Vista - Adding Remote Users to AD via Script
Old 08-19-2008   #1 (permalink)
KDawg44
We moved from Novell a while back but still have a hundred or so
people that are not on Active Directory. I would like to write a
script that I can distribute that will do a couple of things.
The user would be connected remotely over a VPN.
1.) Add get their computers to the domain.
2.) Install SyncToy and set up pairings and run the first copy down of
data.
Is this feasible with VBScript? I'd like the user to be able to
connect and run this script in the evening so that all the SyncToy
copying and everything would be done over night. Handling a reboot
after the add to the domain would be nice but I don't have a problem
instructing the users to run the SyncToy as a second script after the
reboot.
Thanks for any help.
Kevin
Adding a hotfix from the login script VB Script
Adding attributes to Richard Muellers script VB Script
Re: Adding XP in another partition users into Vi$ta Vista security
Catastrophic failure adding users Vista General
adding certain priveledges to standard users Vista account administration
