| | [ultimate geek] api's, typedef's, Forms (gui interface) -- from script hi gang, Yes, I do realize that there may be only one or two of you who might be interested in this sort of stuff. It involves: calling api's from script, creating typedefs (needed for some api calls); creating scripting gui's (called "forms" in this utility); and even inserting machine code into your script (gasp!). Yes, I know what you're thinking. Scripters shouldn't ever be doing any that sort of stuff!!! O.K. then, you can call me something other than a scripter -- but watch your mouth, this is a public forum. And, I have been doing that sort of stuff for some years with proprietary actX objects, written with the help of microsoft's (free) vb5cce (control creation edition) compiler (which ms is no longer making available). The reason I mention that little detail is that _THIS_ code has all been written in c/c++, making it all the more impressive. Back to basics - this package is called SFCmini (don't ask why) and it was found posted on Source Forge (Japan), written by "Katsumi" (no indication as to whether that is his/her first or last name?). Also, the documentation is part Japanese, and part English: http://kandk.cafe.coocan.jp/sfcmini/catid-19.html However, google will do a reasonable translation into fractured English, if you click on "translate this page". So go to google and search for "sfcmini". You will get a number of hits. Pick out a url that points to: kandk.cafe.coocan.jp/sfcmini/item... and select "translate this page". That will send you into the middle of the documentation under the control of google's translator, and you may then navigate through the rest using the left-hand menu. Google will follow you along translating as you go. If you wish to try out sfcmini, you may download the source, binaries, samples (demo code), and libraries (class code) from this page: http://sourceforge.jp/projects/sfcmini/files/ Download the "sfcmini-1.0.1.zip" file, dated 17Feb07. Unzip the file into a folder of your choosing. Then LEAVE THAT FOLDER AND ITS INCLUDED SUB-FOLDERS ALONE. The successful operation of SFCmini depends on retaining the structure that the zip file installs. Run the installation vbs script. That will register the sfcmini(i/a).dll. The sfcminii.dll is supposedly for intel systems, and the sfcminia.dll is supposedly for AMD systems. You may choose the INTEL installation (as I did) if you have an intel processor. That will get you into a morass of "DEP" (data execution prevention) errors. For some reason, even though I have admin privileges I couldn't bypass the DEP error checking. And so, I un-installed INTEL and installed the AMD version. Against all common sense, the AMD version DOES work on an intel processor (miracles never cease). If successful, you will find the following progID's in your registry: SfcMini.ClassEx SfcMini.DynaCall (obviously to call api's) SfcMini.MachineCode SfcMini.Structure (for typedefs) SfcMini.Tools You may then try running the demo scripts in the "samples" folder. One little bothersome item. There are THREE "winform.vbs" scripts. This was puzzling at first. But I eventually sorted it out. The "winform.vbs" script in the samples folder is a demo script. The "winform.vbs" script in the "lib" folder is class code (used by other demo scripts for creating "forms" a.k.a., windows). And the "winform.vbs" in the consts folder is just an enumeration of the windows system api constants used. Still in all, if it were up to me, I would have given those different entities different names. The sfcmini actX objects in question all come with source, so if you are handy with a c/c++ compiler, you can create your own binary (just in case you are a suspicious person). If you don't wish to compile-yer-own, the binaries come with the download. The "standard" version (v1.01) works for winXP and win2k. Unfortunately, it WILL NOT WORK for win98. Being partial to win98, that substantially dimmed my initial enthusiasm. If you are a Vista person, take a look at v1.05beta. Beta means it's not quite ready for "prime time" yet, but then neither is Vista itself. cheers, jw |
| | Re: api's, typedef's, Forms (gui interface) -- from script hi, Quote: > Yes, I do realize that there may be only one or two of you > who might be interested in this sort of stuff. a free pdf viewer script: http://groups.google.com/group/micro...d4a0aee?hl=fr# oops, sorry in french but I guess it's easier than japanese ;-) |
| | Re: api's, typedef's, Forms (gui interface) -- from script "omen999" <omen999z@xxxxxx> wrote in message news:08733b0e-9ae3-4e9f-b0c3-c077228ce5ba@xxxxxx Quote: > hi, > Quote: >> Yes, I do realize that there may be only one or two of you >> who might be interested in this sort of stuff. > I agree > > a free pdf viewer script: > http://groups.google.com/group/micro...d4a0aee?hl=fr# > oops, sorry in french but I guess it's easier than japanese ;-) VBScript. The rendering of graphics, like a topographic map of Purisima Creek Redwoods park (www.openspace.org/preserves/maps/pr_purisima.pdf) is much slower than with Adobe's reader, and is of lower quality, but this PDF viewer could be handy at times. -Paul Randall |
| I am not a Geek! | Chillout Room | |||
| [ann] another way to call api's from script (the PB way) | VB Script | |||
| Network Store interface service has stopped working 64b Ultimate S | Vista General | |||
| simulate continuous forms & subforms in a windows forms application | .NET General | |||
| Bad PID number, and I can't acll myself a geek.... | Vista General | |||
