| | how to create checkbox using vbscript Hai... how to create checkbox using vbscript can anyone help me out... Thanks & Regards, Ramji |
| | Re: how to create checkbox using vbscript Il giorno Sun, 7 Sep 2008 08:37:04 -0700 (PDT), ramji <dasari.ramji@xxxxxx> ha scritto: Quote: >how to create checkbox using vbscript >can anyone help me out... It's an html file renamed with hta extension. From ms site download ms hta-helpomatic, which creates the code you need. Giovanni. -- Giovanni Cenati (Bergamo, Italy) Write to "Reventlov" at katamail com http://digilander.libero.it/Cenati (Esempi e programmi in VbScript) -- |
| how to create a tunnel vpn with vbscript? | VB Script | |||
| Create tables with vbscript. | VB Script | |||
| Create vbscript to empty secure temp folder when exiting Outlook. | VB Script | |||
| vbscript AD and who create account | VB Script | |||
| vbscript to create file | Vista General | |||
