Vista - xml parsing issue
Old 08-06-2008   #1 (permalink)
Big D
xml parsing issue
I have an issue with the number of records coming back while parsing xml.
Below is sample xml file used as a configuration file. I am parsing data and
creating a new file with data needed. I have majority of parsing completed
but ran into a snag. I did not put all the code in email and rather the
snippets of the critical pieces.
If I just use a For/next statement for getting VLAN nodes the output is 100
, 200, 300. Once I get the list and move to the next For statement to get
values what happens is I end up getting the Network DeviceId for all vlans.
My expectation is the following:
1. iterate through the first VLAN which happens to be 100 first. Create VLAN
ID 100 in output file if its not created.
2. Read each network tag attribute for that VLAN and write out to file. Once
I get the values for VLAN 100 and get the info needed for two network
values, tag is closed
3. Then create vlan 200 and get its values and continue on until i am done.
What is happening:
1. When I get the vlans the For/Next statement end up getting all the vlan
Network attriubutes in the first loop. I added some debug info and when
output the NetworknodeList with first loop it tell me the count is 5 which
really should be 2. This tells me I am somehoe pulling in every network
attribute for all VLANS and not just the current one and then moving on.
Any ideas?
Set NetworknodeList = xml.selectNodes("/MyNetwork/Networks/VLAN/Network")
Set VLANNetworknodeList = xml.selectNodes("/MyNetwork/Networks/VLAN")
For h = 0 To VLANNetworknodeList.length -1
sVLANId=VLANNetworknodeList(h).Attributes.getNamedItem("Id").value
WScript.Echo " The VLAN ID is. " & sVLANId
For i = 0 To NetworknodeList.length -1
WScript.Echo "Network Node List = " & NetworknodeList.length
sDeviceId=NetworknodeList(i).Attributes.getNamedItem("DeviceId").value
sBeginRange=NetworknodeList(i).Attributes.getNamedItem("BeginRange").value
sEndRange=NetworknodeList(i).Attributes.getNamedItem("EndRange").value
Next
Next
----------XML FILE---------
<MyNetwork>
<Networks>
<VLAN Id="100">
<Network DeviceId="Router" BeginRange="1" EndRange="1"/>
<Network DeviceId="Controller" BeginRange="1" EndRange="1"/>
</VLAN>
<VLAN Id="200">
<Network DeviceId="TestDevice" BeginRange="1" EndRange="1"/>
</VLAN>
<VLAN Id="300">
<Network DeviceId="Test Device" BeginRange="1" EndRange="1"/>
</VLAN>
</MyNetwork>
Old 08-06-2008   #2 (permalink)
Old Pedant
RE: xml parsing issue
"Big D" wrote:
> <MyNetwork>
> <Networks>
> <VLAN Id="100">
> </VLAN>
> <VLAN Id="200">
> </VLAN>
> <VLAN Id="300">
> </VLAN>
> </MyNetwork>
Your XML is *ILLEGAL*.
You have a <Networks> tag but no matching </Networks>.
I'm surprised it can be parsed, at all.
Old 08-06-2008   #3 (permalink)
Old Pedant
Don't get all hung up on only using the selectNodes method.
And don't forget about "containerization". When you do use selectNodes or
getElementsByTagName or various other methods, you will *only* find
nodes/attributes/whatever that are *INSIDE* the object you are using to make
the method call!
So lon as you persist in using the root xml object to do all your
selectNodes, you *WILL* get *ALL* matching nodes. Period.
So...a simple demo. This is done with VBScript in ASP, but just strip off
the <%...%> and change Response.Write to WScript.echo and get rid of the
HTML, and it should work perfectly. (Just try it as an ASP page first.)
data = _
"<?xml version=""1.0"" encoding=""UTF-8""?>" & vbNewLine & _
"<MyNetwork>" & vbNewLine & _
" <Networks>" & vbNewLine & _
" <VLAN Id=""100"">" & vbNewLine & _
" <Network DeviceId=""Router"" BeginRange=""1"" EndRange=""1""/>" &
vbNewLine & _
" <Network DeviceId=""Controller"" BeginRange=""1"" EndRange=""1""/>" &
vbNewLine & _
" </VLAN>" & vbNewLine & _
" <VLAN Id=""200"">" & vbNewLine & _
" <Network DeviceId=""TestDevice"" BeginRange=""1"" EndRange=""1""/>" &
vbNewLine & _
vbNewLine & _
" <VLAN Id=""300"">" & vbNewLine & _
" <Network DeviceId=""Test Device"" BeginRange=""1"" EndRange=""1""/>" &
vbNewLine & _
" </Networks>" & vbNewLine & _
"</MyNetwork>"
Set dom = Server.CreateObject("msxml2.DomDocument")
dom.LoadXML data
Set vlans = dom.getElementsByTagName("VLAN")
For Each vlan In vlans
Response.Write "VLAN: id is " & vlan.Attributes.getNamedItem("Id").value
& "<ul>" & vbNewLine
Set vnets = vlan.getElementsByTagName("Network")
For Each vnet In vnets
Response.Write "<li>Network: " &
vnet.Attributes.getNamedItem("DeviceId").value & "</li>"
Next
Response.Write "</ul>" & vbNewLine
Next
Old 08-07-2008   #4 (permalink)
Big D
Re: xml parsing issue
Thanks for help. I have made changes and gotten much further. I am at a
point all data is being created and writing to xml file what I need. I
started creating the xml tags as I get the data from config file and could
use some further direction.
The output file has the following tags:
<MyNetwork>
</MyNetwork>
As I get the data I create additonal tags an add data. I could be over
complicating when creating the tags.
----------------Code------------------
Set xmlMyNetworkNode = xml.documentElement.selectSingleNode("/MyNetwork")
Set xmlNetworksNode =
xml.documentElement.selectSingleNode("/MyNetwork/Networks")
Set xmlVLANNetworksNode =
xml.documentElement.selectSingleNode("/MyNetwork/Networks/VLAN")
Set xmlNetworkNode =
xml.documentElement.selectSingleNode("/MyNetwork/Networks/VLAN/Network")
If(xmlNetworksNode Is nothing) Then
Set xmlNetworksNode=xml.createNode(1, "Networks", "")
xmlMyNetworkNode.appendChild(xmlNetworksNode)
End If
If(xmlVLANNetworksNode Is nothing) Then
Set xmlVLANNetworksNode=xml.createNode(1, "VLAN", "")
xmlNetworksNode.appendChild(xmlVLANNetworksNode)
xmlVLANNetworksNode.setAttribute "Id", sVLANId
xmlNetworksNode.appendChild xmlVLANNetworksNode
End If
if(xmlNetworkNode is nothing) Then
Set xmlNetworkNode = xml.createNode(1, "Network", "")
xmlMyNetworkNode.appendChild xmlNetworkNode
xmlNetworkNode.setAttribute "DeviceId", sDeviceId
xmlNetworkNode.setAttribute "Number", NumCounter
xmlNetworkNode.setAttribute "IPAddress", intIP
xmlNetworksNode.appendChild xmlNetworkNode
xml.save XML_DROPOFF_DIR & XML_FileName
End If
---------RESULT----------
<MyNetwork>
<Networks>
<VLAN Id="100"/>
<Network DeviceId="Router" Number="1" IPAddress="10.128.129.1"/>
<Network DeviceId="Controller" Number="1" IPAddress="10.128.129.4"/>
<Network DeviceId="TestDevice" Number="1" IPAddress="10.128.129.128"/>
<Network DeviceId="TestDevice" Number="1" IPAddress="10.128.129.129"/>
<Network DeviceId="TestDevice" Number="1" IPAddress="10.128.129.130"/>
</Networks>
</Store>
The VLAN tag and attribute get created but a closing tag never does. Thats
the first issue and second is based on sample xml in previous thread I would
expect additonal vlan tags to get created.
--------EXPECTED RESULT--------
<MyNetwork>
<Networks>
<VLAN Id="100">
</VLAN>
<VLAN Id="200">
</VLAN>
<VLAN Id="300">
</VLAN>
</Networks>
</MyNetwork>
Any help to get me pointed in the right direction is appreciated.
"Old Pedant" <OldPedant@xxxxxx> wrote in message
news:6B62E364-6771-4538-B572-68504D696C86@xxxxxx
Quote:
> What the heck...
> Here, as a VBS file:
> data = _
> vbNewLine & _
> vbNewLine & _
> vbNewLine & _
> vbNewLine & _
> vbNewLine & _
> "</MyNetwork>"
> Set dom = CreateObject("msxml2.DomDocument")
> dom.LoadXML data
> WScript.Echo "VLAN: id is " & vlan.Attributes.getNamedItem("Id").value
> WScript.Echo " Network: " &
> WScript.Echo " BeginRange: " &
> vnet.Attributes.getNamedItem("BeginRange").value
> WScript.Echo " EndRange: " &
> vnet.Attributes.getNamedItem("EndRange").value
> Next
> Next
Old 08-08-2008   #5 (permalink)
Anthony Jones
"Big D" <BigDaddy@xxxxxx> wrote in message
news:OyxLTnI%23IHA.4772@xxxxxx
> <MyNetwork>
> </MyNetwork>
> End If
> End If
> End If
> <MyNetwork>
> <Networks>
> <VLAN Id="100"/>
Quote:
> </Networks>
> </Store>
Note the VLAN tag is terminate by the /> in XML a node that would look like
this: <VLAN></VLAN> can be shortened to <VLAN />.
Quote:
> Thats
would
> <MyNetwork>
> <Networks>
> <VLAN Id="100">
> </VLAN>
> <VLAN Id="200">
Quote:
> </VLAN>
> <VLAN Id="300">
Quote:
> </VLAN>
> </Networks>
> </MyNetwork>
Is the above in a function which is called multiple times? One basic error
is you are appending the Network node to the Networks node where you should
be appending it to the VLAN node.
I guess you are calling the above code multiple times, how were you
expecting to create multiple VLAN nodes when your code selects the first
VLAN and if found doesn't create another.
Without further details about the context in which you are calling this code
its difficult to help. However here is a complete VBScript which generates
the expect XML. You can probably use the functions therein to make you code
clearer.
BTW, Functions, Functions, admins that do scripting really need to learn
the art of abstraction by functions. It would make what you are doing so
much clearer to you.
Option Explicit
'Generally useful XML functions
'(Only one needed for this example)
Function AddElem(elemParent, name)
Set AddElem = elemParent.ownerDocument.createElement(name)
elemParent.appendChild AddElem
End Function
'Specifically useful functions that hide much of the XML plumbing.
Function CreateMyNetwork()
Dim dom : Set dom = CreateObject("MSXML2.DOMDocument.3.0")
dom.loadXML("<MyNetwork />")
Set CreateMyNetwork = dom.documentElement
End Function
Function AddVLan(elemParent, id)
Set AddVLan = AddElem(elemParent, "VLAN")
AddVLan.setAttribute "id", id
End Function
Function AddNetwork(elemParent, deviceId, number, ipAddress)
Set AddNetwork = AddElem(elemParent, "Network")
AddNetwork.setAttribute "DeviceId", deviceId
AddNetwork.setAttribute "Number", number
AddNetwork.setAttribute "ipAddress", ipAddress
End Function
'The actual code to create the XML.
'Note how the expected structure is more apparent in
'the code itself.
Dim elemMyNetwork : Set elemMyNetWork = CreateMyNetwork()
Dim elemNetworks : Set elemNetworks = AddElem(elemMyNetwork, "Networks")
Dim elemVLan
Set elemVLan = AddVLan(elemNetworks, 100)
AddNetwork elemVLan, "Router", 1 , "10.128.129.1"
AddNetwork elemVLan, "Controller", 1 , "10.128.129.4"
Set elemVLan = AddVLan(elemNetworks, 200)
AddNetwork elemVLan, "TestDevice", 1 , "10.128.129.128"
AddNetwork elemVLan, "TestDevice", 1 , "10.128.129.129"
Set elemVLan = AddVLan(elemNetworks, 300)
AddNetwork elemVLan, "TestDevice", 1 , "10.128.129.130"
elemMyNetwork.ownerDocument.save "g:\temp\test.xml"
In one real world usage the creation of each VLan would be part of a for
loop and the creation of each Network would be an inner loop.
Anthony Jones - MVP ASP/ASP.NET
XML parsing issue in IE for Windows Vista Vista General
parsing xml VB Script
Parsing Web content PowerShell
PowerShell parsing issue PowerShell
Getting a web page and parsing PowerShell
