| | Debugging or even running a script in MSE7 I just ran across MS Script Editor - it's been on my machine forever, I guess, but I only recently found it and am trying to write a new VBS in it instead of Notepad. But I'm having trouble getting past the first step: I installed the debugging part, but when I try F5 or any other command to run my sample script, which consists of a MsgBox and nothing else (except comments), it just switches to Run mode for a few seconds, then back to Design. I can get the MsgBox text when I run it in other ways, but not via MSE7. So is there something particular I have to do? I see something about "loading a script to a process", but I'm not sure what that means...? |
| Debugging vbs script | VB Script | |||
| Running WDEB386 and the debugging kernel of Windows 3.1 | Virtual PC | |||
| error running script | PowerShell | |||
| Script Debugging for IE7 in Vista | Vista General | |||
| Help on running a a script | PowerShell | |||
