| | Power Management Schedule Task Options I have created a script shelling out to schtask.exe to create scheduled tasks on all my servers (1000+), which are all located at different sites around the country. As you are aware the default Power Mgmt. setting on the Settings tab is for "Don't start the task if the computer is running on batteries" and "Stop the task if battery mode begins" to be checked on I need to change the default Power Management settings that are on the Settings tab in the scheduled job through a script. Can anyone recommend a way to do this, and possibly provide some sample scripting. Thank you! |
| Rename schedule task | VB Script | |||
| Power Management/Power Options in Vista | Vista General | |||
| Schedule a task with Vista task Scheduler wakes up computer and mo | Vista General | |||
| schedule a task with WMI? | PowerShell | |||
| Schedule Task | Vista performance & maintenance | |||
