Vista - VBScript problem in running Stored Query
Old 09-18-2008   #1 (permalink)
Codeblack
I am having strange problem. I have a saved query in MS Access which works
absolutely fine without any problems. But when I try to call the stored query
from VBScript I get the below error. In fact the database has records in it.
Can anyone tell me what could be the problem. Any help will be greatly
appreciated
Error
Either BOF or EOF is True, or the current record has been deleted.
MS Access Query
SELECT SenderToRecip.Sender, AllEmployees.DeptCode, AllEmployees.Department,
AllEmployees.City, SenderToRecip.Recipient, Sum([Total_Bytes]/1024/1024) AS
Total_MB, Sum(SenderToRecip.Recip_Counts) AS Recip_Counts FROM
[Corp009d-Skip] INNER JOIN (SenderToRecip INNER JOIN
AllEmployees ON SenderToRecip.Sender=AllEmployees.Email) ON
([Corp009d-Skip].recipient=SenderToRecip.Recipient) AND
([Corp009d-Skip].sender=SenderToRecip.Sender)
WHERE
(((InStr(Left(SenderToRecip.Recipient,InStr(SenderToRecip.Recipient,"@")-1),[LName]))>0))
GROUP BY SenderToRecip.Sender, AllEmployees.DeptCode,
AllEmployees.Department, AllEmployees.City, SenderToRecip.Recipient
HAVING (((SenderToRecip.Recipient) Like "*@*"))
ORDER BY Sum([Total_Bytes]/1024/1024) DESC;
VBScript :
strExcelPath = "z:\project\file.xls"
Set objExcel = CreateObject("Excel.Application")
objExcel.Visible = True
objExcel.Workbooks.Add
objExcel.Sheets.Add ,objExcel.Sheets(objExcel.Sheets.Count)
x = 1
Set oSheet1 = objExcel.ActiveWorkbook.Worksheets(1)
oSheet1.Name = "abc"
oSheet1.Cells(2,1).Value = "Recip_Domain"
oSheet1.Cells(2,2).Value = "Total MB"
oSheet1.Cells(2,3).Value = "Recip Counts"
Set conn = CreateObject("ADODB.Connection")
strConnect = "Provider=Microsoft.Jet.OLEDB.4.0;Data
Source=z:\Project\test.mdb"
conn.Open strConnect
set rs=createobject("adodb.recordset")
MySavedQuery ="Corp009eSenderToHomeEmail"
rs.open MySavedQuery, conn, 0, 4
intRow = 2
Do While not rs.EOF
Wscript.Echo RS(0)
intRow = intRow + 1
oSheet1.Cells(introw, 1) = RS(0)
oSheet1.Cells(introw, 2) = RS(1)
oSheet1.Cells(introw, 3) = RS(2)
rs.MoveNext
Loop
rs.Close
set rs = nothing
Old 09-18-2008   #2 (permalink)
Richard Mueller [MVP]
Re: VBScript problem in running Stored Query
"Codeblack" <Codeblack@xxxxxx> wrote in message
news:1B0CA8FC-699F-42C7-8B13-20E0167BE2AE@xxxxxx
> query
> it.
> appreciated
> Error
> MS Access Query
> AS
> WHERE
> VBScript :
> x = 1
> intRow = 2
> Do While not rs.EOF
> Wscript.Echo RS(0)
> intRow = intRow + 1
> rs.MoveNext
> Loop
> rs.Close
> set rs = nothing
The error doesn't make sense to me, as nothing should happen if rs.EOF is
True (you don't say which line raised the error, but I assume it is not
rs.Close). I would suspect one of the parameters on the rs.Open statement.
Certainly, lockType = 4 (adLockBatchOptimistic) is not necessary. I would
use 1 or nothing. Maybe you need to specify an option (optional 5th
parameter), perhaps 4 = adCmdStoredProc. In fact, maybe that is what you
intended. Maybe it should be:
rs.Open MySavedQuery, conn, 0, 1, 4
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Old 09-18-2008   #3 (permalink)
I should have included a link to reference on Open method, which explains
options available for all parameters:
http://msdn.microsoft.com/en-us/library/ms675544.aspx
Richard Mueller
Old 09-19-2008   #4 (permalink)
Codeblack
Richard,
Thanks for looking into this. Tried the options which you mentioned but
gettig teh same error. I have simplified the code so that it will be easy to
read. The error is pointing at Wscript.Echo rs(0). Can you please tell me
what is wrong with the code. I tested thie query again in MS access and it
works absolutely fine. Any suggestions will be highly appreciated.
rs.open MySavedQuery, conn, 0, 1, 4
Do While rs.EOF
Wscript.Echo rs(0) ' Error Here
rs.MoveNext
Loop
Old 09-20-2008   #5 (permalink)
Codeblack
Richard,
Any suggestions on this please.
Old 09-22-2008   #6 (permalink)
Codeblack
Does any one has any clue on why this problem is occurring.Can anyone please
help me on this.
Regards
Codeblack
Old 09-24-2008   #7 (permalink)
Codeblack
You are genius, the second suggestion (using %) worked for me. Thanks a lot
for your timelly help.
Regards
Codeblack
VBScript to Query WMI VB Script
execute mysql query using vbscript VB Script
SQL Query in VBScript VB Script
VBScript Problem with Access Query (Unspecified error) VB Script
Running WMI Query in without Powershell or VBS PowerShell
