| | Help with a regular expression Hi Can someone help me with a regular expression to validate the following string: 1. A number must be between 1000 and 9999 2. Several numbers can be entered in a sequence separates with a comma 3. Not more then 5 numbers can be entered at one time Example of valid entries: ================= 1052 1052,1175,1951 1052,1175,1951,1000,1157 Example of invalid entries ==================: 0995 (must be between 1000 and 9999) 1052,12, 1175 (must be between 1000 and 9999, and no spaces) 1052;1175;1951; (comma must be used to separate numbers and no trailing commas) 1052,1175,1951,1000,1157,7852 (no more then 5 numbers may be entered) Thanks in advance Pete |
| | Re: Help with a regular expression PO wrote: Quote: > > Can someone help me with a regular expression to validate the > following string: > > 1. A number must be between 1000 and 9999 > 2. Several numbers can be entered in a sequence separates with a comma > 3. Not more then 5 numbers can be entered at one time > --- test = array("1052", _ "1052,1175,1951", _ "1052,1175,1951,1000,1157", _ "0995", _ "1052,12, 1175", _ "1052;1175;1951;", _ "1052,1175,1951,1000,1157,7852" _ ) with new regexp .pattern = "^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$" for each str in test wscript.echo .test(str) & vbTab & str next end with -- Steve The belief in the possibility of a short decisive war appears to be one of the most ancient and dangerous of human illusions. -Robert Lynd |
| | Re: Help with a regular expression Thanks a lot Steve. Works just like I want. If I want to increase or decrease the number of values a user can enter, do I just change the last number i.e. ^[1-9]\d{3}(?:,[1-9]\d{3}){0,5}$ will allow 6 values? Regards Pete "Steve" <cerberus40@xxxxxx> skrev i meddelandet news:uE0aL3uIJHA.1088@xxxxxx Quote: > PO wrote: Quote: >> >> Can someone help me with a regular expression to validate the >> following string: >> >> 1. A number must be between 1000 and 9999 >> 2. Several numbers can be entered in a sequence separates with a comma >> 3. Not more then 5 numbers can be entered at one time >> > ^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$ > > --- > > test = array("1052", _ > "1052,1175,1951", _ > "1052,1175,1951,1000,1157", _ > "0995", _ > "1052,12, 1175", _ > "1052;1175;1951;", _ > "1052,1175,1951,1000,1157,7852" _ > ) > > with new regexp > .pattern = "^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$" > for each str in test > wscript.echo .test(str) & vbTab & str > next > end with > > -- > Steve > > The belief in the possibility of a short decisive war appears to be one > of the most ancient and dangerous of human illusions. -Robert Lynd > |
| | Re: Help with a regular expression The first thing you need to find out before modifying someone's regular expression is to analyze what it does and how it works. A useful but imperfect tool for this is Regular Expression Workbench, a link to which you should be able to find by groups.googling this microsoft.public.scripting.vbscript newsgroup. Note that Regular Expression Workbench uses the dot net regular expression engine rather than the VBScript regular expression engine, so it is not perfect for VBScripting purposes and will sometimes lead you astray. It is often helpful, as in this case. The regular expression ^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$ is interpreted to mean: ^ (anchor to start of string) Any character in "1-9" Any digit Exactly 3 times Non-capturing Group , Any character in "1-9" Any digit Exactly 3 times End Capture At least 0, but not more than 4 times $ (anchor to end of string) I'm not sure whether this interpretation correctly handles the ?: in the regular expression -- I don't know what those two characters do here. Assuming that this dot net interpretation of the original regular expression actually is the author's intent, then is is pretty easy to see that the current pattern requires four digits per number, the first digit of any number cannot be a zero, and a comma preceeds the four digits for all numbers following the first number, with zero to 5 numbers on a line. With Regular Expression Workbench you can easily modify the regular expression and execute it on a test string. -Paul Randall "PO" <h> wrote in message news:uQr2spwIJHA.2156@xxxxxx Quote: > Thanks a lot Steve. Works just like I want. > If I want to increase or decrease the number of values a user can enter, > do I just change the last number i.e. ^[1-9]\d{3}(?:,[1-9]\d{3}){0,5}$ > will allow 6 values? > > Regards > Pete > > "Steve" <cerberus40@xxxxxx> skrev i meddelandet > news:uE0aL3uIJHA.1088@xxxxxx Quote: >> PO wrote: Quote: >>> >>> Can someone help me with a regular expression to validate the >>> following string: >>> >>> 1. A number must be between 1000 and 9999 >>> 2. Several numbers can be entered in a sequence separates with a comma >>> 3. Not more then 5 numbers can be entered at one time >>> >> ^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$ >> >> --- >> >> test = array("1052", _ >> "1052,1175,1951", _ >> "1052,1175,1951,1000,1157", _ >> "0995", _ >> "1052,12, 1175", _ >> "1052;1175;1951;", _ >> "1052,1175,1951,1000,1157,7852" _ >> ) >> >> with new regexp >> .pattern = "^[1-9]\d{3}(?:,[1-9]\d{3}){0,4}$" >> for each str in test >> wscript.echo .test(str) & vbTab & str >> next >> end with >> >> -- >> Steve >> >> The belief in the possibility of a short decisive war appears to be one >> of the most ancient and dangerous of human illusions. -Robert Lynd >> > |
| | Re: Help with a regular expression Paul Randall wrote: Quote: > > I'm not sure whether this interpretation correctly handles the ?: in > the regular expression -- I don't know what those two characters do > here. expression is executed. Any time you use parentheses in a pattern and don't use the Submatches collection (or don't use all the members of the collection) you should use (?: ) to group any submatch you're not interested in. I'm not sure about the .NET regexp engine, but the VBScript engine does not degrade well for complex patterns. When a pattern crosses the tipping point, the engine "hits the wall" and slows to a crawl. Anything you can do to cut down the work the engine needs to do and moves the wall a little further back. I don't know if the VBScript regexp's Test method is optimized, but I suspect that it just calls the same code as the Execute method and tests the Count property of the returned Matches collection. And in this case, a submatch is not very useful--it would only capture the last group of comma and digits and ignore any preceeding ones. -- Steve We have just enough religion to make us hate but not enough to make us love one another. -Jonathan Swift |
| | #6 (permalink) |
| | Re: Help with a regular expression PO wrote: Quote: > Thanks a lot Steve. Works just like I want. > If I want to increase or decrease the number of values a user can > enter, do I just change the last number i.e. > ^[1-9]\d{3}(?:,[1-9]\d{3}){0,5}$ will allow 6 values? > ^[1-9]\d{3}(?:,[1-9]\d{3}){1,4}$ will only accept 2-5 values. Paul's advice is good--you should analyze and understand what a pattern does before you use it. I know regexp patterns seem like arcane incatations, as though you should be sacrificing a chicken while reciting them during a new moon, but if you keep working with them you'll reach an "aha moment" and suddenly they start to make sense. For a long time I didn't use regexps because I didn't understand them and I didn't understand them because I didn't use them. ;-) Once you get the hang of them, you'll find them incredibly useful and wonder how you ever got along without them. -- Steve The world is a tragedy to those who feel, but a comedy to those who think. -Horace Walpole |
| | #7 (permalink) |
| | Re: Help with a regular expression "Steve" <cerberus40@xxxxxx> wrote in message news:uhduVL7IJHA.1556@xxxxxx Quote: > PO wrote: Quote: > For a long time I didn't use regexps because I didn't understand them and > I didn't understand them because I didn't use them. ;-) Once you get the > hang of them, you'll find them incredibly useful and wonder how you ever > got along without them. time, thinking they had a high learning curve with little payoff. I use at least one regular expression in the majority of the scripts I write now. I really wish Microsoft had included 'lookbehind', though. I have only needed it a few times, but in those instances there was no good work-around. I am glad that we did get 'lookahead', though. These are my three most often used syntax pages: http://msdn.microsoft.com/en-us/library/ms974570.aspx http://msdn.microsoft.com/en-us/libr...41(VS.71).aspx http://regexlib.com/CheatSheet.aspx |
| | #8 (permalink) |
| | Re: Help with a regular expression James Whitlow wrote: Quote: > "Steve" <cerberus40@xxxxxx> wrote in message > news:uhduVL7IJHA.1556@xxxxxx > Quote: >> For a long time I didn't use regexps because I didn't understand >> them and I didn't understand them because I didn't use them. ;-) >> Once you get the hang of them, you'll find them incredibly useful >> and wonder how you ever got along without them. > I am in complete agreement with you! Like you, I avoided them for > a long time, thinking they had a high learning curve with little > payoff. I use at least one regular expression in the majority of the > scripts I write now. I really wish Microsoft had included > 'lookbehind', though. I have only needed it a few times, but in those > instances there was no good work-around. I am glad that we did get > 'lookahead', though. really wish MS had included the Singleline mode for VBScript regexps (also in .NET). The workaround is pretty straightforward but it's so much simpler to code "." than "[\s\S]" or "[\w\W]" when you want to match every character including newlines. Quote: > These are my three most often used syntax pages: > > http://msdn.microsoft.com/en-us/library/ms974570.aspx > http://msdn.microsoft.com/en-us/libr...41(VS.71).aspx > http://regexlib.com/CheatSheet.aspx http://msdn.microsoft.com/en-us/libr...pting12_topic4 when I can't remember how to code replacement function in VBScript. -- Steve If someone does something we disapprove of, we regard him as bad if we believe we can deter him from persisting in his conduct, but we regard him as mad if we believe we cannot. -Thomas Szasz |
| Regular Expression help C# | .NET General | |||
| regular expression capture | PowerShell | |||
| Regular Expression for ../ | .NET General | |||
| regular expression help | VB Script | |||
| simple regular expression | PowerShell | |||
