Vista - SQL Statement Help - Invalid chars
Old 09-17-2008   #1 (permalink)
Bob Smith
Does anyone have a VBScript function that will help escape common SQL
Characters.
An example would be something like inserting this SQL command with this string
string = "smith, jacob's"
SQL = "INSERT INTO MyTable (DisplayName) Values ('" & String & "')"
conn.Execute(SQL)
This would return an error. Other common charactors may include include \ '
% OR and other items. There may also be multiple entries of one or more of
these chars in the same string. any help would be appriciated. The source of
data is unpredictable.
Thanks
Old 09-17-2008   #2 (permalink)
Bob Barrows [MVP]
Re: SQL Statement Help - Invalid chars
Bob Smith wrote:
> Characters.
> this string
> conn.Execute(SQL)
> include \ ' % OR and other items. There may also be multiple entries
> of one or more of these chars in the same string. any help would be
> appriciated. The source of data is unpredictable.
Use parameters instead of dynamic sql - the need for escaping characters
disappears ... along with the need to worry about delimiting data
values. Like this:
SQL = "INSERT INTO MyTable (DisplayName) Values (?)"
set cmd=createobject("adodb.command")
arparms=array("smith, jacob's")
cmd.commandtext=SQL
Set cmd.activeconnection=conn
cmd.execute ,arparms,129
'129=adCmdText + adExecuteNoRecords
Microsoft MVP -- ASP/ASP.NET
Please reply to the newsgroup. The email account listed in my From
header is my spam trap, so I don't check it very often. You will get a
quicker response by posting to the newsgroup.
split string every tot chars PowerShell
Unicode chars munged? PowerShell
Telneting from Windows Vista hungs after typens some chars Vista networking & sharing
Format a string with non printable chars PowerShell
RE: Format a string with non printable chars PowerShell
