| | Is the script ok or does it need improvement Here it is: strComputer = "." Dim strNetdrive, strNetpath strNetdrive = "v:\" 'strNetpath = Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") Set objNetwork = CreateObject("Wscript.Network") Set colItems = objWMIService.ExecQuery _ ("Select * From Win32_LogicalDisk Where DeviceID" = strNetdrive ) Set objFSO = CreateObject("Scripting.FileSystemObject") Set objTextFile = objFSO.CreateTextFile("C:\Scripts\Test.txt") Set colSubfolders = objWMIService.ExecQuery _ ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ & "Where AssocClass = Win32_Subdirectory " _ & "ResultRole = PartComponent") Set colFiles = objWMIService.ExecQuery _ ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where " _ & "ResultClass = CIM_DataFile") For Each objFile In colFiles If objFile.Extension = "RW" Or objFile.Extension = "txt" Or objFile.Extension = "csv" Or objFile.Extension = "rwx" Then objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " & Date() & " " & Time WScript.Echo strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " & Date() & " " & Time End If Next For Each objFolder in colSubfolders GetSubFolders strNetdrive i = i + 1 Next WScript.Echo "Total Files: " & i Sub GetSubFolders(strNetdrive) Set colSubfolders2 = objWMIService.ExecQuery _ ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ & "Where AssocClass = Win32_Subdirectory " _ & "ResultRole = PartComponent") For Each objFolder2 in colSubfolders2 strNetdrive = objFolder2.Name Set colFiles = objWMIService.ExecQuery _ ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where " _ & "ResultClass = CIM_DataFile") For Each objFile In colFiles If objFile.Extension = "RW" Or objFile.Extension = "txt" Or objFile.Extension = "csv" Or objFile.Extension = "rwx" Then objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " & Date() & " " & Time WScript.Echo strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " & Date() & " " & Time 'will delete file End If Next GetSubFolders strNetdrive Next End Sub It runs fine but I think I have the WScript.Echo "Total Files: " & i in the wrong place. I left out the objfile.delete, this is just a test run. Where it says objFile.Extension over and over again can I do something different like strEXten = "txt, rw, rxz" |
| | Re: Is the script ok or does it need improvement "freddy" <freddy@xxxxxx> wrote in message news:F6AE359E-CD7B-47CC-868E-3C42F98B5CD2@xxxxxx Quote: > Here it is: > > strComputer = "." > Dim strNetdrive, strNetpath > strNetdrive = "v:\" > 'strNetpath = > Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") > Set objNetwork = CreateObject("Wscript.Network") > Set colItems = objWMIService.ExecQuery _ > ("Select * From Win32_LogicalDisk Where DeviceID" = strNetdrive ) > > Set objFSO = CreateObject("Scripting.FileSystemObject") > Set objTextFile = objFSO.CreateTextFile("C:\Scripts\Test.txt") > > Set colSubfolders = objWMIService.ExecQuery _ > ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ > & "Where AssocClass = Win32_Subdirectory " _ > & "ResultRole = PartComponent") > > Set colFiles = objWMIService.ExecQuery _ > ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where " _ > & "ResultClass = CIM_DataFile") > For Each objFile In colFiles > If objFile.Extension = "RW" Or objFile.Extension = "txt" Or > objFile.Extension = "csv" Or objFile.Extension = "rwx" Then > objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & "." & > objFile.Extension & " has been deleted on " & Date() & " " & Time > WScript.Echo strNetdrive & "\" & objFile.FileName & "." & > objFile.Extension & " has been deleted on " & Date() & " " & Time > End If > Next > > For Each objFolder in colSubfolders > GetSubFolders strNetdrive > i = i + 1 > Next > WScript.Echo "Total Files: " & i > > > Sub GetSubFolders(strNetdrive) > > Set colSubfolders2 = objWMIService.ExecQuery _ > ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ > & "Where AssocClass = Win32_Subdirectory " _ > & "ResultRole = PartComponent") > > For Each objFolder2 in colSubfolders2 > strNetdrive = objFolder2.Name > > Set colFiles = objWMIService.ExecQuery _ > ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where > " _ > & "ResultClass = CIM_DataFile") > > For Each objFile In colFiles > If objFile.Extension = "RW" Or objFile.Extension = "txt" Or > objFile.Extension = "csv" Or objFile.Extension = "rwx" Then > objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & > "." > & objFile.Extension & " has been deleted on " & Date() & " " & Time > WScript.Echo strNetdrive & "\" & objFile.FileName & "." & > objFile.Extension & " has been deleted on " & Date() & " " & Time > 'will delete file > > End If > Next > > GetSubFolders strNetdrive > > Next > > End Sub > > It runs fine but I think I have the WScript.Echo "Total Files: " & i in > the > wrong place. I left out the objfile.delete, this is just a test run. Where > it > says objFile.Extension over and over again can I do something different > like > strEXten = "txt, rw, rxz" and there is an error in the statement: Set colItems = objWMIService.ExecQuery _ ("Select * From Win32_LogicalDisk Where DeviceID" = strNetdrive ) It probably should be: Set colItems = objWMIService.ExecQuery _ ("Select * From Win32_LogicalDisk Where DeviceID='" & strNetdrive & "'") except I don't think the trailing backslash in the value of strNetdrive is allowed. No matter since colItems is not used. I would suggest: Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _ & strComputer & "\root\cimv2") Instead of: Date() & " " & Time() I would use: Now() I don't believe there is any better way to handle the file extensions. Your variable i counts folders, not files, and only at the parent level. If you want to count files the variable should be incremented in the For Each loop that enumerates colFiles. Since the Sub is recursive, the variable must have global scope. Finally, I would suggest using "Option Explicit" and declaring all variables. Some variables are used in both the main program and subroutine, which I believe is OK, but it would help to make the scope clear with Dim statements. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: Is the script ok or does it need improvement I tried moving the i=i+1 but nothing is happening it just echos out: file = Where do I put the i=i+1. Here is where I put it Sub GetSubFolders(strNetdrive) Set colSubfolders2 = objWMIService.ExecQuery _ ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ & "Where AssocClass = Win32_Subdirectory " _ & "ResultRole = PartComponent") For Each objFolder2 in colSubfolders2 strNetdrive = objFolder2.Name Set colFiles = objWMIService.ExecQuery _ ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where " _ & "ResultClass = CIM_DataFile") For Each objFile In colFiles If objFile.Extension = "RW" Or objFile.Extension = "PRN" Or objFile.Extension = "csv" Or objFile.Extension = "rwx" Or objFile.Extension = "RPT" Then objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " & Now () WScript.Echo strNetdrive & "\" & objFile.FileName & "." & objFile.Extension & " has been deleted on " &Now () 'will delete file End If i = i + 1 Next GetSubFolders strNetdrive Next End Sub Thanks "Richard Mueller [MVP]" wrote: Quote: > > "freddy" <freddy@xxxxxx> wrote in message > news:F6AE359E-CD7B-47CC-868E-3C42F98B5CD2@xxxxxx Quote: > > Here it is: > > > > strComputer = "." > > Dim strNetdrive, strNetpath > > strNetdrive = "v:\" > > 'strNetpath = > > Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2") > > Set objNetwork = CreateObject("Wscript.Network") > > Set colItems = objWMIService.ExecQuery _ > > ("Select * From Win32_LogicalDisk Where DeviceID" = strNetdrive ) > > > > Set objFSO = CreateObject("Scripting.FileSystemObject") > > Set objTextFile = objFSO.CreateTextFile("C:\Scripts\Test.txt") > > > > Set colSubfolders = objWMIService.ExecQuery _ > > ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ > > & "Where AssocClass = Win32_Subdirectory " _ > > & "ResultRole = PartComponent") > > > > Set colFiles = objWMIService.ExecQuery _ > > ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where " _ > > & "ResultClass = CIM_DataFile") > > For Each objFile In colFiles > > If objFile.Extension = "RW" Or objFile.Extension = "txt" Or > > objFile.Extension = "csv" Or objFile.Extension = "rwx" Then > > objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & "." & > > objFile.Extension & " has been deleted on " & Date() & " " & Time > > WScript.Echo strNetdrive & "\" & objFile.FileName & "." & > > objFile.Extension & " has been deleted on " & Date() & " " & Time > > End If > > Next > > > > For Each objFolder in colSubfolders > > GetSubFolders strNetdrive > > i = i + 1 > > Next > > WScript.Echo "Total Files: " & i > > > > > > Sub GetSubFolders(strNetdrive) > > > > Set colSubfolders2 = objWMIService.ExecQuery _ > > ("Associators of {Win32_Directory.Name='" & strNetdrive & "'} " _ > > & "Where AssocClass = Win32_Subdirectory " _ > > & "ResultRole = PartComponent") > > > > For Each objFolder2 in colSubfolders2 > > strNetdrive = objFolder2.Name > > > > Set colFiles = objWMIService.ExecQuery _ > > ("ASSOCIATORS OF {Win32_Directory.Name='" & strNetdrive & "'} Where > > " _ > > & "ResultClass = CIM_DataFile") > > > > For Each objFile In colFiles > > If objFile.Extension = "RW" Or objFile.Extension = "txt" Or > > objFile.Extension = "csv" Or objFile.Extension = "rwx" Then > > objTextFile.WriteLine strNetdrive & "\" & objFile.FileName & > > "." > > & objFile.Extension & " has been deleted on " & Date() & " " & Time > > WScript.Echo strNetdrive & "\" & objFile.FileName & "." & > > objFile.Extension & " has been deleted on " & Date() & " " & Time > > 'will delete file > > > > End If > > Next > > > > GetSubFolders strNetdrive > > > > Next > > > > End Sub > > > > It runs fine but I think I have the WScript.Echo "Total Files: " & i in > > the > > wrong place. I left out the objfile.delete, this is just a test run. Where > > it > > says objFile.Extension over and over again can I do something different > > like > > strEXten = "txt, rw, rxz" > The variable objNetwork is not used. The variable colItems is also not used > and there is an error in the statement: > > Set colItems = objWMIService.ExecQuery _ > ("Select * From Win32_LogicalDisk Where DeviceID" = strNetdrive ) > > It probably should be: > > Set colItems = objWMIService.ExecQuery _ > ("Select * From Win32_LogicalDisk Where DeviceID='" & strNetdrive & "'") > > except I don't think the trailing backslash in the value of strNetdrive is > allowed. No matter since colItems is not used. > I would suggest: > > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate,authenticationLevel=Pkt}!\\" _ > & strComputer & "\root\cimv2") > > Instead of: > > Date() & " " & Time() > > I would use: > > Now() > > I don't believe there is any better way to handle the file extensions. Your > variable i counts folders, not files, and only at the parent level. If you > want to count files the variable should be incremented in the For Each loop > that enumerates colFiles. Since the Sub is recursive, the variable must have > global scope. Finally, I would suggest using "Option Explicit" and declaring > all variables. Some variables are used in both the main program and > subroutine, which I believe is OK, but it would help to make the scope clear > with Dim statements. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab - http://www.rlmueller.net > -- > > > |
| WLM an improvement? | Live Mail | |||
| Possible UAC Improvement | Vista security | |||
| Contacts in need of improvement | Vista mail | |||
| 2GB to 4GB, how much of an improvement? | Vista hardware & devices | |||
| No Improvement in RC1 since Beta 2 | Vista General | |||
