| | right click option to run a scipt without closing the window when done? I tried adding the following as a custom right-click command (via folder options) but I keep getting access denied permission errors (with the file path and name in the error text) when trying to run it via a right click on a vbs file: %SystemRoot%\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe "%1" Which should resolve to something like this at runtime (which runs fine at the command prompt by the way): c:\windows\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe "C:\Documents and Settings\Steve\Desktop\example.vbs" The default "Open with command prompt" just runs the vbs and then exits, I want the window the remain open when done. The /k tells the command window to stay open when done (so you can read the output, etc). Q: Any ideas why this isn't working, or how to get the desired action? Tested using XP-Pro SP2. I can provide a screen cap of the dialog if you need the visual. |
| | Re: right click option to run a scipt without closing the window when done? "Steve" <sdixon2006@xxxxxx> wrote in message news 8Nsk.117438$nD.12944@xxxxxxQuote: >I tried adding the following as a custom right-click command (via folder >options) but I keep getting access denied permission errors (with the file >path and name in the error text) when trying to run it via a right click on >a vbs file: > %SystemRoot%\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe "%1" > > Which should resolve to something like this at runtime (which runs fine at > the command prompt by the way): > c:\windows\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe > "C:\Documents and Settings\Steve\Desktop\example.vbs" > > The default "Open with command prompt" just runs the vbs and then exits, I > want the window the remain open when done. The /k tells the command > window to stay open when done (so you can read the output, etc). > > Q: Any ideas why this isn't working, or how to get the desired action? > > Tested using XP-Pro SP2. I can provide a screen cap of the dialog if you > need the visual. '%1' argument. The code below should create the item for you. It works on my comptuer & I am also using XP-Pro SP2. Set oWSH = CreateObject("WScript.Shell") sSendTo = oWSH.Environment("Process").Item("UserProfile") & "\SendTo\" With oWSH.CreateShortcut(sSendTo & "Run With CScript.lnk") .TargetPath = "%SystemRoot%\system32\cmd.exe" .Arguments = "/k %systemroot%\system32\cscript.exe //NoLogo" .WorkingDirectory = "%temp%" .Description = "Run VBScript with CScript & leave window open." .IconLocation = "%systemroot%\system32\cscript.exe, 0" .Save End With |
| | Re: right click option to run a scipt without closing the window when done? "Steve" <sdixon2006@xxxxxx> wrote in message news 8Nsk.117438$nD.12944@xxxxxxQuote: >I tried adding the following as a custom right-click command (via folder >options) but I keep getting access denied permission errors (with the file >path and name in the error text) when trying to run it via a right click on >a vbs file: > %SystemRoot%\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe "%1" > > Which should resolve to something like this at runtime (which runs fine at > the command prompt by the way): > c:\windows\system32\cmd.exe /k C:\WINDOWS\System32\CScript.exe > "C:\Documents and Settings\Steve\Desktop\example.vbs" > > The default "Open with command prompt" just runs the vbs and then exits, I > want the window the remain open when done. The /k tells the command > window to stay open when done (so you can read the output, etc). > > Q: Any ideas why this isn't working, or how to get the desired action? > > Tested using XP-Pro SP2. I can provide a screen cap of the dialog if you > need the visual. associate this with a batch script that runs the script as vbscript and then executes a PAUSE statement. /Al |
| Single Click option | Tutorials | |||
| closing a window when done | .NET General | |||
| CMD window now closing | Vista General | |||
| closing wlm in tray w/r-click, then have to reboot to get back into wlm | Live Mail | |||
| Closing window | Vista General | |||
