Vista - problem with SetDNSServerSearchOrder WMI function
Old 09-25-2008   #1 (permalink)
James
uint32 SetDNSServerSearchOrder(
[in] string DNSServerSearchOrder[]
above is copy/paste from msdn site on this function. I keep getting error
70, which means invalid IP address but I know the IP's I'm supplying are
fine. The site said that it takes a 'list' of ip addresses but fails to
mention how that list should be delimited.. I've tried comma and space and
'or' with no luck, same error every time.
here is a snippet of my code, including some temp debugging stuff:
Dim temp
aDNSServers = Array(PrimaryDNS & "," & SecondaryDNS)
For Each temp In aDNSServers
MsgBox temp
Next
sQuery = "SELECT MACAddress FROM Win32_NetworkAdapterConfiguration WHERE
IPEnabled = TRUE"
set colAdapters = oWMI.ExecQuery(sQuery)
For Each oAdapter In colAdapters 'all the NICs in the machine
MsgBox "configuring: " & oAdapter.MACAddress
iRetVal = oAdapter.SetDNSServerSearchOrder(aDNSServers)
If iRetVal = 0 Then
msgbox "DNS servers set."
Else
msgbox "possible error setting dns servers: " & iRetval
End If
next
aDNSServers contains 2 ipaddresses delimited by a comma. This has been
verified with my debugging msgboxs at runtime.
what am I missing here?
Old 09-26-2008   #2 (permalink)
J Ford
RE: problem with SetDNSServerSearchOrder WMI function
I have had problems in the past when trying to set something and using a
specific select statement ie "SELECT MACAddress...", but when I have done
"SELECT *..." it worked.
-J
> Dim temp
> MsgBox temp
> Next
> IPEnabled = TRUE"
> If iRetVal = 0 Then
> Else
> End If
> next
Old 09-26-2008   #3 (permalink)
James
Re: problem with SetDNSServerSearchOrder WMI function
Thanks for the reply J Ford. I appreciate it. That has happened to me before
also and I didn't even think to try that for this one... turned out to not
be the issue in this case but I appreciate the good advice none the less.
In this case it turns out I'm an idiot (again)
this line:
is the problem. Even know I knew the IPs I was supplying were valid I
screwed up making the array. Above produces array with one element
containing a string with both IP's seperated by the comma. Improper use of
the array function. Should be this:
aDNSServers = Array(PrimaryDNS, SecondaryDNS)
and works fine when it is.
"J Ford" <JFord@xxxxxx> wrote in message
news:7F2ACC92-FF10-4831-9C19-C3EA98B8F8B2@xxxxxx
> -J
>> and
>> Dim temp
>> MsgBox temp
>> Next
>> IPEnabled = TRUE"
>> If iRetVal = 0 Then
>> Else
>> End If
>> next
win32_pingstatus and function problem PowerShell
Function problem with keyboard Vista hardware & devices
Problem using split function VB Script
Keyboard second function problem Vista hardware & devices
Problem with Vista's sleep function Vista General
