Vista - How to avoid opening a recovery storage group using CDOEXM?
Old 08-11-2008   #1 (permalink)
Claude Lachapelle
Hi!
We have a VBScript that produce storage groups reports, but actually it is
not working anymore since we create a recovery storage group and CDOEXM it is
not supporting that:
http://msdn.microsoft.com/en-us/libr...EXCHG.65).aspx
Note Exchange Server 2003 introduced recovery storage groups that can be
used when restoring individual mailboxes. However, recovery storage groups
cannot be opened using CDO for Exchange Management (CDOEXM). Attempting to
open a recovery storage group using CDOEXM will return the error 0xC1032221,
"CDOEXM is not supported on Recovery objects."
So, the question is, how to avoid opening them using CDOEXM or we will have
to use an alternative method?
Thanks.
Claude Lachapelle
Systems Administrator, MCSE
Determine Mailbox under Storage Group in Exchange Server 2003 VB Script
auto play not opening usb storage Vista General
System Recovery Left almost no storage space! Vista performance & maintenance
System Recovery Left almost no storage space! General Discussion
How Do I Avoid Opening Any and All Messages in the Preview Window! Vista mail
