| | diskpart and WshScriptExec problem Hello, currently putting together a vbscript that is piping input to diskpart.exe (from within winPE). It uses the WshScriptExec object with is sending input commands just fine. The problem I'm having is that even know I'm piping the 'exit' command to diskpart it does not exit... I still see it's process running in taskmgr... so my script loops infinitely waiting for that WshScriptExec.Status to change from 0, which it doesn't since diskpart does not exit. After I manually kill the task with taskmgr, my script breaks out of the loop as expected. the only command I'm sending diskpart that really takes any time is the format command. Thats where my loop comes in and just sleeps waiting for that WshScriptExec.status to change, signaling diskpart is done and has exited. I would really like to make this work the way I have set out to do but I know I have 2 other options: 1, do the format commands outside of diskpart with the 'run' instead of the 'exec' method. This would alow for running format.com synchronously eliminating the issue of not knowing when diskpart is done, or 2, instead of piping the diskpart commands interactively I could pipe them to a txt file which could then be supplied as script file param to diskpart, again, using run instead of exec so that its done synchronously. but again, I really like the way I started this... much cooler in my opinion, but I need to get this done so if anyone has any ideas as to why what I want to do is not working please let me know. I'm going to bail on it and move to an alternative by Monday. thanks. |
| | Re: diskpart and WshScriptExec problem just an update: if someone knows more please do share. I've decided to just move the format operations outside of diskpart. My hunch is that diskpart's format command is probably just actually calling format.com anyway, which is what may be causing my problem with the WshScriptExec object.... the program I execute (diskpart.exe) is calling another program (format.com) and so the 'wiring' between the program and my object get screwy? Thats my hunch, I have to move on. Again, if anyone else has any input on this please do share. thanks. "James" <noone@xxxxxx> wrote in message news:Og5LgIpGJHA.3576@xxxxxx Quote: > Hello, > > currently putting together a vbscript that is piping input to diskpart.exe > (from within winPE). It uses the WshScriptExec object with is sending > input commands just fine. The problem I'm having is that even know I'm > piping the 'exit' command to diskpart it does not exit... I still see it's > process running in taskmgr... so my script loops infinitely waiting for > that WshScriptExec.Status to change from 0, which it doesn't since > diskpart does not exit. After I manually kill the task with taskmgr, my > script breaks out of the loop as expected. > > the only command I'm sending diskpart that really takes any time is the > format command. Thats where my loop comes in and just sleeps waiting for > that WshScriptExec.status to change, signaling diskpart is done and has > exited. I would really like to make this work the way I have set out to do > but I know I have 2 other options: 1, do the format commands outside of > diskpart with the 'run' instead of the 'exec' method. This would alow for > running format.com synchronously eliminating the issue of not knowing when > diskpart is done, or 2, instead of piping the diskpart commands > interactively I could pipe them to a txt file which could then be supplied > as script file param to diskpart, again, using run instead of exec so that > its done synchronously. > > but again, I really like the way I started this... much cooler in my > opinion, but I need to get this done so if anyone has any ideas as to why > what I want to do is not working please let me know. I'm going to bail on > it and move to an alternative by Monday. > > thanks. > |
| | Re: diskpart and WshScriptExec problem On Sep 19, 2:58*pm, "James" <no...@xxxxxx> wrote: Quote: > Hello, > > currently putting together a vbscript that is piping input to diskpart.exe > (from within winPE). It uses the WshScriptExec object with is sending input > commands just fine. The problem I'm having is that even know I'm piping the > 'exit' command to diskpart it does not exit... I still see it's process > running in taskmgr... so my script loops infinitely waiting for that > WshScriptExec.Status to change from 0, which it doesn't since diskpart does > not exit. After I manually kill the task with taskmgr, my script breaks out > of the loop as expected. > > the only command I'm sending diskpart that really takes any time is the > format command. Thats where my loop comes in and just sleeps waiting for > that WshScriptExec.status to change, signaling diskpart is done and has > exited. I would really like to make this work the way I have set out to do > but I know I have 2 other options: 1, do the format commands outside of > diskpart with the 'run' instead of the 'exec' method. This would alow for > running format.com synchronously eliminating the issue of not knowing when > diskpart is done, or 2, instead of piping the diskpart commands > interactively I could pipe them to a txt file which could then be supplied > as script file param to diskpart, again, using run instead of exec so that > its done synchronously. > > but again, I really like the way I started this... much cooler in my > opinion, but I need to get this done so if anyone has any ideas as to why > what I want to do is not working please let me know. I'm going to bail onit > and move to an alternative by Monday. > > thanks. ' ProcessKillLocal.vbs ' Sample VBScript to kill a program ' Author Guy Thomas http://computerperformance.co.uk/ ' Version 2.7 - December 2005 ' ------------------------ -------------------------------' Option Explicit Dim objWMIService, objProcess, colProcess Dim strComputer, strProcessKill strComputer = "." strProcessKill = "'calc.exe'" <---- Diskpart.exe goes here Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" _ & strComputer & "\root\cimv2") Set colProcess = objWMIService.ExecQuery _ ("Select * from Win32_Process Where Name = " & strProcessKill ) For Each objProcess in colProcess objProcess.Terminate() Next WSCript.Echo "Just killed process " & strProcessKill _ & " on " & strComputer WScript.Quit ' End of WMI Example of a Kill Process |
| | Re: diskpart and WshScriptExec problem thanks for the input OldDog. The problem though is that I would'nt know 'when' to kill the process. It runs asynchronously from my main script. I do appreciate your response though. Thanks. "OldDog" <mikef2691@xxxxxx> wrote in message news:90b469bd-2318-45e3-8e67-b36d3cbe3166@xxxxxx On Sep 19, 2:58 pm, "James" <no...@xxxxxx> wrote: Quote: > Hello, > > currently putting together a vbscript that is piping input to diskpart.exe > (from within winPE). It uses the WshScriptExec object with is sending > input > commands just fine. The problem I'm having is that even know I'm piping > the > 'exit' command to diskpart it does not exit... I still see it's process > running in taskmgr... so my script loops infinitely waiting for that > WshScriptExec.Status to change from 0, which it doesn't since diskpart > does > not exit. After I manually kill the task with taskmgr, my script breaks > out > of the loop as expected. > > the only command I'm sending diskpart that really takes any time is the > format command. Thats where my loop comes in and just sleeps waiting for > that WshScriptExec.status to change, signaling diskpart is done and has > exited. I would really like to make this work the way I have set out to do > but I know I have 2 other options: 1, do the format commands outside of > diskpart with the 'run' instead of the 'exec' method. This would alow for > running format.com synchronously eliminating the issue of not knowing when > diskpart is done, or 2, instead of piping the diskpart commands > interactively I could pipe them to a txt file which could then be supplied > as script file param to diskpart, again, using run instead of exec so that > its done synchronously. > > but again, I really like the way I started this... much cooler in my > opinion, but I need to get this done so if anyone has any ideas as to why > what I want to do is not working please let me know. I'm going to bail on > it > and move to an alternative by Monday. > > thanks. ' ProcessKillLocal.vbs ' Sample VBScript to kill a program ' Author Guy Thomas http://computerperformance.co.uk/ ' Version 2.7 - December 2005 ' ------------------------ -------------------------------' Option Explicit Dim objWMIService, objProcess, colProcess Dim strComputer, strProcessKill strComputer = "." strProcessKill = "'calc.exe'" <---- Diskpart.exe goes here Set objWMIService = GetObject("winmgmts:" _ & "{impersonationLevel=impersonate}!\\" _ & strComputer & "\root\cimv2") Set colProcess = objWMIService.ExecQuery _ ("Select * from Win32_Process Where Name = " & strProcessKill ) For Each objProcess in colProcess objProcess.Terminate() Next WSCript.Echo "Just killed process " & strProcessKill _ & " on " & strComputer WScript.Quit ' End of WMI Example of a Kill Process |
| | Re: diskpart and WshScriptExec problem On Sep 19, 5:56*pm, "James" <no...@xxxxxx> wrote: Quote: > thanks for the input OldDog. The problem though is that I would'nt know > 'when' to kill the process. It runs asynchronously from my main script. Ido > appreciate your response though. Thanks. > > "OldDog" <mikef2...@xxxxxx> wrote in message > > news:90b469bd-2318-45e3-8e67-b36d3cbe3166@xxxxxx > On Sep 19, 2:58 pm, "James" <no...@xxxxxx> wrote: > > > > > Quote: > > Hello, Quote: > > currently putting together a vbscript that is piping input to diskpart.exe > > (from within winPE). It uses the WshScriptExec object with is sending > > input > > commands just fine. The problem I'm having is that even know I'm piping > > the > > 'exit' command to diskpart it does not exit... I still see it's process > > running in taskmgr... so my script loops infinitely waiting for that > > WshScriptExec.Status to change from 0, which it doesn't since diskpart > > does > > not exit. After I manually kill the task with taskmgr, my script breaks > > out > > of the loop as expected. Quote: > > the only command I'm sending diskpart that really takes any time is the > > format command. Thats where my loop comes in and just sleeps waiting for > > that WshScriptExec.status to change, signaling diskpart is done and has > > exited. I would really like to make this work the way I have set out todo > > but I know I have 2 other options: 1, do the format commands outside of > > diskpart with the 'run' instead of the 'exec' method. This would alow for > > running format.com synchronously eliminating the issue of not knowing when > > diskpart is done, or 2, instead of piping the diskpart commands > > interactively I could pipe them to a txt file which could then be supplied > > as script file param to diskpart, again, using run instead of exec so that > > its done synchronously. Quote: > > but again, I really like the way I started this... much cooler in my > > opinion, but I need to get this done so if anyone has any ideas as to why > > what I want to do is not working please let me know. I'm going to bail on > > it > > and move to an alternative by Monday. Quote: > > thanks. > You will probably need to Kill the Diskpart process after you quit. > > ' ProcessKillLocal.vbs > ' Sample VBScript to kill a program > ' Author Guy Thomashttp://computerperformance.co.uk/ > ' Version 2.7 - December 2005 > ' ------------------------ -------------------------------' > Option Explicit > Dim objWMIService, objProcess, colProcess > Dim strComputer, strProcessKill > strComputer = "." > strProcessKill = "'calc.exe'" *<---- Diskpart.exe goes here > > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate}!\\" _ > & strComputer & "\root\cimv2") > > Set colProcess = objWMIService.ExecQuery _ > ("Select * from Win32_Process Where Name = " & strProcessKill ) > For Each objProcess in colProcess > objProcess.Terminate() > Next > WSCript.Echo "Just killed process " & strProcessKill _ > & " on " & strComputer > WScript.Quit > ' End of WMI Example of a Kill Process- Hide quoted text - > > - Show quoted text - it waiting for any additional input when using diskpart before it hits the exit? |
| | #6 (permalink) |
| | Re: diskpart and WshScriptExec problem good point, I just double-checked and no, its not awaiting input. Thanks for the good thought though. "pooradmin" <jskiba99@xxxxxx> wrote in message news:35eac1cf-d47c-4074-a6dd-fd5b9aba87be@xxxxxx On Sep 19, 5:56 pm, "James" <no...@xxxxxx> wrote: Quote: > thanks for the input OldDog. The problem though is that I would'nt know > 'when' to kill the process. It runs asynchronously from my main script. I > do > appreciate your response though. Thanks. > > "OldDog" <mikef2...@xxxxxx> wrote in message > > news:90b469bd-2318-45e3-8e67-b36d3cbe3166@xxxxxx > On Sep 19, 2:58 pm, "James" <no...@xxxxxx> wrote: > > > > > Quote: > > Hello, Quote: > > currently putting together a vbscript that is piping input to > > diskpart.exe > > (from within winPE). It uses the WshScriptExec object with is sending > > input > > commands just fine. The problem I'm having is that even know I'm piping > > the > > 'exit' command to diskpart it does not exit... I still see it's process > > running in taskmgr... so my script loops infinitely waiting for that > > WshScriptExec.Status to change from 0, which it doesn't since diskpart > > does > > not exit. After I manually kill the task with taskmgr, my script breaks > > out > > of the loop as expected. Quote: > > the only command I'm sending diskpart that really takes any time is the > > format command. Thats where my loop comes in and just sleeps waiting for > > that WshScriptExec.status to change, signaling diskpart is done and has > > exited. I would really like to make this work the way I have set out to > > do > > but I know I have 2 other options: 1, do the format commands outside of > > diskpart with the 'run' instead of the 'exec' method. This would alow > > for > > running format.com synchronously eliminating the issue of not knowing > > when > > diskpart is done, or 2, instead of piping the diskpart commands > > interactively I could pipe them to a txt file which could then be > > supplied > > as script file param to diskpart, again, using run instead of exec so > > that > > its done synchronously. Quote: > > but again, I really like the way I started this... much cooler in my > > opinion, but I need to get this done so if anyone has any ideas as to > > why > > what I want to do is not working please let me know. I'm going to bail > > on > > it > > and move to an alternative by Monday. Quote: > > thanks. > You will probably need to Kill the Diskpart process after you quit. > > ' ProcessKillLocal.vbs > ' Sample VBScript to kill a program > ' Author Guy Thomashttp://computerperformance.co.uk/ > ' Version 2.7 - December 2005 > ' ------------------------ -------------------------------' > Option Explicit > Dim objWMIService, objProcess, colProcess > Dim strComputer, strProcessKill > strComputer = "." > strProcessKill = "'calc.exe'" <---- Diskpart.exe goes here > > Set objWMIService = GetObject("winmgmts:" _ > & "{impersonationLevel=impersonate}!\\" _ > & strComputer & "\root\cimv2") > > Set colProcess = objWMIService.ExecQuery _ > ("Select * from Win32_Process Where Name = " & strProcessKill ) > For Each objProcess in colProcess > objProcess.Terminate() > Next > WSCript.Echo "Just killed process " & strProcessKill _ > & " on " & strComputer > WScript.Quit > ' End of WMI Example of a Kill Process- Hide quoted text - > > - Show quoted text - it waiting for any additional input when using diskpart before it hits the exit? |
| Diskpart Mistake | Vista General | |||
| Using Diskpart in VM's | Virtual PC | |||
| Diskpart and Imagex | Vista installation & setup | |||
| Diskpart utility | Vista installation & setup | |||
| Diskpart Format command | Vista General | |||
