| | Help with script Hello, I need help with a script, what I would like it to do is scan though a share look for a particular file, copy the file and rename it to the name of the computer that it was on... for example the file is acb123.txt ... search for that file and then once it is found rename it to computer1acb123.txt... any help would be appreaciated. Thanks Gavin... |
| | RE: Help with script Hey, Gavin. What have you attempted so far? My guess, from your post, is "nothing" - you've never written a VBS script before and you're starting from scratch. Nothing wrong with that, but it calls for a different answer than if you're fairly experienced and just need a hint. So fill us in, please, and let us know how much you know so far. --- "Gavin" wrote: Quote: > I need help with a script, what I would like it to do is scan though a share > look for a particular file, copy the file and rename it to the name of the > computer that it was on... for example the file is acb123.txt ... search for > that file and then once it is found rename it to computer1acb123.txt... any > help would be appreaciated. |
| Logon Script Causing Laptops To Hang - Problems in script? | VB Script | |||
| problem passing args to script 'There is no script engine for file extenstion' | VB Script | |||
| Include another script, keep variables in included script? | PowerShell | |||
| Script file has 'OS Handle' error when run from script | PowerShell | |||
| Can you drag-n-drop a file on top of a PS script to run the script? | PowerShell | |||
