| | How to get in a vbs script the sum of values of a Excel cells in a certain range? Assume I want to get the sum of values of all cells from the range "H6:H18" from an Excel Worksheet. How can I do this within vbs script? Claudia |
| | RE: How to get in a vbs script the sum of values of a Excel cells in a This will definitely work for you. Sub SumRange() Dim myRange As Range Dim cell As Range Dim rngtotal As Double Set myRange = Sheets("Sheet1").Range("H6:H18") For Each cell In myRange rngtotal = rngtotal + cell Next cell MsgBox "The Sum of Range(''H6:H18'') = " & rngtotal End Sub Hope it helps! -- Cheers, Ryan "Claudia d'Amato" wrote: Quote: > Assume I want to get the sum of values of all cells from the range "H6:H18" from an Excel Worksheet. > > How can I do this within vbs script? > > Claudia > > |
| Coloring the cells and text in Excel 7 | Microsoft Office | |||
| a little problem with .Range(.Cells(2,1),.Cells(2,49)). | VB Script | |||
| Excel / .Net: Extract a given Range into Picture or X(HT)ML? | .NET General | |||
| How to delete the content of Excel cells from VBS script? | VB Script | |||
| Can't create uint32 values outside int32 range? | PowerShell | |||
