Vista - Get a SQL Script
Old 08-13-2008   #1 (permalink)
Robert
Get a SQL Script
Is there a way to use VBScript to query a database, get a list of sp's and
then script the sp if the create date is beyond a certain date.
I think I can use openschema to get a list of sp's but i dont seem to be
able to run the sp_helptext stored procedure to get the text. So i was
wondering whether sql has an api to allow you to ask it to script an sp
remotely?
thanks
Robert
Old 08-13-2008   #2 (permalink)
Robert
RE: Get a SQL Script
OK please ignore that .. the answer is simple .. just use cmdtext to run
sp_helptext rather than adcmdstoredproc..
because sphelptext is an sp in master and not in the db concerned
Robert
"Robert" wrote:
Quote:
> Hi,
> remotely?
> thanks
> Robert
Logon Script Causing Laptops To Hang - Problems in script? VB Script
problem passing args to script 'There is no script engine for file extenstion' VB Script
Include another script, keep variables in included script? PowerShell
Script file has 'OS Handle' error when run from script PowerShell
Can you drag-n-drop a file on top of a PS script to run the script? PowerShell
