Vista - regular expressions to replace but keep character?
Old 07-15-2008   #1 (permalink)
Nick B
Is there a way to use Replace with Regular Expressions but keep a character
in the original string? A simplified example: If we have "< a >" or "<b >"
or "< br>" within a string and we want to remove the spaces, but keep the
character, is there a way this can be done? A Regular Expression can find
the substring with something like "<\s*[a-z]\s*>" (only finds one character),
but the ReplaceWith argument appears to be static. Is there any way to keep
the character?
Thanks!,
Nick
Old 07-15-2008   #2 (permalink)
ekkehard.horner
Re: regular expressions to replace but keep character?
> the character?
You can use $<n> (<n> = number of () in pattern starting with 1) in the
replacement string:
oRE.Pattern = "(<)(\s*)(\S+)(\s*)(>)"
1 2 3 4 5
sRes = oRE.Replace( "< br >", "$1$3$5" )
Old 07-15-2008   #3 (permalink)
Nick B
That's exactly what I couldn't find. Thanks!!
> > the character?
> replacement string:
> 1 2 3 4 5
Old 07-15-2008   #4 (permalink)
Old Pedant
> 1 2 3 4 5
You can do it a lot simpler than that.
oRE.Pattern = "<\s*([^\s>]+)\s*>"
sRes = oRE.Replace( "< br >", "<$1>" )
Since you *KNOW* that you are looking for <...> and you *KNOW* you want to
retain <...>, just do *NOT* put any of that stuff in the parentheses. So now
only the non-space, non-> characters will be in parens and there's only one
"group" to be plunked into the output.
regular expressions - why are they so hard to compose and decipher? PowerShell
$Variables into Regular expressions ?! help PowerShell
New lines in regular expressions PowerShell
How to work with regular expressions PowerShell
Regular expressions PowerShell
