| | Is there a write-multi-cell-at-once function in VBS for Excel? As well known I can write into an Excel cell a certain value with in a VBS script with e.g. objWorksheet.Cells(2, 5).Value = 55 Can I write the value 55 into multiple cells at once? Imagine I want to write in all cells 2,5 .... 2,37 the value 55. Do I really have to iterate through all cells individually or is there a function like objWorksheet.multiCells((2,5),(2,37)).Value = 55 ? Tony |
| | RE: Is there a write-multi-cell-at-once function in VBS for Excel? No iteration is needed: Sub tony() Set objWorksheet = ActiveSheet objWorksheet.Range(Cells(2, 5), Cells(2, 37)).Value = 55 End Sub You only need a loop if you want individual values in individual cells, and by using arrays properly, maybe not even then. -- Gary''s Student - gsnu2007j "Tony Bansten" wrote: Quote: > As well known I can write into an Excel cell a certain value with in a VBS script with e.g. > > objWorksheet.Cells(2, 5).Value = 55 > > Can I write the value 55 into multiple cells at once? > Imagine I want to write in all cells 2,5 .... 2,37 the value 55. > Do I really have to iterate through all cells individually or is there a function like > > objWorksheet.multiCells((2,5),(2,37)).Value = 55 > > ? > > Tony > > |
| | Re: Is there a write-multi-cell-at-once function in VBS for Excel? It's probably better to fully qualify those ranges in case objWorksheet isn't the activesheet. with objWorksheet .Range(.Cells(2, 5), .Cells(2, 37)).Value = 55 end with or objWorksheet.Range("E2").resize(1,33).Value = 55 Gary''s Student wrote: Quote: > > No iteration is needed: > > Sub tony() > Set objWorksheet = ActiveSheet > objWorksheet.Range(Cells(2, 5), Cells(2, 37)).Value = 55 > End Sub > > You only need a loop if you want individual values in individual cells, and > by using arrays properly, maybe not even then. > -- > Gary''s Student - gsnu2007j > > "Tony Bansten" wrote: > Quote: > > As well known I can write into an Excel cell a certain value with in a VBS script with e.g. > > > > objWorksheet.Cells(2, 5).Value = 55 > > > > Can I write the value 55 into multiple cells at once? > > Imagine I want to write in all cells 2,5 .... 2,37 the value 55. > > Do I really have to iterate through all cells individually or is there a function like > > > > objWorksheet.multiCells((2,5),(2,37)).Value = 55 > > > > ? > > > > Tony > > > > Dave Peterson |
| VistaPro + Excel 2007- cell copy very very slow | Vista General | |||
| How to sedn data to an excel cell from another file using a vb script | VB Script | |||
| VBscript Returns wrong value from Excel Cell | VB Script | |||
| RE: Assign variable value to excel cell | VB Script | |||
| Need sample for reading value from and writing value to cell E53 from outside Excel | VB Script | |||
