Vista - cable disconnected or connected
Old 07-30-2008   #1 (permalink)
Big D
How can i determine if the LAN cable is connected or disconnected. I need to
find out the status of a LAN connection for netcards. I know its not plugged
in teh message state is media is disconnected.
Old 07-30-2008   #2 (permalink)
Tom Lavedas
Re: cable disconnected or connected
Maybe something like this will do the job (based on a MS Technet
Script Center example) ...
aStatusStr = split("0,1,Connected,3,4,5,Disconnected,?", ",")
strComputer = "."
Set oWMI = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer _
& "\root\cimv2")
Set cItems = oWMI.ExecQuery("Select * from Win32_NetworkAdapter"_
& " where AdapterTypeID = 0") ' 0 = Ethernet 802.3
For Each oItem in cItems
if Instr(oItem.NetConnectionID, "Local Area Connection") > 0 then
Wsh.Echo "Description: " & oItem.Description
Wsh.Echo "Net Connection Status: " _
& aStatusStr(oItem.NetConnectionStatus)
End if
Next
I experimented to find that the status numbers 2 and 7 mean connected
and disconnected, respectively. I don't have a reference that tells
what the other possible states are or mean. That's why I populated
the array with their numbers, instead. I also don't know what the
highest possible value is.
Tom Lavedas
http://members.cox.net/tglbatch/wsh/
Old 07-30-2008   #3 (permalink)
Alex K. Angelopoulos
I tracked down the status listings for this, Tom. For reference for anyone
who uses this, here's the current MSDN listing:
And here are the numeric codes, hex equivalents, and what they are supposed
to mean.
0 (hex &H0): Disconnected
1 (hex &H1): Connecting
2 (hex &H2): Connected
3 (hex &H3): Disconnecting
4 (hex &H4): Hardware not present
5 (hex &H5): Hardware disabled
6 (hex &H6): Hardware malfunction
7 (hex &H7): Media disconnected
8 (hex &H8): Authenticating
9 (hex &H9): Authentication succeeded
10 (hex &HA): Authentication failed
11 (hex &HB): Invalid address
12 (hex &HC): Credentials required
"Tom Lavedas" <tglbatch@xxxxxx> wrote in message
news:e3ae8251-7c47-427b-b2e9-606a6415f447@xxxxxx
>> to
>> plugged
> strComputer = "."
> & "\root\cimv2")
> End if
> Next
> Tom Lavedas
Old 07-31-2008   #4 (permalink)
Pegasus \(MVP\)
>> to
>> plugged
> strComputer = "."
> & "\root\cimv2")
> End if
> Next
> Tom Lavedas
Nice code. Using your script plus the details supplied by Alex
I found that the code failed on my laptop which uses a "Packet
Scheduler Miniport" because this pseudo-adpater does not have
the NetConnectionStatus property. The code below appears to
overcome the problem:
aStatusStr = Split("Disconnected,Connecting,Connected,Disconnecting," _
& "Hardware not present,Hardware disabled,Hardware malfunction," _
& "Media disconnected,Authenticating,Authentication succeeded," _
& "Authentication failed,Invalid address,Credentials required", ",")
Set oWMI =
GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\cimv2")
For Each oItem In cItems
If VarType(oItem.NetConnectionStatus) > 1 Then
wsh.Echo "Description: " & oItem.Description
wsh.Echo "Connection status: " & aStatusStr(oItem.NetConnectionStatus)
End If
WScript.echo
Next
Old 09-26-2008   #5 (permalink)
Ruizz
all this is right... but this doesn't work on windows 2000 (property
netConnectionStatus not availeble)
any help will be nice
Easy Transfer connects & then shows disconnected cable Vista installation & setup
Nic stat indicate disconnected cable Virtual Server
Re: On startup PC restarts and network cable connected to PC problem Vista networking & sharing
Can only get connected Wirelessly, but not with eithernet cable Vista General
Connection is offered , dial up and broadband, thru modem, when I´m actually connected by cable... Vista General
