Vista - Help Understanding INNER JOIN
Old 09-10-2008   #1 (permalink)
Leona Leal Educator
I have this script that seems to work until;
rsSchools.Open "SELECT * FROM Schools INNER JOIN Students ON
Schools.StdntID=Students.StdntID", Cnnct, 3, 3
However when I go to reference a field it bombs!
On Response.Write rsSchools("StdntID") i get the following message!
ADODB.Recordset (0x800A0CC1)
Item cannot be found in the collection corresponding to the requested name
or ordinal.
I know the join works because the rsSchools.RecordCount returns the right
number of records.
Why do I bomb on my Response.Write rsSchools("StdntID") ?
Thanks for the help in advance
Leona
Old 09-10-2008   #2 (permalink)
hb21l6
Re: Help Understanding INNER JOIN
"Leona Leal Educator" <LeonaLealEducator@xxxxxx> wrote in
message news:9EB33F21-70FD-4041-BBD8-8DA86E72EB87@xxxxxx
> or ordinal.
> number of records.
> Leona
You have two tables with the same field name so it doesn't know which one to
return
try specifying the field names you require.
rsSchools.Open "SELECT Students.StdntID as studentID, Students.fieldName2
etc
Old 09-10-2008   #3 (permalink)
Old Pedant
RE: Help Understanding INNER JOIN
> or ordinal.
"hb" is absolutely correct as to the reason for the error and the solution.
But just as a general rule you should always give the explicit list of fields
you need in your SELECT. It would be highly unusual to actually *need* all
the field in both tables in your VBS code, and you can gain efficiency
(sometimes a lot) by only transferring needed data.
Having said all that...
It's also true that for *some* databases ADO will allow you to do
Response.Write rsSchools("Students.StdntID")
and separate the tables via the recordset field selector. Whether it works
or not depends on whether the SQL query to the given DB returns the table
info for each field or not.
LINQ: Inner Join & Left Outer Join Q .NET General
Help understanding one liner VB Script
Understanding the WLM newsreader Live Mail
UAC problem - Need a little help and a lot of understanding Vista security
Understanding Vista Vista General
