| | Is it possible to allow the use of the status bar via script, using a vbscript? Hi everyone, Is it possible to allow the use of the status bar via script, using a vbscript? I have a script that deletes files in the temp folders and in IE 6 it would use the status bar to display its progress. Not so with IE7 which for "security" reasons prevents the status bar from displaying anything unless the setting is changed in Tools -> Internet Options, etc. Does anyone know the registry key to modify for that? Thanks in advance for your help. Joseph |
| | Re: Is it possible to allow the use of the status bar via script, using a vbscript? Don't modify the registry directly when there is a documented solution and this is something that Microsoft would provide a documented solution for. Speaking of documentation .... guess what? "Joseph" <josephoget@xxxxxx> wrote in message news:51FC3BBA-E818-42F8-AAE5-217E247707F4@xxxxxx Quote: > Hi everyone, > > Is it possible to allow the use of the status bar via script, using a > vbscript? > > I have a script that deletes files in the temp folders and in IE 6 it > would use the status bar to display its progress. > Not so with IE7 which for "security" reasons prevents the status bar from > displaying anything unless the setting is changed in Tools -> Internet > Options, etc. > Does anyone know the registry key to modify for that? > > Thanks in advance for your help. > > Joseph > |
| | Re: Is it possible to allow the use of the status bar via script, using a vbscript? The status bar may not be the best choice, but if that's what you really want, see here: http://support.microsoft.com/kb/182569 It looks like the value is probably 2103 set to 1. With "Local Machine Lockdown" possible you actually need to set the value in 4 places if you want to be sure it's not being overridden by some other hidden setting. Where "***" = "Software\Microsoft\Windows\CurrentVersion\Internet Settings" you would want to set the following: HKLM\***\Zones\0\2103 HKCU\***\Zones\0\2103 HKLM\***\Lockdown_Zones\0\2103 HKCU\***\Lockdown_Zones\0\2103 Quote: > > Is it possible to allow the use of the status bar via script, using a > vbscript? > > I have a script that deletes files in the temp folders and in IE 6 it Quote: > use the status bar to display its progress. > Not so with IE7 which for "security" reasons prevents the status bar from > displaying anything unless the setting is changed in Tools -> Internet > Options, etc. > Does anyone know the registry key to modify for that? > > Thanks in advance for your help. > > Joseph > |
| | RE: Is it possible to allow the use of the status bar via script, usin "Joseph" wrote: Quote: > I have a script that deletes files in the temp folders and in IE 6 it would > use the status bar to display its progress. > Not so with IE7 which for "security" reasons prevents the status bar from > displaying anything unless the setting is changed in Tools -> Internet > Options, etc. Why not display the status in a <DIV> that you position right at the bottom of the window? Just above the status bar? That's easy to do. Here's a simple demo HTML page: <html><body> <div id="STATUS" style="position: absolute; width: 100%; height: 24px; bottom:0px; color: white; background-color: black;"></div> <form> <input onchange='vbscript: document.getElementById("STATUS").innerHTML = me.value' size=100> </form> </body></html> |
| | Re: Is it possible to allow the use of the status bar via script, using a vbscript? Hi Sam, You answer is beautifully cryptic thanks - You wouldn't work for MS by any chance? Anyway I have read the doc on the msdn, the problem is not there its that I have a script which relies on the status bar of a web page created at run-time, which status bar is used to display run-time info to the user. No way am I going to ask a user to go change their internet settings, too complicated, trust me. tada "Sam Hobbs" <samuel@xxxxxx_change_social_to_socal> wrote in message news:urBOE2N8IHA.4108@xxxxxx Quote: > Don't modify the registry directly when there is a documented solution and > this is something that Microsoft would provide a documented solution for. > > Speaking of documentation .... guess what? > > > "Joseph" <josephoget@xxxxxx> wrote in message > news:51FC3BBA-E818-42F8-AAE5-217E247707F4@xxxxxx Quote: >> Hi everyone, >> >> Is it possible to allow the use of the status bar via script, using a >> vbscript? >> >> I have a script that deletes files in the temp folders and in IE 6 it >> would use the status bar to display its progress. >> Not so with IE7 which for "security" reasons prevents the status bar from >> displaying anything unless the setting is changed in Tools -> Internet >> Options, etc. >> Does anyone know the registry key to modify for that? >> >> Thanks in advance for your help. >> >> Joseph >> > > |
| | #6 (permalink) |
| | Re: Is it possible to allow the use of the status bar via script, using a vbscript? Thank you Mayayana, exactly what I was looking for, I'll check this out, thank you very much for your help. Joseph "mayayana" <mayaXXyana@xxxxxx> wrote in message news:Ob6ptZO8IHA.616@xxxxxx Quote: > The status bar may not be the best choice, but if that's > what you really want, see here: > > http://support.microsoft.com/kb/182569 > > It looks like the value is probably 2103 set to 1. > With "Local Machine Lockdown" possible you actually > need to set the value in 4 places if you want to be > sure it's not being overridden by some other hidden > setting. > > Where "***" = "Software\Microsoft\Windows\CurrentVersion\Internet > Settings" > > you would want to set the following: > > HKLM\***\Zones\0\2103 > HKCU\***\Zones\0\2103 > HKLM\***\Lockdown_Zones\0\2103 > HKCU\***\Lockdown_Zones\0\2103 > > > Quote: >> >> Is it possible to allow the use of the status bar via script, using a >> vbscript? >> >> I have a script that deletes files in the temp folders and in IE 6 it Quote: >> use the status bar to display its progress. >> Not so with IE7 which for "security" reasons prevents the status bar from >> displaying anything unless the setting is changed in Tools -> Internet >> Options, etc. >> Does anyone know the registry key to modify for that? >> >> Thanks in advance for your help. >> >> Joseph >> > |
| | #7 (permalink) |
| | Re: Is it possible to allow the use of the status bar via script, usin That actually, is NOT a dumb question at all, it is quite clever in fact, I though of that yesterday and in view of security issues amongst others, your idea is probably the way ahead, Thank you for your help, much appreciated. Joseph "Old Pedant" <OldPedant@xxxxxx> wrote in message news:C109F477-02FC-4886-B4C2-1608078F890B@xxxxxx Quote: > "Joseph" wrote: > Quote: >> I have a script that deletes files in the temp folders and in IE 6 it >> would >> use the status bar to display its progress. >> Not so with IE7 which for "security" reasons prevents the status bar from >> displaying anything unless the setting is changed in Tools -> Internet >> Options, etc. > Not to ask a dumb question, but... > > Why not display the status in a <DIV> that you position right at the > bottom > of the window? Just above the status bar? > > That's easy to do. Here's a simple demo HTML page: > > <html><body> > <div id="STATUS" style="position: absolute; width: 100%; height: 24px; > bottom:0px; color: white; background-color: black;"></div> > > <form> > <input onchange='vbscript: document.getElementById("STATUS").innerHTML = > me.value' size=100> > </form> > </body></html> |
| | #8 (permalink) |
| | Re: Is it possible to allow the use of the status bar via script,using a vbscript? Joseph wrote: Quote: > Is it possible to allow the use of the status bar via script, using a > vbscript? > _READ_ statusbar can sometimes be problematical. However, you can always use a "fake" statusbar, which is not subjected to microsoft's arbitrary restrictions. I have attached an hta which shows a "fake" statusbar, made from a table tag. I looks pretty good, and you can enter anything you like into it... cheers, jw ____________________________________________________________ You got questions? WE GOT ANSWERS!!! ..(but, no guarantee the answers will be applicable to the questions) <HTML> <HEAD> <script language="vbscript"> ' --- discussion (avoiding that annoying hta "dialog bounce") --- ' this "trick" found on the vbScript ng, code by mikHar, 05Sept06 ' Normally, an hta dialog will initially be shown in its "default" ' position and size for a brief instant. Later, when it gets ' around to running your script code, it will move/resize itself ' according to your wishes. Placing the move/resize code AHEAD ' of the hta tag seems to avoid that... ' --- end of discussion ---------------------- Const wdDlg = 600, htDlg = 380 ' dialog size Const pxLeft = 100, pxTop = 100 ' positioning window.ResizeTo wdDlg,htDlg window.MoveTo pxLeft,pxTop </script> <HTA:APPLICATION ID="oHTA" APPLICATIONNAME="htaDebugDialogTemplate" WINDOWSTATE="normal" SCROLL = "no" BORDERSTYLE="normal" BORDER="thin" CAPTION="yes" MAXIMIZEBUTTON="no" MINIMIZEBUTTON="no" ICON="mru.ico" SHOWINTASKBAR="yes" SINGLEINSTANCE="yes" SYSMENU="yes" VERSION="1.0" > <TITLE> << (hta) Debug Dialog Template (with Fake StatusBar) Demo Script >> </TITLE> <SCRIPT LANGUAGE="vbScript"> <!-- ' --- description block -------------------------- ' ' Title: (hta) debug dialog with Fake StatusBar, jw 12May06 ' ' Description: A scripting graphical user interface (gui), ' appropriate for posting debugging messages or status msgs. ' Due to difficulties with posting messages to microsoft's ' IE statusbar, there is also a "fake" statusbar included... ' ' Author: mr_unreliable ' Website: none at this time (but lurks around the wsh/vbs ng's) ' ' Usage: Use at you own risk, tested on win98se... ' ' Acknowledgments: xx/xx/xx a "xxx yyy" of the vbs newsgroup ' offered up an anternative to my "brute force" approach ' to scrolling, i.e., "scrolldown". He suggested using ' "scroll into view". His approach was incorporated here ' (although so vastly modified as to probably be unrecognizable ' to xxx. ' ' --- revision history --------------------------- ' 12May06: initial attempt (working from "regular" hta dbDlg)... ' 13May06: added "working clock"... ' 20May06: added "scroll into view" option for scrolling... ' --- end of description block ------------------- Option Explicit ' --- global variables --------------------------- ' ' Dim oFSO : Set oFSO = CreateObject("Scripting.FileSystemObject") ' Dim oShell : Set oShell = CreateObject("WScript.Shell") ' Dim oDoc ' as document object Dim clkTmr ' as timer (used to update clock) Const clkTmrInt = 995 ' clock update interval (note: LESS THAN 1 SEC) ' Dim tRun ' as long (to keep track of running time) Dim iItem ' as integer (to keep track of "span" tags) Dim iMsg ' as integer (sequential number, to keep track of messages) Const bAlignWithTop = True Const bAlignWithBottom = False ' --- end of declarations and constants ---------- ' --- initialize window size & positioning ------- ' Const wdDlg = 500, htDlg = 280 ' dialog size ' do a little adjusting of my size and location... ' window.ResizeTo wdDlg,htDlg ' window.MoveTo 100,100 ' --- INITIALIZATION ROUTINE --------------------- Sub initDialog() Const sMe = "[initDialog], " ' do a little adjusting of my size and location... ' window.ResizeTo wdDlg,htDlg ' window.MoveTo 100,100 Set oDoc = window.document With oDoc ' resize text area... oDoc.getElementById("msgList").style.width = wdDlg - 25 ' htClientArea, less statusbar, logo, less button, less progbar, less... oDoc.getElementById("msgList").style.height = oDoc.body.clientHeight _ - 25 - 20 - 35 - 20 ' (and less fudge factor, but don't tell anybody)... ' MsgBox("Client Width: " & oDoc.body.clientWidth _ ' & "Client Height: " & oDoc.body.clientHeight) ' re-position the logo to lie just above the (fake) statusbar... oDoc.getElementById("logo").style.top = oDoc.body.clientHeight - 47 oDoc.getElementById("logo").style.left = oDoc.body.clientWidth - 215 ' re-position the (fake) statusbar at the bottom of the form (er, dialog)... oDoc.getElementById("etchedEdge").style.top = oDoc.body.clientHeight - 25 oDoc.getElementById("fakeStatusBarFrame").style.top = oDoc.body.clientHeight - 23 ' oDoc.getElementById("btnExit").disabled = False oDoc.getElementById("btnExit").onClick = GetRef("btnExit_Click") End With ' place a message in the main statusbar panel... oDoc.getElementByID("statusPanel1").innerText = " The ""Main"" statusbar panel text goes here " ' place the current time in the clock panel of the statusbar... oDoc.getElementByID("statusPanel2").innerText = " Time: " _ & formatDateTime(Time, vbLongTime) ' set clock timer, (used to update the clock)... ClearInterval(clkTmr) : clkTmr = setInterval("clkTimer_Event", clkTmrInt, "vbscript") tRun = 0 ' initialize the running time... iItem = 0 dbPrint sMe & "finished.. " ' hiding the dbMsgs, for now... oDoc.getElementByID("msgLabel").style.visibility = "visible" ' "hidden" oDoc.getElementByID("msgList").style.visibility = "visible" ' "hidden" End Sub ' --- SIMULATE DEBUG.PRINT ----------------------- Sub dbPrint(sMsg) ' simulates debug.print... Dim msgID ' as string ' posting messages and scrolling down (take II)... ' In this version, the posted messages are "wrapped" into "span tags", ' and given an "id" attribute containing the "message number", ' then inserted into the listing... msgID = "msg" & CStr(iMsg) oDoc.getElementById("msgList").insertAdjacentHTML "BeforeEnd", _ "<span id=""" & msgID & """ >" & sMsg & "<br></span>" ' and the current/last span tag (message) is scrolled into view... oDoc.getElementByID(msgID).scrollIntoView(bAlignWithBottom) ' also, publish the current dbMessage in the (fake) statusbar panel... oDoc.getElementByID("statusPanel1").innerText = " " & sMsg iMsg = iMsg + 1 ' bump up for next message End Sub ' ------------------------------------------------ ' --- EVENT HANDLERS ----------------------------- ' ------------------------------------------------ Sub clkTimer_Event() ' update the clock Const sMe = "[timer], " ' msgbox("timer event detected") oDoc.getElementByID("statusPanel2").innerText = " Time: " _ & formatDateTime(Time, vbLongTime) ' every to often, post a debug message, just for the entertainment value... tRun = tRun + 1 ' if ((tRun mod 10) = 0) then dbPrint sMe & "elapsed time: " & CStr(tRun) & " secs" dbPrint sMe & "elapsed time: " & CStr(tRun) & " secs" End Sub Sub btnExit_Click() Const sMe = "[btnClick], " ' MsgBox("detected Click Event") ClearInterval(clkTmr) ' stop the clock timer ' post a notification to the debug window... dbPrint "" ' space dbPrint sMe & " ..detected Exit Button Click Event " dbPrint sMe & " (this window will close in 1 sec) " ' wait-a-bit, to allow for reading the msg, ' by setting ANOTHER timer, to close this dialog window... SetTimeout "Window.Close", 1000 End Sub Sub CleanUp() ' msgbox("onUnload event detected") ClearInterval(clkTmr) End Sub //--> </SCRIPT> <style> body {font-family: ms sans serif; font-size: 10pt; font-weight: 400; color: Navy; margin-top: 4px; margin-left: 1px; margin-right: 1px; margin-bottom: 1px; height: 10px; width: 10px; border-style: none; } div {border-style: inset; border-width: 2; background-color:aliceblue; overflow:auto; text-align:left; font-family:verdana; font-size:10pt; font-weight:400; color:Navy; } textarea {font-family: verdana; font-size: 10pt; font-weight: 400; color: Navy; } button {margin-top: 7px; height: 25px; width: 100px; font-family: verdana; font-weight: 600; width: 125px; } h3 {margin-top: 3px; margin-bottom: 2px; padding-top: 0%; padding-bottom: 0%; font-family: verdana; font-size: 8pt; font-weight: 400; color: Navy; } h4 {position:absolute; top:100; left: 2; margin-top: 6px; margin-bottom: 0px; padding-top: 0%; padding-bottom: 0%; font-family: Arial; font-size: 8pt; font-weight: Normal; font-style: Italic; color: Navy; } hr {position:absolute; top:100; left: 2; margin-top: 1px; margin-bottom: 1px; } table {position:absolute; top:110; left: 1; margin-top: 1px; margin-bottom: 1px; border-style: none; border-width: 1; width: 100%; height: 20px; } td {border-style: inset; border-width: 2; font-family: verdana; font-size: 8pt; font-weight: normal; color: Navy } </style> </HEAD> <!-- this is the "mother" (a.k.a. "debug dialog") page --> <BODY onload="initDialog()" onUnload="CleanUp()" scroll='no' text='navy' bgcolor="silver" > <h3 id="msgLabel" > debugging messages... </h3> <CENTER> <!-- using "div" element (instead of textarea) for posting messages, instead of a listbox (i.e., what you would have used in vb)... --> <DIV id="msgList" > </DIV> <BUTTON id="btnExit" onclick="window.close()" >Exit</BUTTON> </CENTER> <h4 id="logo" ALIGN=RIGHT > jawar productions (all rights reserved)... </h4> <!-- using table as (fake) statusbar. (with "inset" border) --> <hr id="etchedEdge" width=99% align=center > <TABLE id="fakeStatusBarFrame" width=99% bgcolor=silver align=center ><TR> <TD id="statusPanel1" bgcolor=silver > <TD id="statusPanel2" style="width: 120px; "> Time 12:00:00 </TR></TABLE> </BODY> </HTML> |
| | #9 (permalink) |
| | Re: Floating DIV OK BUT... "Joseph" wrote: Quote: > the problem is that it flickers so much it is nearly impossible to read > what's in it. in a <DIV> it has to keep redrawing it? If so, I'm surprised that the status line doesn't flicker, too. I can think of a number of ways to try to reduce the flicker. One, of course, is to *NOT* use inverse video. Just leaving the pseudo-status bar the same color as the background should help a lot. Might help to put a <SPAN> inside the <DIV> and just change the innerHTML of the <SPAN>. Could possibly put a "throttle" on that changing, so that changes aren't displayed if they occur less than 50ms (or whatever number) after the prior displayed one. That woudn't be hard. Let's see... <script> var newStatus = ""; function updateStatus( ) { document.getElementById("STATUS").innerHTML = newStatus; setTimeout( "updateStatus( )", 100 ); } </script> And then do <body onLoad="updateStatus( )"> and finally, instead of changing the innerHTML directly, have your code simply dump the new messages into the newStatus variable. And then the timeout ensures that the display isn't updated more than once every 100ms. So if the variable is updated more often, the intermediate changes are just dropped into the old bitbucket. Is that adequate? |
| | #10 (permalink) |
| | Re: Is it possible to allow the use of the status bar via script,using a vbscript? mr_unreliable wrote: Quote: > Joseph, As has already been mentioned, using IE's > _READ_ statusbar can sometimes be problematical. > fumble-fingers, jw |
| Pure Vb script progress or status bar | VB Script | |||
| VBScript Login Script | Vista security | |||
| can i use vbscript or powershell to script with livemail desktop? | Live Mail | |||
| Problem setting Param($Status) in PS script | PowerShell | |||
| Logon Script - VBScript | Vista General | |||
