| | Re: String manipulation using replace etc. The objective is to replace all lower or upper case alphabet "o" to a number zero in the string "opt". Is there a way to do this Opt is entered by the user and will vary with each input. This is waht I have done and its not working ================================ opt="o3050406252602O127152816" wscript.echo ReplaceTest(left(opt,2),"o","0") extract2=ReplaceTest(left(opt,2),"o","0") extract2=ReplaceTest(left(opt,2),"oM","01") extract2=ReplaceTest(left(opt,2),"oT","02") Function ReplaceTest(str2,patrn, replStr) Dim regEx ' Create variables. Set regEx = New RegExp ' Create regular expression. regEx.Pattern = patrn ' Set pattern. regEx.IgnoreCase = True ' Make case insensitive. ReplaceTest = regEx.Replace(str2, replStr) ' Make replacement. End Function |
| string manipulation - join lines | VB Script | |||
| string manipulation | VB Script | |||
| Re: String manipulation using replace etc. | VB Script | |||
| string manipulation | PowerShell | |||
