Vista - SQL by column position - How (rewording)
Old 08-01-2008   #1 (permalink)
Daron
I need to get a count on a field and I need to use the column
position.
How do I do this in the SQL statement?
My code:
str_grpCnt = "SELECT Fields(" & int_Column & ") as my_Group,
Count(Fields(0)) as grp_Totals " & _
"FROM [" & str_ThisFile & "] " & _
"GROUP BY Fields(" & int_Column & ")"
I cannot use a Schema.ini. I need to use the column positon because
the incoming csv text file could have a different number of fields
each time, and I need to give the user the ability to choose which
field/column to group by. Also, the incoming file will be in a
different folders each time. (I'm using drag-n-drop)
TIA
- Daron
Old 08-01-2008   #2 (permalink)
Old Pedant
RE: SQL by column position - How (rewording)
"Daron" wrote:
Quote:
> I need to get a count on a field and I need to use the column position.
> My code:
[snip]
You can't. But...
Since you appear to be using ASP (or is it ASP.NET), you could do it in two
steps.
First, get a list of all the fields, in the form of a "dummy" recordset.
Then get the field name from that and plug it into your second query.
Example:
sql1 = "SELECT * FROM [" & str_ThisFile & "] WHERE 1=0"
Set rs1 = conn.Execute( sql1 )
fieldName = rs1.Fields(int_column).Name
sql2 = "SELECT [" & fieldName & "] AS myGroup, COUNT(*) AS myCount " _
& " FROM [" & str_ThisFile & "] " _
& " GROUP BY [" & fieldName & "]" _
& " ORDER BY 1"
Set rs2 = conn.Execute( sql2 )
Hmmm??
IE8 gets the Prime position Browsers & Mail
Is it possible in "computer" to view files from top to bottom in 1st column then same again in next column to the right etc? Vista file management
Get the position in a DataGridView .NET General
Position in an array PowerShell
