| | Help with SQL statement I am trying to check for the existance of a server record in our SQL db. My sql statement returns an error of: Microsoft VBScript compilation error: Expected end of statement. My statement is: strSqlQuery = "SELECT item.item_sc, item.item_n,item.item_keya FROM assyst.dbo.item WHERE item.item_sc = ' " & strComputer " ' " There are several more fields I want to return in addition to what's in the current statement, but getting this to work will do for now. I'm assuming it will return a NULL recordset if the server was not entered. TIA, Seymour |
| | Re: Help with SQL statement > My statement is: Quote: > strSqlQuery = "SELECT item.item_sc, item.item_n,item.item_keya FROM > assyst.dbo.item WHERE item.item_sc = ' " *& strComputer " ' " "SELECT item.item_sc, item.item_n,item.item_keya FROM assyst.dbo.item WHERE item.item_sc = ' " & strComputer & " ' " |
| | Re: Help with SQL statement "krazymike" <krazymike@xxxxxx> wrote in message news:4dbee183-b17f-48db-89c5-63e82def063d@xxxxxx Quote: > My statement is: > strSqlQuery = "SELECT item.item_sc, item.item_n,item.item_keya FROM > assyst.dbo.item WHERE item.item_sc = ' " & strComputer " ' " "SELECT item.item_sc, item.item_n,item.item_keya FROM assyst.dbo.item WHERE item.item_sc = ' " & strComputer & " ' " ------ Also, I believe the extra spaces around the value of strComputer are a problem. I would use: ====== strSqlQuery = "SELECT item.item_sc, item.item_n, item.item_keya " _ & "FROM assyst.dbo.item " _ & "WHERE item.item_sc = '" & strComputer & "'" ==== Otherwise you have concatenated space characters to the computer name. -- Richard Mueller MVP Directory Services Hilltop Lab - http://www.rlmueller.net -- |
| | Re: Help with SQL statement Thanks to you both. I figured out the concatenation and was coming back here to post that I solved it. You guys are QUICK! Now it appears that I need to do a JOIN as some of the fields I'm looknig for might be in another table. I may be back for more help <g> Seymour On Sep 8, 3:39*pm, "Richard Mueller [MVP]" <rlmueller- nos...@xxxxxx> wrote: Quote: > "krazymike" <krazym...@xxxxxx> wrote in message > > news:4dbee183-b17f-48db-89c5-63e82def063d@xxxxxx > Quote: > > My statement is: > > strSqlQuery = "SELECT item.item_sc, item.item_n,item.item_keya FROM > > assyst.dbo.item WHERE item.item_sc = ' " & strComputer " ' " > You didn't concatenate the last string segment. > "SELECT item.item_sc, item.item_n,item.item_keya FROM > assyst.dbo.item WHERE item.item_sc = ' " *& strComputer & *" ' " > ------ > Also, I believe the extra spaces around the value of strComputer are a > problem. I would use: > ====== > strSqlQuery = "SELECT item.item_sc, item.item_n, item.item_keya " _ > * * & "FROM assyst.dbo.item " _ > * * & "WHERE item.item_sc = '" *& strComputer & "'" > ==== > Otherwise you have concatenated space characters to the computer name. > > -- > Richard Mueller > MVP Directory Services > Hilltop Lab -http://www.rlmueller.net > -- |
| Is this statement real? I can't buy but maybe U can | General Discussion | |||
| First 400 Records in SQL Statement | VB Script | |||
| More than one condition with the if-Statement | PowerShell | |||
| just a statement | Vista General | |||
