Vista - Using ADODB
Old 10-08-2008   #1 (permalink)
Sparkie
Using ADODB
I'm trying to edit an SQL database using the ADODB object, using Mircosoft
SQL Server 2005 Express. The script runs from the command line not from a
WEB page.
If I have Attached to the database using server management studio, then I
can open the database, but if I have not already attached to the database
then the processs fails.
The Current Code I have is
Dim oSQLServer
Dim sConnectionString
sConnectionString = "Driver={SQL Server};Server=KDANCERLTXP;
Database=i96X;Uid=sa;Pwd=XXXX;"
Set oSQLServer = CreateObject("ADODB.Connection")
oSQLServer.Open sConnectionString
If SQL Server has not already attached to the data base how do I use the
ADODB object to attach to the database before I open it?
Old 10-08-2008   #2 (permalink)
Joe Fawcett
Re: Using ADODB
It maybe because SQLExpress catalogues are loaded from a file when needed
unlike regular SQL ones.
I wouldn't use ODBC connection (the 'driver' keyword means it's using ODBC).
Take a look at http://www.connectionstrings.com and pick one the more modern
connection strings such as:
Server=.\SQLExpress;AttachDbFilename=c:\asd\qwe\mydbfile.mdf;Database=dbname;Trusted_Connection=Yes;
(under SQL 2005 section, you may want to use username/password instead of
Windows authentication)
Alternatively use:
Server=myServerAddress\SQLExpress;Database=myDataBase;User
ID=myUsername;Password=myPassword;Trusted_Connection=False;
(SQL Express usually runs as a named instance)
Joe Fawcett (MVP - XML)
http://joe.fawcett.name
"Sparkie" <Sparkie@xxxxxx> wrote in message
news:0741FF0F-A40F-4D37-B786-CF81B2415074@xxxxxx
> WEB page.
> Dim oSQLServer
Error using SUM() with the ADODB Object VB Script
Using SUM with ADODB object VB Script
migrating vb6 code using adodb .NET General
ADODB: com and .net PowerShell
Powershell 32 vs. 64 when using ADODB PowerShell
