetwork = CreateObject("Wscript.Network") strLocalComputer = objNetwork.ComputerName For Each strComputer in arrComputers If (LCase(strComputer) = LCase(strLocalComputer)) Then objFSO.CopyFolder "\\SVR1\netlogon\Install\SEP" ,"c:\SEP_Install" Exit For End If Next Const ForReading = 1 Set objFSO = CreateObject("Scripting.FileSystemObject") Set objTextFile = objFSO.OpenTextFile _ ("\\svr2\NETLOGON\HoustonComp.txt", ForReading) strText = objTextFile.ReadAll objTextFile.Close arrComputers = Split(strText, vbCrLf) Set objNetwork = CreateObject("Wscript.Network") strLocalComputer = objNetwork.ComputerName For Each strComputer in arrComputers If (LCase(strComputer) = LCase(strLocalComputer)) Then objFSO.CopyFolder "\\SVR2\netlogon\Install\SEP" ,"c:\SEP_Install" Exit For End If Next Email portion that I would like added to the script.. Set objNet = CreateObject("WScript.Network") strLocalComputer = objNet.ComputerName strTime = time strDate = date schema = "http://schemas.microsoft.com/cdo/configuration/" Set objEmail = CreateObject("CDO.Message") With objEmail ..From = "SEP_Auto@xxxxxx" ..To = "david.rodriguez@xxxxxx" ..Subject = "Workstation " & strLocalComputer & " Has recieved the SEP_Install files." ..Textbody = "Workstation " & strLocalComputer & " Have successfully recieved the install files and is ready for Phase2 deployment. The current time is " & strTime & " " & strDate With .Configuration.Fields ..Item (schema & "sendusing") = 2 ..Item (schema & "smtpserver") = "relay.123.com" ..Item (schema & "smtpserverport") = 25 ..Item (schema & "smtpauthenticate") = cdoBasic ' .Item (schema & "sendusername") = "username" ' .Item (schema & "sendpassword") = "password" End With ..Configuration.Fields.Update ..Send End With Thank you for all the help. David -- "Richard Mueller [MVP]" wrote: Quote: > David Rodriguez wrote: > Quote: > > I am working on part of a VB logon script. This script will have to run > > when the user logs in and I think I got it to were it will read a text > > file > > of all computers (44) from a text then the part that I need help with is > > to > > check to see if the computer name is in the list, if so then start the > > file > > copy process. (I got this part done too). > > > > My code isn't close to complete. ![]() > > > > Dim strComp > > > > Const ForReading = 1 > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objTextFile = objFSO.OpenTextFile _ > > ("c:\scripts\servers.txt", ForReading) > > > > strText = objTextFile.ReadAll > > objTextFile.Close > > > > arrComputers = Split(strText, vbCrLf) > > > > For Each strComputer in arrComputers > > > > Set FSO =CreateObject("scripting.FileSystemObject") > > FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > > > > Next > > -- > > > You can retrieve the NetBIOS name of the local computer from the wshNetwork > object. Assuming your text file has the NetBIOS names of computers, one per > line, you could use code similar to: > ============ > Const ForReading = 1 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.OpenTextFile _ > ("c:\scripts\servers.txt", ForReading) > > strText = objTextFile.ReadAll > objTextFile.Close > arrComputers = Split(strText, vbCrLf) > > Set objNetwork = CreateObject("Wscript.Network") > strLocalComputer = objNetwork.ComputerName > > For Each strComputer in arrComputers > If (LCase(strComputer) = LCase(strLocalComputer)) Then > objFSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" > Exit For > End If > Next > ======= > No need to bind to objFSO a second time in the "For Each" loop. I used the > LCase function to make the comparison case insensitive. I exit the "For > Each" loop after the copy since there is no point considering other names. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| | #6 (permalink) |
| | Re: VB scripting help Have a look at the item "Help emailing this script", posted here a few minutes after yours. It deals with almost the same subject. "David Rodriguez" <DavidRodriguez@xxxxxx> wrote in message news:BC45FCB1-2B82-40F6-9DE8-DB7789F7E36C@xxxxxx Quote: > Hey Richard, > How would I add this email portion to this script that you helped me with? > Just so you know I am running the script 2 times, because there are 2 SEP > servers that will handle different workstations. The email portion is just > to > confirm that the workstation is ready for phase 2. > > > Const ForReading = 1 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.OpenTextFile _ > ("\\svr2\NETLOGON\RemoteComp.txt", ForReading) > > strText = objTextFile.ReadAll > objTextFile.Close > arrComputers = Split(strText, vbCrLf) > > Set objNetwork = CreateObject("Wscript.Network") > strLocalComputer = objNetwork.ComputerName > > For Each strComputer in arrComputers > If (LCase(strComputer) = LCase(strLocalComputer)) Then > objFSO.CopyFolder "\\SVR1\netlogon\Install\SEP" ,"c:\SEP_Install" > Exit For > End If > Next > > Const ForReading = 1 > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.OpenTextFile _ > ("\\svr2\NETLOGON\HoustonComp.txt", ForReading) > > strText = objTextFile.ReadAll > objTextFile.Close > arrComputers = Split(strText, vbCrLf) > > Set objNetwork = CreateObject("Wscript.Network") > strLocalComputer = objNetwork.ComputerName > > For Each strComputer in arrComputers > If (LCase(strComputer) = LCase(strLocalComputer)) Then > objFSO.CopyFolder "\\SVR2\netlogon\Install\SEP" ,"c:\SEP_Install" > Exit For > End If > Next > > Email portion that I would like added to the script.. > > Set objNet = CreateObject("WScript.Network") > strLocalComputer = objNet.ComputerName > strTime = time > strDate = date > > schema = "http://schemas.microsoft.com/cdo/configuration/" > Set objEmail = CreateObject("CDO.Message") > With objEmail > .From = "SEP_Auto@xxxxxx" > .To = "david.rodriguez@xxxxxx" > .Subject = "Workstation " & strLocalComputer & " Has recieved the > SEP_Install files." > .Textbody = "Workstation " & strLocalComputer & " Have successfully > recieved > the install files and is ready for Phase2 deployment. The current time is > " & > strTime & " " & strDate > With .Configuration.Fields > .Item (schema & "sendusing") = 2 > .Item (schema & "smtpserver") = "relay.123.com" > .Item (schema & "smtpserverport") = 25 > .Item (schema & "smtpauthenticate") = cdoBasic > ' .Item (schema & "sendusername") = "username" > ' .Item (schema & "sendpassword") = "password" > End With > .Configuration.Fields.Update > .Send > End With > > Thank you for all the help. > > David > > -- > "Richard Mueller [MVP]" wrote: > Quote: >> David Rodriguez wrote: >> Quote: >> > I am working on part of a VB logon script. This script will have to run >> > when the user logs in and I think I got it to were it will read a text >> > file >> > of all computers (44) from a text then the part that I need help with >> > is >> > to >> > check to see if the computer name is in the list, if so then start the >> > file >> > copy process. (I got this part done too). >> > >> > My code isn't close to complete. ![]() >> > >> > Dim strComp >> > >> > Const ForReading = 1 >> > >> > Set objFSO = CreateObject("Scripting.FileSystemObject") >> > Set objTextFile = objFSO.OpenTextFile _ >> > ("c:\scripts\servers.txt", ForReading) >> > >> > strText = objTextFile.ReadAll >> > objTextFile.Close >> > >> > arrComputers = Split(strText, vbCrLf) >> > >> > For Each strComputer in arrComputers >> > >> > Set FSO =CreateObject("scripting.FileSystemObject") >> > FSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" >> > >> > Next >> > -- >> > >> You can retrieve the NetBIOS name of the local computer from the >> wshNetwork >> object. Assuming your text file has the NetBIOS names of computers, one >> per >> line, you could use code similar to: >> ============ >> Const ForReading = 1 >> >> Set objFSO = CreateObject("Scripting.FileSystemObject") >> Set objTextFile = objFSO.OpenTextFile _ >> ("c:\scripts\servers.txt", ForReading) >> >> strText = objTextFile.ReadAll >> objTextFile.Close >> arrComputers = Split(strText, vbCrLf) >> >> Set objNetwork = CreateObject("Wscript.Network") >> strLocalComputer = objNetwork.ComputerName >> >> For Each strComputer in arrComputers >> If (LCase(strComputer) = LCase(strLocalComputer)) Then >> objFSO.CopyFolder "\\SVR1\D$\Install\SEP" ,"c:\SEP_Install" >> Exit For >> End If >> Next >> ======= >> No need to bind to objFSO a second time in the "For Each" loop. I used >> the >> LCase function to make the comparison case insensitive. I exit the "For >> Each" loop after the copy since there is no point considering other >> names. >> >> -- >> Richard Mueller >> MVP Directory Services >> Hilltop Lab - http://www.rlmueller.net >> -- >> >> >> |
| Registry scripting | VB Script | |||
| Re: batch scripting | VB Script | |||
| Scripting question | Vista General | |||
| UAC and scripting | Vista General | |||
| Scripting bug? | PowerShell | |||
