Vista - What is the executable associated with running VBScripts?
Old 10-07-2008   #1 (permalink)
gimme_this_gimme_that
I'd like to run VBScripts from the cygwin command line.
Executing the scipts from the cygwin command line fails out right.
But running the script would work fine if I knew what executable to
evoke to run a VBScript.
What is it?
Thanks.
Old 10-07-2008   #2 (permalink)
Pegasus \(MVP\)
Re: What is the executable associated with running VBScripts?
<gimme_this_gimme_that@xxxxxx> wrote in message
news:4f573117-b0b1-4e12-b6ee-6fa0a545458e@xxxxxx
> What is it?
> Thanks.
You could look it up in the association registered for .vbs files. It's
wscript.exe or cscript.exe.
Old 10-07-2008   #3 (permalink)
Richard Mueller [MVP]
"Pegasus (MVP)" <I.can@xxxxxx> wrote in message
news:ua3O9gMKJHA.5232@xxxxxx
>> What is it?
>> Thanks.
The Wscript host executes VBScripts in a GUI environment. The Cscript host
executes scripts in a console or command line environment. You can pass the
name of the VBScript program (with *.vbs extension) as a parameter to
either.
Richard Mueller
MVP Directory Services
Hilltop Lab - http://www.rlmueller.net
Running an executable within a VBscript VB Script
Running executable from Power Point Vista General
Running an executable - how? PowerShell
VBScripts in Vista Vista General
running an executable PowerShell
