Vista - Problems with wsDualHttpBinding in duplex scenario
Old 08-22-2008   #1 (permalink)
windows XP 32bit
I constructed a duplex WCF service with wsDualHttpBinding and netTcpBinding.When the client accessed the service with netTcpBinding,everything was OK,however,when changed the the wsDualHttpBinding,errors occured at the client side.
Unexpected Exceptions:
System.ServiceModel.AddressAlreadyInUseException: HTTP can not register URL http://+:80/Temporary_Listen_Address...-bc4734438bc8/,because another program is using the TCP port: 80
Why????
Is there anyone can help me ? Please.....
HP6980 will not Automatically do Duplex with Duplex Hardware Vista print fax & scan
HP 7310 + full feature drivers: duplex problems persist Vista hardware & devices
