Vista - SQL by field position - How
Old 08-01-2008   #1 (permalink)
Daron
I need to get a count on a field and I need to use the field position.
How do I do this in the SQL statement?
My code:
str_grpCnt = "SELECT Fields(" & int_Column & ") as my_Group,
Count(Fields(0)) as grp_Totals " & _
"FROM [" & str_ThisFile & "] " & _
"GROUP BY Fields(" & int_Column & ")"
I cannot use a Schema.ini. I need to use the field positon because the
incoming csv text file could have a different number of fields each
time, and I need to give the user the ability to choose which field/
column to group by. Also, the incoming field will be in various
folders.
TIA
- Daron
Old 08-02-2008   #2 (permalink)
ekkehard.horner
Re: SQL by field position - How
> My code:
> folders.
> TIA
> - Daron
(1) Use test code like this
Dim oFS : Set oFS = CreateObject( "Scripting.FileSystemObject" )
Dim sFSpec : sFSpec = oFS.GetAbsolutePathName( "<YourFile>" )
Dim oTCN : Set oTCN = CreateObject( "ADODB.Connection" )
Dim sCS : sCS = Join( Array( _
"Provider=Microsoft.Jet.OLEDB.4.0" _
, "Data Source=" & oFS.GetParentFolderName( sFSpec ) _
, "Extended Properties=""text;HDR=No;""" _
oTCN.Open sCS
Dim sSQL : sSQL = "SELECT * FROM [" & oFS.GetFileName( sFSpec ) & "]"
Dim oRS : Set oRS = oTCN.Execute( sSQL )
Dim oFld
For Each oFld In oRS.Fields
WScript.Echo oFld.Name
Next
WScript.Echo oRS( "F1" )
oRS.Close
oTCN.Close
to verify that on your system (without schema.ini definition and with
"HDR=No") the default/automatic field names really are "F1", "F2", ...
(2) Use "SELECT F<N> ... GROUP BY F<N>" accordingly
Old 08-02-2008   #3 (permalink)
Daron
On Aug 2, 6:22*pm, "ekkehard.horner" <ekkehard.hor...@xxxxxx> wrote:
Quote:
Quote:
> > My code:
> > * * * * * *"FROM [" & str_ThisFile & "] " & _
> > * * * * * *"GROUP BY Fields(" & int_Column & ")"
> > folders.
Quote:
> > TIA
Quote:
> > - Daron
> * *Dim oFS * * : Set oFS *= CreateObject( "Scripting.FileSystemObject" )
> * *Dim sFSpec *: sFSpec * = oFS.GetAbsolutePathName( "<YourFile>" )
> * *Dim oTCN * *: Set oTCN = CreateObject( "ADODB.Connection" )
> * *Dim sCS * * : sCS * * *= Join( Array( _
> * * * * * * * * * * * * * * * "Provider=Microsoft.Jet.OLEDB.4.0" _
> * * * * * * * * * * * * * * , "Data Source=" & oFS.GetParentFolderName( sFSpec ) _
> * * * * * * * * * * * * * * , "Extended Properties=""text;HDR=No;""" _
> * *oTCN.Open sCS
> * *Dim sSQL * *: sSQL * * = "SELECT * FROM [" & oFS.GetFileName( sFSpec ) & "]"
> * *Dim oRS * * : Set oRS *= oTCN.Execute( sSQL )
> * *Dim oFld
> * *For Each oFld In oRS.Fields
> * * * *WScript.Echo oFld.Name
> * *Next
> * *WScript.Echo oRS( "F1" )
> * *oRS.Close
> * *oTCN.Close
> * * *to verify that on your system (without schema.ini definition and with
> * * *"HDR=No") the default/automatic field names really are "F1","F2", ...
Thank you. I will try this on Monday when I get back.
IE8 gets the Prime position Browsers & Mail
Get the position in a DataGridView .NET General
BCC field Vista mail
Position in an array PowerShell
