Vista - Using sendkeys in a web form
Old 08-23-2008   #1 (permalink)
LuisE
I need a script to open a website, tab thru a form in that webpage and
"submit" or "enter"at the 11th field (after doing tab for 11 times). I can
get the website open and the window acticvate but in order to be able to tab
inside the page I need to "click" on it. How can I replicate the "click"
event by using SendKeys or other method of VBScript.
Here is what I have
Set wshshell=CreateObject("wscript.shell")
With CreateObject("InternetExplorer.Application")
..Navigate "http://www.hcso.tampa.fl.us/pub/default.asp?/Online/sname01"
..visible=true
End with
Thanks in adavance
Old 08-23-2008   #2 (permalink)
mr_unreliable
Re: Using sendkeys in a web form
hi LuisE,
Instead of using sendkeys, you would be much better off to use
the "document object model" of the page you are navigating to.
There are a number of example scripts posted on this newsgroup,
showing how to do that. In general, you wait for the page to
be fully loaded (by checking readystate), and then get the
document object model (window.document). The reason for getting
the DOM is that it makes it easy to parse the html. Instead of
tabbing through the controls, you can pick up a reference to the
control you want by either getting the element from its id, or
by enumerating the elements (say, input elements or button
elements) and then picking out the one you want by its caption.
Finally, when you find the element you are looking for, then
you can use the click verb to trigger the submit action.
cheers, jw
____________________________________________________________
You got questions? WE GOT ANSWERS!!! ..(but, no guarantee
the answers will be applicable to the questions)
Old 08-23-2008   #3 (permalink)
LuisE
Thanks a lot for the reply. I hope I find you reliable, not unreliable.
I'm new to VBscript as you can see, I was exploring the elementsId but I
couldn't get anything out of it. I went to see the website's source trying
to find the elements IDs but not luck.
document.getElementByID("LoginButtonID").Click()
Should I do something like For each element ........
Could you please guide me towards a more specific reference so I can take it
from there??
Thanks again.
"mr_unreliable" wrote:
Quote:
> hi LuisE,
> cheers, jw
Old 08-23-2008   #4 (permalink)
James Whitlow
"LuisE" <legonzales@xxxxxx> wrote in message
news:BBBD29C4-4E30-45A6-848E-726E2E697FFC@xxxxxx
> tab
> Here is what I have
> .visible=true
> End with
As mr_unreliable stated, use the methods of IE. Another method to
consider would be using the post URL. Below is a sample.
Set oIE = CreateObject("InternetExplorer.Application")
sDate = "082208"
sPostURL = "http://www.hcso.tampa.fl.us/pub/default.asp?" _
& "/Online/dailybook3"
oIE.navigate sPostURL & "?Date=" & sDate & "&report=D"
oIE.visible = True
Do Until oIE.ReadyState = 4 : WScript.Sleep 100 : Loop
Old 08-23-2008   #5 (permalink)
LuisE
Thanks James, it works fine.
In your code, what should I change if I need to use different fields of the
form?
> sDate = "082208"
> oIE.visible = True
Old 08-23-2008   #6 (permalink)
James Whitlow
news:433ED65F-7746-4235-867A-BE58AF0C2338@xxxxxx
> the
> form?
You will need to look at the source code of the page to determine that.
In the example you posted, I right clicked, selected 'View Source' and
searched for 'Booking Date:' & then 'Date:' under that. I searched up for
'action' to find the post URL. I then looked at the names of the input
fields. The date field is named 'Date' & the Report radio buttons are named
'report'. Just take the Post URL, add a question mark and then the field
names followed by an equal sign and the value you wish to pass. Separate the
fields with ampersands. In this case, I added '?Date=082208&report=D' to the
end of the Post URL.
I am not sure of a way to get the field names other than digging through
the HTML source code. There are probably others in the group that can offer
you a better way to do this. Firefox 2.x used to provide the fields names in
'View Page Info', but Firefox 3.x does not.
If you have trouble with the above, just advise the field names you are
looking for and either myself of someone else from the group can probably
help you determine them.
Old 08-24-2008   #7 (permalink)
Al Dunbar
"James Whitlow" <jwhitlow.60372693@xxxxxx> wrote in message
news:udhHHOWBJHA.2476@xxxxxx
>> the
>> form?
> named 'report'. Just take the Post URL, add a question mark and then the
> field names followed by an equal sign and the value you wish to pass.
> Separate the fields with ampersands. In this case, I added
> '?Date=082208&report=D' to the end of the Post URL.
> through the HTML source code. There are probably others in the group that
> can offer you a better way to do this. Firefox 2.x used to provide the
> fields names in 'View Page Info', but Firefox 3.x does not.
Most web pages are designed to present the human user an interface with
visual clues that make it intuitively obvious how to interact with the page
using keyboard and mouse via common controls and navigation standards. You
could develop two pages that looked and operated exactly the same, but using
completely different HTML coding underneath, so I suspect that James'
statement that "You will need to look at the source code of the page" is
right on the money.
Not only that, but you might find that internal changes in the page you are
accessing might eventually break your external code.
I wonder if a standard will eventually arise (a document object model
approach, perhaps) that will make web pages more navigable by external
script. This could, of course, result in fewer ads being seen, so perhaps
there are forces working against this approach.
/Al
Old 08-24-2008   #8 (permalink)
Bob Bridges
A few comments:
1) I didn't realize you could just add the values of fields to a URL; I
thought I had to get my program to fill in the values of the text boxes,
drop-down lists etc, and then simulate a click on the correct button. I
should spend more time in this forum.
2) I've had occasion to automate access to the occasional web page that
didn't assign names to the fields I wanted, so getElementById wasn't
avaailable. (In fact, at least one made a point of assigning random names
with each new invocation; I suppose they wanted to prevent the black hats
from ruining their site with undesirable automated attacks. Thus I've
developed some methods of getting at some fields (once I've identified them)
by other means than ...ById or ...ByName. In fact I've had to do it often
enough that I've written a Class and methods for the purpose, though of
course I'm still tweaking it. If you've had to do this once, it's a
lead-pipe cinch you'll want to do it again and again; I think you may as well
make up your mind to write your own class to save you time.
3) One of the ways of getting at fields without a name or ID is to navigate
down the ChildNode tree. But finding an element in the tree, so that you'll
know where to navigate to, is MUCH harder than finding it in the raw HTML
code - more useful, sometime, but harder. I eventually surrendered to
inevitability and wrote a method for my class that maps an entire HTML
document tree - wrote it in VBA/Excel, that being my need at the moment, but
the concept shouldn't be hard to transfer to VBS and text output.
I mention all this partly to solicit comments and partly with an eye to
exchanging useful code relating to this problem.
right on the money. Not only that, but you might find that internal changes
in the page you are accessing might eventually break your external code.
> fields.... The date field is named 'Date' & the Report radio buttons are
Quote:
> "LuisE" <legonzales@xxxxxx> wrote:
Quote:
>> ...what should I change if I need to use different fields of the form?
Old 08-25-2008   #9 (permalink)
James Whitlow
"Bob Bridges" <rhbridg.RemoveThisNode@xxxxxx> wrote in message
news:42A49137-AF00-4F2B-A699-2777B8B2DEE3@xxxxxx
Quote:
>A few comments:
Be aware of a few things when using this method. In the URL used in this
example, the Post URL was a fully qualified URL. In more cases than not,
this is not the case. It will be a relative path. For instance, the Google
groups advanced search URL is 'http://groups.google.com/advanced_search'.
The Post URL listed in the page is '/groups', so you would use the parent
URL plus the Post URL: 'http://groups.google.com/groups'. If you want a
search of the word 'vbscript', you could use
'http://groups.google.com/groups?as_q=vbscript'.
The second thing to be aware of is URL encoding. If you want to do the
same search as above, but search for multiple words, like 'vbscript xml',
you need encode the space. You could use something like
'http://groups.google.com/groups?as_q=vbscript%20xml'. If you are not
already aware of URL encoding, see this page:
http://www.permadi.com/tutorial/urlEncoding/
I use a function to just encode the reserved characters rather than the
entire URL. Below is the function I use. It is not extensively tested &
might be missing some characters, so use it with caution.
Function EncodeURL(ByVal sURL)
Dim i, sChar, sToEncode
sToEncode = "$&+,/:;=?@ <>#%{}|\^~[]`"
For i = 1 to Len(sURL)
sChar = Mid(sURL, i, 1)
If InStr(sToEncode, sChar) > 0 Then sChar = "%" & Right("00" &
Hex(Asc(sChar)), 2)
EncodeURL = EncodeURL & sChar
Next
End Function
Old 08-25-2008   #10 (permalink)
Al Dunbar
Quote:
>A few comments:
Adding field values to a URL is what the browser does in response to the
interactions you have with the mouse and the keyboard. Here, for example, is
the URL generated by a simple GOOGLE search for "look at this":
http://www.google.ca/search?hl=en&q=...e+Search&meta=
You could simply type in those calculated URL's, but it is generally easier
to interact with the GUI interface - unless you are a script.
They also want to increase the likelihood that visitors will see (and click
on) ads they have on their page that help pay their bills. Writing a script
to interact with a page is most likely *not* going to click on these links
(although you could consider attempting to add that "feature" to your code).
Quote:
> Thus I've
> them)
> well
Most probably.
> navigate
> you'll
> but
I hinted at the possibility of developing a script-friendly web page DOM,
but I now think it more likely for web page developers to obfuscate the
situation by making it harder to navigate programmatically. Or perhaps some
might publish code for others such as yourself to use that presses the
buttons of their sponsours. Then again, the sponsours might not like to find
out that their buttons are being pushed by scripts that are not likely to
buy their products...
Definitely a good idea.
/Al
> page
> using
> changes
>> that.
>> are
Strange Sendkeys() problem PowerShell
Sending Alt-Space with SendKeys in C# .NET General
sendkeys, ie7, forms, any new bugs? VB Script
SendKeys to cmd.exe PowerShell
Sendkeys problem with Vista Vista General
