Vista - String to int conversion
Old 09-11-2008   #1 (permalink)
karsagarwal
I have a string str which can take any odd values from 01 to 99. I
need to convert that to the next positive number.
Therefore 03 becomes 04
25 becomes 26
01 becomes 02
With the code I have below I get 03 to be 4. So I loose the 0 which is
crucial to me. Any suggestions as to how to solve this issue.
str="03"
str=Cint(str) + 1
wscript.echo str
Thanks,
SA
Old 09-11-2008   #2 (permalink)
Richard Mueller [MVP]
Re: String to int conversion
<karsagarwal@xxxxxx> wrote in message
news:24d37819-2dae-426c-9d57-f11bf1f06ada@xxxxxx
Quote:
> Hi,
> 25 becomes 26
> 01 becomes 02
> str="03"
> str=Cint(str) + 1
> wscript.echo str
It must be formated as a string to have the leading zero. One solution
(assuming always 2 digits) would be:
str = "03"
str = Right("0" & CStr(CInt(str) + 1), 2)
Wscript.Echo str
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 09-13-2008   #3 (permalink)
Dr J R Stockton
In microsoft.public.scripting.vbscript message <24d37819-2dae-426c-
9d57-f11bf1f06ada@xxxxxx>, Thu, 11 Sep 2008
18:10:37, "karsagarwal@xxxxxx" <karsagarwal@xxxxxx> posted:
Quote:
>str="03"
>str=Cint(str) + 1
>wscript.echo str
str="03"
wscript.echo Right(str+101, 2)
ASIDE - it appears that one cannot (one can in JavaScript) apply unary
plus and convert String to Number - document.write +"03" gives '03'.
But one can apply unary minus and convert - document.write -"03" gives
'-3' and one can apply it twice - document.write --"03" gives '3' .
(c) John Stockton, nr London, UK. ?@merlyn.demon.co.uk Turnpike v6.05 MIME.
Web <URL:http://www.merlyn.demon.co.uk/> - FAQish topics, acronyms, & links.
Proper <= 4-line sig. separator as above, a line exactly "-- " (SonOfRFC1036)
Do not Mail News to me. Before a reply, quote with ">" or "> " (SonOfRFC1036)
Old 09-13-2008   #4 (permalink)
Old Pedant
"Dr J R Stockton" wrote:
Quote:
> str="03"
My head hurts.
In so many other uses of string+number, I have seen that the result is
string concatenation. Why this simple usage works is a mystery to me.
Oh, I understand what happens, under the covers. VBScript attempts to
coerce the two values being "added" to the same data type, using
VariantChangeTypeEx. But it has been my experience *many* times in the past
that the preferred conversion is integer to string (so that then the +
operator causes concatenation). Wish I had a handy example; if I find one
I'll repost. But anyway, clearly in a simple situation such as this (one
string, one integer) it works exactly as you would want it to.
I wonder if the precendence (string vs. number) has changed between VBS 3
and VBS 5? Because when I was working in the source code of VBS 3 (about
1999), I pretty clearly remember it the other way around. Oh, well. Maybe
not. Maybe senility has set in.
conversion from .net String to mfc CString .NET General
problems with $var | select-string -pattern $string -q PowerShell
bug in string<->datetime conversion? PowerShell
How export-csv deals with string versus string[] PowerShell
String PRODUCT_NAME was not found in string table Vista General
