Vista - VBScript Problem with Access Query (Unspecified error)
Old 09-05-2008   #1 (permalink)
Codeblack
I am facing a strange problem with a access query. I am trying to retrive
some records from the multiple tables using Inner Join. The query is working
absolutely fine when i execute the query in MS access 2003. But when i use
the below Query in VBscript then i am getting the below Error. Can any one
help me to findout what is that i am missing. Any help will be greatly
appreciated.
Error : (null): Unspecified error.
Error is pointing at :- Set rs = conn.Execute(StrSQL)
Set conn = CreateObject("ADODB.Connection")
strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data
Source=z:\Project\test.mdb"
conn.Open strConnect
intRow = 1
StrSQL = "SELECT [Webmail Domains].[Root Domain],
Sum([Total_Bytes]/1024/1024) AS [Total MB], Sum(SenderToDom.Recip_Counts) AS
[Recip Counts]"&_"FROM [DeptCode CorpSvcs] INNER JOIN ((SenderToDom INNER
JOIN AllEmployees ON SenderToDom.Sender = AllEmployees.Email) INNER JOIN
[Webmail Domains] ON SenderToDom.Recip_Domain = [Webmail Domains].Domain) ON
[DeptCode CorpSvcs].DeptCode = AllEmployees.DeptCode"&_
"GROUP BY [Webmail Domains].[Root Domain] ORDER BY
Sum([Total_Bytes]/1024/1024) DESC"
do While not rs.EOF
wscript.Echo rs(0)
wscript.Echo rs(1)
rs.MoveNext
Loop
RS.Close
set RS = nothing
conn.close
set conn = nothing
Old 09-05-2008   #2 (permalink)
Bob Barrows [MVP]
Re: VBScript Problem with Access Query (Unspecified error)
Codeblack wrote:
> retrive some records from the multiple tables using Inner Join. The
> query is working absolutely fine when i execute the query in MS
> access 2003. But when i use the below Query in VBscript then i am
> getting the below Error. Can any one help me to findout what is that
> i am missing. Any help will be greatly appreciated.
> intRow = 1
> Sum(SenderToDom.Recip_Counts) AS [Recip Counts]" & _
> "FROM [DeptCode
> CorpSvcs] INNER JOIN ((SenderToDom INNER JOIN AllEmployees ON
> SenderToDom.Sender = AllEmployees.Email) INNER JOIN [Webmail Domains]
> ON SenderToDom.Recip_Domain = [Webmail Domains].Domain) ON [DeptCode
> CorpSvcs].DeptCode = AllEmployees.DeptCode"&_ "GROUP BY [Webmail
> Domains].[Root Domain] ORDER BY Sum([Total_Bytes]/1024/1024) DESC"
It is very hard to help you without knowing the string that this
expression evaluates to.
Echo the contents of StrSQL or write them to a file so you can show us
what the result looks like.
Microsoft MVP -- ASP/ASP.NET
Please reply to the newsgroup. The email account listed in my From
header is my spam trap, so I don't check it very often. You will get a
quicker response by posting to the newsgroup.
Old 09-05-2008   #3 (permalink)
Codeblack
The Echo of StrSQL just returned this
SELECT [Webmail Domains].[Root Domain], Sum([Total_Bytes]/1024/1024) AS
[Total MB], Sum(SenderToDom.Recip_Counts) AS [Recip Counts] FROM [DeptCode
SenderToDom.Sender = AllEmployees.Email) INNER JOIN [Webmail Domains] ON
CorpSvcs].DeptCode = AllEmployees.DeptCode GROUP BY [Webmail Domains].[Root
Z:\Project\test.vbs(25, 1) (null): Unspecified error
> > intRow = 1
> > "FROM [DeptCode
Old 09-05-2008   #4 (permalink)
Bob Barrows [MVP]
And you have verified that this matches the sql of the query that you
successfully ran in Access?
You might it simpler to save the query that works in Access, giving it
a name you can use in vbscript:
set rs=createobject("adodb.recordset")
conn.MySavedQuery rs
do While not rs.EOF
wscript.Echo rs(0)
wscript.Echo rs(1)
rs.MoveNext
Loop
> AS [Total MB], Sum(SenderToDom.Recip_Counts) AS [Recip Counts] FROM
> [DeptCode CorpSvcs] INNER JOIN ((SenderToDom INNER JOIN AllEmployees
> ON SenderToDom.Sender = AllEmployees.Email) INNER JOIN [Webmail
> [DeptCode CorpSvcs].DeptCode = AllEmployees.DeptCode GROUP BY
> [Webmail Domains].[Root Domain] ORDER BY Sum([Total_Bytes]/1024/1024)
> DESC
>>> intRow = 1
>>> "FROM [DeptCode
>>> [DeptCode CorpSvcs].DeptCode = AllEmployees.DeptCode"&_ "GROUP BY
>> us what the result looks like.
>> a quicker response by posting to the newsgroup.
Old 09-06-2008   #5 (permalink)
Jeff C
RE: VBScript Problem with Access Query (Unspecified error)
Jeff C
Live Well .. Be Happy In All You Do
> appreciated.
I use Access extensively and whenever I want to process data from outside
the database I use a different method. I build the process to work
completely within an Access macro, whether running multiple queries in
succession and/or running code from a module - place it all in a macro. Then
I use Access command line functionality - "full path to Access.exe" "full
path to the database I am using" /x "name of macro". I place the command
line in a batch file and run it using the task scheduler. Maybe this method
could help?
> intRow = 1
> do While not rs.EOF
> wscript.Echo rs(0)
> wscript.Echo rs(1)
> rs.MoveNext
> Loop
> RS.Close
> set RS = nothing
> conn.close
> set conn = nothing
Old 09-09-2008   #6 (permalink)
Codeblack
Thank you very much for your suggestion. The problem got solved.
> do While not rs.EOF
> wscript.Echo rs(0)
> wscript.Echo rs(1)
> rs.MoveNext
> Loop
> > DESC
> >>> intRow = 1
> >>> "FROM [DeptCode
VBScript to Query WMI VB Script
execute mysql query using vbscript VB Script
Solved add favourites unspecified error General Discussion
SQL Query in VBScript VB Script
VBScript problem in running Stored Query VB Script
