Vista - Script to retrieve file versions
Old 07-30-2008   #1 (permalink)
tke402
hi,
I found this script on Scripting Guy. However I would like for the window to
have the results of three file versions. Here's what I have now. It shows in
three seperate windows one at a time:
strComputer = "Server1"
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colFiles = objWMIService.ExecQuery _
("Select * from CIM_Datafile Where Name =
'c:\\windows\\system32\\setup.exe'")
For Each objFile in colFiles
Wscript.Echo objFile.Version
Next
strComputer = "Server2"
Next
strComputer = "Server3"
Next
Old 07-30-2008   #2 (permalink)
mayayana
Re: Script to retrieve file versions
Did you know that you don't need WMI for that?
(Unless there's a problem using FSO across a network.
I've never tried that.)
Set FSO = CreateObject("Scripting.FileSystemObject")
S = FSO.GetFileVersion("c:\windows\system32\setup.exe")
If you want to show it all in one msgbox you can
use a variable to concatenate the values as you collect
them. Instead of using WScript.echo with each machine,
you can do something like this:
Dim sVer
sVer = sVer & strComputer & " - " & objFile.Version & vbcrlf
Next
Do the same for each machine. Then at the end
you can show one window with:
MsgBox sVer
The window will show a list like:
Server1 - 1.055
Server2 - 1.055
Server3 - 1.061
to
in
> Next
> Next
> Next
how to test a script for compatibility with different Windows Versions VB Script
Retrieve file from Recycle Bin issue General Discussion
problem passing args to script 'There is no script engine for file extenstion' VB Script
How to retrieve the latest file PowerShell
Retrieve the path of the file PowerShell
