Vista - Assign a Comment
Old 08-10-2008   #1 (permalink)
Gary''s Student
Assign a Comment
I can manually assign a comment to a file (say a Word doc) by:
1. right-clicking the icon
2. selecting properties
3. selecting the Summary tab
4. typing in the comment
Can I do the same thing with a script??
Gary''s Student - gsnu2007xx
Old 08-10-2008   #2 (permalink)
Pegasus \(MVP\)
Re: Assign a Comment
"Gary''s Student" <GarysStudent@xxxxxx> wrote in message
news:99A634DF-BB32-4992-A7C1-0FE1FD6E62C1@xxxxxx
An MS Word file is in essence a binary file composed of a
mixture of text and binary code that controls how the text
should appear on the screen.
A VB Script file is a pure text file. There is no room for binary
control code in it. However, you can add comments by inserting
a single quote like so:
wscript.echo "My Name is Gary" 'Console output
Old 08-10-2008   #3 (permalink)
Gary''s Student
First, thanks for responding.
Second, let me apologize for my mis-leading query.
Here is an manual example of what I want the script to do
1. I created a script called "search.vbs"
2. the script contained the following two lines:
Set wshshell = CreateObject("Shell.Application")
wshshell.findfiles
3. I opened the folder containing the file, right-clicked the file, selected
properties, selected the Summary tab, and entered this comment:
"This script will bring up Windows Desktop Search"
If I now mouse-over the icon, the comment pops up.
If I select Comments in the Details view of the folder, the comment is
displayed.
The filetype, how I created it, or its contents are not important. I am
only concerned with the assignment of the comment. The assignment of the
comment was manual. I had to manually enter it thru Properties.
I want to know if I can assign a comment to a file with a script ( the step
3 part).
b.t.w your previous assistance with my mapped drive problem worked very well!
Old 08-10-2008   #4 (permalink)
urkec
> wshshell.findfiles
> displayed.
> 3 part).
If you have Word installed, you can use it's object model to acces
Document.BuiltInDocumentProperties collection and assign a value to it's
members.
urkec
Old 08-10-2008   #5 (permalink)
Ildhund
message news:F3E988CA-3708-4ADF-9B74-42812F79CDE9@xxxxxx
> I am only concerned with the assignment of the comment. The
> assignment of the
> ( the step 3 part).
You want dsofile: see http://support.microsoft.com/kb/224351. Chip
Pearson has some typically thorough code (much of it specifically
designed for XL workbooks) for download at
http://www.cpearson.com/excel/DocProp.aspx
I'm not sure, but I think that any file type that has a Summary tab
on its Properties sheet in Explorer can have its properties read and
written using dsofile.dll.
Noel
Old 08-10-2008   #6 (permalink)
Gary''s Student
Great idea!!
This actually works. I use DIR to get the list of files. Then I can use
the extensions to get the right application. Then I use CreateObject and Set
to get to the appropriate application's Object Model for the file in
question.
A nearly perfect blend of WSH and VBA.
I am still having some problems with some non-Office filetypes, but the end
is in sight.
Thanks again.
Gary''s Student - gsnu200799
> > wshshell.findfiles
> > displayed.
> > 3 part).
> members.
> urkec
Old 08-10-2008   #7 (permalink)
Gary''s Student
Thank you very much. i am going to experiment with this tomorrow. It looks
like I may be able to set the comment without even opening the file.
> > assignment of the
> > ( the step 3 part).
> Noel
Can't assign default program Vista General
Assign user files Vista account administration
Assign playback to WMP Vista music pictures video
How assign extension to app? Vista General
Cannot assign drive letter Vista installation & setup
