| Vista Home Premium 32bit | what is difference between VB and VB.net what is difference between VB and VB.net |
| | Re: what is difference between VB and VB.net "pradip030384" <guest@xxxxxx-email.com> wrote in message news:5b9c7e2b04a1f93f905347d098a54735@xxxxxx-gateway.com... Quote: > > what is difference between VB and VB.net > > > -- > pradip030384 language more akin to VB than VB.NET, then I suggest a web search, a VB or a VB.NET group. http://www.thescarms.com/vbasic/vb6vsvbnet.aspx -- Joe Fawcett (MVP - XML) http://joe.fawcett.name |
| | Re: what is difference between VB and VB.net VB (mostly VB 5 and 6) is a COM-centric programming system for writing compiled Windows software, using mostly ActiveX and the Win32 API. VB 5 and 6 each have their own 1 MB runtime library. VB was designed to be a "RAD" (rapid application development) system that allowed for designing a program GUI graphically and then writing the code behind it. In many cases there are also components available that simplify complex coding challenges. The idea was to provide a way for programmers to learn something less abstruse and -- and program in something less tedious -- than plain C++. In VB one can write software that mainly uses the Win32 API, like traditional C++ software, but one can also write very simple and quick programs by using components. VB.Net is a Java-like system that uses the .Net Framework (a 70+ MB runtime, correlate to the Java VM). It creates JIT-compiled "assemblies", designed for use where Java might be used: in creating server-side components for Windows servers, corporate intranet software, etc. Like Java, .Net software is designed to be powererd by a runtime (one or more support libraries), not directly connected to the operating system API, thus making it cross-platform and safer to use than most compiled software. Unlike Java, .Net is not really cross-platform (the latest version only runs on XP SP2 and Vista) and it's not necessarily safe because the exclusive dependence on the runtime can be supplemented by the use of "unsafe" API calls. In many ways VB.Net is to VB what Java is to C++. VB.Net does not create compiled executables. VB does not use the the .Net Framework. The numerous classes that are built into VB.Net do not exist in VB. Etc. VB is for Windows software. .Net, like Java, is more for server-side software because of its slow speed, large runtime, and ease of decompiling. At Microsoft they've been wanting all "3rd-party" developers to get switched over to .Net so that only Microsoft and their partners would be directly using the Window platform -- the Win32 API. As part of the .Net marketing push, the name "VB.Net" was shortened to just "VB" awhile back. So you might get different answers to your question in different places. To many newer VB.Net programmers, VB and VB.Net mean the same thing. To reiterate what Joe Fawcett said, neither VB nor VB.Net has anything to do with VBScript, and this is a VBScript group. If you have a VB question try: microsoft.public.vb.general.discussion If you have a VB.Net question try any group with "dotnet" in the name, such as: microsoft.public.dotnet.languages.vb Quote: > > what is difference between VB and VB.net > > > -- > pradip030384 |
| What is the difference between -eq and = | PowerShell | |||
| Difference between 32 & 64? | General Discussion | |||
| What is the difference | Vista music pictures video | |||
| 32 or 64 bit? What's the difference? | Vista installation & setup | |||
| What is the difference between Pre-RC1 and RC1? | Vista installation & setup | |||
