Vista - Workaround for using wildcard "*" with FileExists method
Old 08-15-2008   #1 (permalink)
Highlander
Hello all.
I want to delete all files in a folder that have a .txt extension.
This does NOT work:
Set objFSO = CreateObject("Scripting.FileSystemObject")
IF objFSO.FileExists("D:\Test\*.txt") Then
objFSO.DeleteFile("D:\Test\*.txt")
End IF
Set objFSO = nothing
This workaround does work:
Set objShell = CreateObject("WScript.Shell")
sCMD = "%COMSPEC% /c DIR /B D:\Test\*.txt"
Set objWshScriptExec = objShell.Exec(sCMD)
Set objStdOut = objWshScriptExec.StdOut
Do Until objStdOut.AtEndOfStream
sLine = objStdOut.ReadLine
IF Instr(sLine,".txt") Then
sFilepath = "D:\Test\" & sLine
objFSO.DeleteFile(sFilepath)
End IF
Loop
Set objShell = nothing
Set objWshScriptExec = nothing
Set objStdOut = nothing
My question is if there's any way to streamline and shorten my
workaround script.
Any help would be greatly appreciated. Thanks!
- Dave
Old 08-15-2008   #2 (permalink)
Tom Lavedas
Re: Workaround for using wildcard "*" with FileExists method
On Aug 15, 1:51*pm, Highlander <tron9...@xxxxxx> wrote:
Quote:
> Hello all.
> This does NOT work:
> * objFSO.DeleteFile("D:\Test\*.txt")
> End IF
> * sLine = objStdOut.ReadLine
> * IF Instr(sLine,".txt") Then
> * * sFilepath = "D:\Test\" & sLine
> * * objFSO.DeleteFile(sFilepath)
> * End IF
> Loop
> workaround script.
> - Dave
How about this ...
sCMD = "%COMSPEC% /c del D:\Test\*.txt"
objShell.Run sCMD, 0, True
or even ...
CreateObject("WScript.Shell").Run sCMD, 0, True
Tom Lavedas
Old 08-15-2008   #3 (permalink)
mayayana
Dim FSO, oFol, oFils, oFil
Set FSO = CreateObject("Scripting.FileSystemObject")
Set oFol = FSO.GetFolder("D:\Test")
Set oFils = oFol.Files
For Each oFil in oFils
If UCase(right(oFil.Name, 4)) = ".TXT" Then oFil.Delete
Next
Set oFils = Nothing
Set oFol = Nothing
Set FSO = Nothing
> End IF
> Loop
> workaround script.
> - Dave
Seeking a safe workaround for "An unknown program wants access to your computer" System Security
Windows Contacts "last name" bug, and a stange workaround Vista mail
Action Pack "upgrade" install workaround.... Vista General
Help wanted: Vistas "Windows Mail" and older SSL encryption method Vista mail
My downloaded Vista with OEM emulation workaround, passed WGA and is considered "legit" !! Vista General
