Vista Tutorial - Copy file to Document and Settings folder permission problem
Old 09-25-2008   #1 (permalink)
Philip Tattersall
Guest
I am trying to copy a file from a location on a server into the
following directory on local pc's
C:\Documents and Settings\All Users\Application Data
I can copy the file with no trouble to c:\Documents and Settings.
However I get a permission denied error code 800a0046 message and the
script fails when trying o copy to
C:\Documents and Settings\All Users\Application Data.
The code I'm using is below. Any suggestions would be much appreciated.
Dim FSO
Set FSO = CreateObject("Scripting.FileSystemObject")
FSO.CopyFile "z:\scripts\test.txt", "C:\Documents and Settings\All
Users\Application Data"
*** Sent via Developersdex http://www.developersdex.com ***
Old 09-25-2008   #2 (permalink)
esska
Guest
Re: Copy file to Document and Settings folder permission problem
Try to copy the script:
Copying a File
Demonstration script that uses the FileSystemObject to copy a file.
Script must be run on the local computer.
Const OverwriteExisting = True
Set objFSO = CreateObject("Scripting.FileSystemObject")
objFSO.CopyFile "C:\FSO\ScriptLog.txt" , "D:\Archive\",
OverwriteExisting
source:
http://www.activexperts.com
Old 09-25-2008   #3 (permalink)
James Whitlow
Guest
"Philip Tattersall" <philip@xxxxxx> wrote in message
news:esPQYIwHJHA.3736@xxxxxx
> Dim FSO
You need to add a backslash to the end of your destination so that it
knows it is a directory. As written, it is trying to copy 'test.txt' to
'C:\Documents and Settings\All Users' with a filename of 'Application Data'.
The error is a result of there already being a folder with that name in the
directory.
Old 09-25-2008   #4 (permalink)
Al Dunbar
Guest
"James Whitlow" <jwhitlow.60372693@xxxxxx> wrote in message
news:OU5Er60HJHA.788@xxxxxx
>> Dim FSO
> Data'. The error is a result of there already being a folder with that
> name in the directory.
Or, since the copy seems to be from a remote share mapped as Z:, perhaps
this is running as a logon script in the security context of an account that
does not have local admin privileges. If so, it might be better to run a
script that pushes the file out to remote systems' in that particular
folder.
/Al
Old 09-26-2008   #5 (permalink)
esska
Guest
The problem is with script not with permissions However if you want
to copy to share folder you need to have domain user rights.
Regards,
document and settings access problem Vista file management
Lost document or file folder Vista file management
You need permission to perform this action!! to copy a file to a directory with Admin rights Vista security
View and copy document content without opening the document Vista General
View and copy document content without opening the document Vista performance & maintenance
