| | Re: String manipulation using replace etc. Hi, The objective is to replace all "o" (alphabet - lower or upper) to "0" (number zero) in the string "opt". opt is a user input and hence varies. Here's my code that does not work ========================= opt="o3050406252602O127oT1528oM16" wscript.echo ReplaceTest(left(opt,2),"o","0") ' gives 03 - correct extract2=ReplaceTest(left(opt,2),"o","0") 'extract2 = o3 incorrect ???? why Function ReplaceTest(str2,patrn, replStr) Dim regEx ' Create variables. Set regEx = New RegExp ' Create regular expression. regEx.Pattern = patrn ' Set pattern. regEx.IgnoreCase = True ' Make case insensitive. ReplaceTest = regEx.Replace(str2, replStr) ' Make replacement. End Function |
| string manipulation - join lines | VB Script | |||
| string manipulation | VB Script | |||
| Re: String manipulation using replace etc. | VB Script | |||
| string manipulation | PowerShell | |||
