Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Microsoft Technical Newsgroups > VB Script
Update Textbox Problem
LinkBack Thread Tools Display Modes
Old 08-27-2008   #1 (permalink)
timwynn
Guest
Hello!
I’m new to VB and need some help.
1st: I’m I posting to the correct group?
2nd: I have a small VB Form Program to do batch process for
converting files in ArcGIS. The processing works well but I need to
make enhancements.
I’m trying to do process monitoring via a textbox (TextBox5.Text). In
some parts of the code the textbox is updated and in other location it
is not. For example, in the Subs btnDoFBD_Click and
OutPutFolder_Click works but in the Main Sub this text box is not
being up dated. For example,
'Display next message in Message Center - this does not work
TextBox5.Text = Nothing
TextBox5.Text = "Proccessing...Please Wait..."
I understand that this code could be written more efficient and I’m
open to suggestion. I’ve pulled it together from example off Google
Groups and surprisingly it work. I don’t know which controls are best
used in which situation but would really like to learn.
Can someone tell me why this textbox is not being updated? Can you
tell me if there’s a better way to do Process Monitoring. I’ve
searched for examples of “Process Bar” but can not find any that I can
understand and implement. A good example would be helpful.
3rd: I have a Sub “btnDoFBD_Click” to input the data for this
process. I select the Input Folder via this Click event and display
the selected folder in TextBox3.Text = objPathIN and all works well
but TextBox3.Text is only for display. Is there another control that
will allow me to keyin the Input and/or select it from a button or
pull-down?
Thanks for your help in advance.
Tim
Display Modes
Comodo Firewall update addresses Windows Update problem PA Bear [MS MVP] Vista security 7 02-14-2008 01:05 AM
Comodo Firewall update addresses Windows Update problem PA Bear [MS MVP] Vista General 5 01-17-2008 07:22 PM
no textbox for password jaap Vista account administration 2 08-13-2007 02:58 PM
Huge problem with security update kb935902 on Windows Update JH Vista General 13 04-05-2007 09:32 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
