| Guest | problem with forms hi ahave a three forms ON the first form i have button and i create second forms by dim frm = new form2 frm2.show() on the cecond form i have listbox and i want add record form thrird forms i have a button on second form and create third forms by: dim frm3 = new form3 frm3.show() on third form i have a button and i want add record to listbox on second form by: frm.listbox.items.add("value") or form2.listbox.items.add("value") bu is not work why? |
| Guest | Re: problem with forms First, your in the wrong group. This group is for VBScript, hence the name. Are you using some kind of VB? If you're using VB5/6 then you have the syntax wrong, and you can't call a sub with parentheses. You want: Frm.List1.AddItem "value" For further questions post to a VB group: microsoft.public.vb.general.discussion If you're using VB.Net then you need to ask in a ..Net group. (VB.Net has been misleadingly renamed just "VB" and each version has up to 3 names besides, so it can get confusing wading through Microsoft's marketing chaos! VB.Net includes anything called VB7, VB8, VB9, VB 1, VB 1.1, VB 2, VB 3, VB 2003, VB 2005, VB2008. You might find that any of those are also sometimes referreed to as "VB.Net", as in "VB.Net 2008". They're *all* VB.Net.) microsoft.public.dotnet.languages.vb Quote: > hi ahave a three forms > ON the first form i have button and i create second forms by > dim frm = new form2 > frm2.show() > > on the cecond form i have listbox > and i want add record form thrird forms > > i have a button on second form and create third forms by: > dim frm3 = new form3 > frm3.show() > > > on third form i have a button and i want add record to listbox on second > form by: > frm.listbox.items.add("value") or form2.listbox.items.add("value") > bu is not work why? > |
| Forms and WLM | Live Mail | |||
| simulate continuous forms & subforms in a windows forms application | .NET General | |||
| IE 7 and sending forms | Vista General | |||
| My Forms are cut off | Vista General | |||
| Trying Again - Flash Forms Problem in Vista | Vista General | |||
