Vista - return variable through script in script
Old 09-18-2008   #1 (permalink)
NIDU
I am using the following code to run a script within side a script
Dim WshShell
Set WSHShell =CreateObject("WScript.Shell")
WSHShell.Run"""E:\Rc Wintrans\VBscript\1.vbs"""
1.vbs is a small script that opens a single empty excel file. Now in
1.vbs i have created an object of excel in the following way
set objExcel=createobject("Excel.Application")
this script runs fine and opens an empty excel file. May be alot of
people may think that I can achieve the same by making a sub function
to open an excel file. With which, I can also return the variable
`objExcel` using arguments.
But due to some special reason i want to use `script in script` method
to open an empty excel file. But i dont know how to return the
variable `objexcel` using this method. Can anybody tell me how to
return variable through `script in script`
Old 09-18-2008   #2 (permalink)
Pegasus \(MVP\)
Re: return variable through script in script
"NIDU" <nidu50@xxxxxx> wrote in message
news:d0dd359a-8170-47bb-bc85-4f0fc2f47136@xxxxxx
> Dim WshShell
The "Run" method spawns a new instance of cscript.exe via the operating
system. Any variables that are passed between your script and this new
instance are passed via the OS. Since Windows knows nothing about objects,
you cannot pass objExcel back to your calling script. By the way, to make
your application robust it would be prudent to invoke the external script
explicitly with "cscript.exe //nologo 1.vbs" instead of relying on
associations that may or may not be present.
Re: delay script return VB Script
Script switch parameter as variable PowerShell
Script to hide a variable folder VB Script
Obtaining Script Exit Return Codes PowerShell
Current script special variable PowerShell
