Vista - Connection Timeout between Network Queries
Old 09-15-2008   #1 (permalink)
Vista32bit
Essentially, with the help of a generous colleague, we built this script to do the following:
1) Over an internal corporate network we do a machine bios search (DNS search essentially) using a list we created from, say c:\systemlist.txt
2) We search these computers from #1 in a location on the remote machines in \c$\syslevel
3) The filename we're looking for, as an example, is test*.*
4) We then dump the results of whether it finds this test*.* successfully, or doesn't find it, or the network times out to a file c:\RESULTS.txt
The problem is this:
As the vbscript is going through the list some machines it won't obviously find on the network due to lag or the remote machine is not turned on.
How do I create a timeout that I can set for, say, 5-15seconds or whatever so that between scans of the computers in #1 it will only, say, scan the machine for 5seconds then just go to the next one in the list if no result was found? Remember, this is looking at the remote PCs name's via a DNS lookup and out network guys cannot change this so if I can do it artificially within the script so it doesn't have to wait up to 1-2mins to not find a machine then it would drastically cut down my query times.
My code:
Code:
on error resume next
Const ForReading = 1
Const ForWriting = 2
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objTextFile = objFSO.OpenTextFile ("c:\systemlist.txt", ForReading)
Wscript.Timeout = 5
Wscript.echo objtextfile
' create the input array
strText = objTextFile.ReadAll
objTextFile.Close
arrComputers = Split(strText,vbcrlf)
Dim objFolder, objFile, TS
Dim strDirectory, strWildCard, strPattern
Dim strLog, blnFound, i
Dim objRegExpr
   'Create an instance of the regexp object
   Set objRegExpr = CreateObject("VBScript.RegExp")
   strWildCard = "test*.*"
   'Update the wildcard string to define a valid regular expression
   strPattern = Replace(strWildCard, ".", "\.")
   strPattern = Replace(strPattern, "*", ".*")
   strPattern = "^" & strPattern & "$"
   strPattern = Replace(strPattern, ".*$", ".+$")
   objRegExpr.Pattern = strPattern
   objRegExpr.Global = True
   objRegExpr.IgnoreCase = True
   'Set where you will log your findings
   strLog = "c:\RESULTS.txt"
   Set TS = objFSO.OpenTextFile(strLog,ForWriting,true)
For i = 0 To UBound(arrComputers)
   'Get the directory you are searching
   strDirectory = "\\" & arrComputers(i) & "\c$\syslevel\"
   'Set your found flag
   blnFound = False
   'Check that that the directory exists. This shouldn't take
   'long to retrun false if the machine can't be reached.
   If objFSO.FolderExists(strDirectory) Then
       'Get the current folder
       Set objFolder = objFSO.GetFolder(strDirectory)
       'Loop through all the files in the folder
       For Each objFile In objFolder.Files
           'Check if the file matches the wildcard search
           If objRegExpr.Test(objFile.Name) Then
               'Add file to log if found
               TS.WriteLine(arrComputers(i) & vbTab & objFile.Name)
               blnFound = True
           End If
       Next
   Else
       'Note in the log if the machine couldn't be reached
       TS.WriteLine(arrComputers(i) & " **Network Path could not be resolved**")
       blnFound = True
   End If
   'Add note if the file wasn't found
   If not blnFound Then
       TS.WriteLine(arrComputers(i) & vbTab & strWildCard & " not found")
   End if
   'Add an extra line to seperate the machines
   'TS.WriteLine("")
Next
TS.Close
Set TS = Nothing
Set objRegExpr = Nothing
MsgBox "QUERY COMPLETED!"
Thanks Vista community. Your help would be MOST appreciated here!
Old 09-15-2008   #2 (permalink)
Richard Mueller [MVP]
Re: Connection Timeout between Network Queries
"thudo" <guest@xxxxxx-email.com> wrote in message
news:9b359bd335f48cef2b42f0165f937006@xxxxxx-gateway.com...
> c:\RESULTS.txt
> turned on.
> query times.
> My code:
> Code:
> Wscript.Timeout = 5
> objTextFile.Close
> Dim objRegExpr
> blnFound = False
> blnFound = True
> End If
> Next
> Else
> blnFound = True
> End If
> End if
> 'TS.WriteLine("")
> Next
> TS.Close
> Set TS = Nothing
> thudo
You can use a ping function to check if the remote computers is available. I
have four examples linked here:
http://www.rlmueller.net/PingComputers.htm
The one you select depends on the OS. Also some do not allow you to specify
the timeout.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 09-15-2008   #3 (permalink)
Vista32bit
Hmmm but how do I integrate that the above script or do I run your script before running mine to produce a list of machines that are up? The problem is how to tell cscript to skip to the next machine in the list while still running the script? cscript's timeout only works when it cancels the whole script engine. So far you can do a timeout via a cscript command line like:
Code:
cscript //t:60 TEST2.vbs
Where it runs the .vbs with a timeout of 60seconds before the script discontinues BUT this cancels the entire script. There has to be another method inside vbscript to query the list for a selectable amount of time before it considers the result a TIMEOUT then proceed to next machine in the list?
Timeout uploading to ftp through network drives. Vista networking & sharing
How to reduce WMI connection timeout? VB Script
The timeout period elapsed prior to obtaining a connection from th .NET General
Vista network quick to timeout Vista networking & sharing
Vista network quick to timeout Vista performance & maintenance
